Cold Starts
Old February 15th 04, 01:18 PM
Viperdoc
Default Cold Starts
Is it worth lugging long extension cords to plug in the Tanis heaters for my
Baron if it's going to sit outside at 12 degrees for two to three hours
after a flight?
I have cowl plugs which may help a little, but is it really a problem? The
oil will be well circulated, and the battery is in good shape to crank the
engines.
Also, the POH says to keep the cowl flaps open during taxi and take off, but
when it's so cold outside does this still make sense? As long as the CHTs
remain within a reasonable range what difference should it make?
Thanks from Wisconsin, where its 2 degrees and clear.
Old February 15th 04, 02:29 PM
Nathan Young
On Sun, 15 Feb 2004 13:18:35 GMT, "Viperdoc"
after a flight?
engines.
It is hard to say, as it will vary plane to plane. But in that kind
of cold, for my O-360, 3 hours is pushing it. A cowl cover in
addition to cowl plugs is the only way I can wait that long.
The Baron's engines would have more thermal mass than the O-360, so
perhaps you can go longer. OTOH, you don't mention cowl covers...
Without the covers, I'd bring the extensions for the Tanis.
-Nathan
Old February 16th 04, 04:08 AM
Travis Marlatte
So, for those of you with plug in heaters, how does that work out? I presume
that at your home airport, you are parked in your own unheated hangar or
near an outlet on the ramp. What about visiting other airports? Do you asked
to be parked near an outlet? Do they stretch a cord across the ramp for you?
Do they plug it into a service truck for a couple of hours before start?
Travis
Old February 16th 04, 11:49 AM
Ron Rosenfeld
On Mon, 16 Feb 2004 04:08:04 GMT, "Travis Marlatte"
Travis
If I cannot plug in, I obtain pre-heat in the usual manner -- i.e. the FBO
either has a gas fired unit; heated hangar or I make other arrangements.
Some folk will carry small generators; others will carry small "Red
Dragons".
Old February 22nd 04, 01:24 AM
Ray Andraka
Most of the time, I've been able to arrange either to leave it plugged in, or
more often have the fBO move it and plug it a few hours before I intend to
depart. I keep an extension cord in the plane all winter. You never know when
a short stop might turn into a longer one than intended, and the weight of the
extension cord is not all that much.
Travis
--Ray Andraka, P.E.
President, the Andraka Consulting Group, Inc.
401/884-7930 Fax 401/884-7950
email
http://www.andraka.com
"They that give up essential liberty to obtain a little
temporary safety deserve neither liberty nor safety."
-Benjamin Franklin, 1759
Old February 15th 04, 02:58 PM
rip
Aluminum shrinks and expands more than steel. At some temperature around
10 degrees the case will have shrunk onto the crank and cam to the
point where you have zero bearing clearance!
Rip
after a flight?
engines.
Old February 15th 04, 04:36 PM
Dale
after a flight?
What is an engine worth? g IF you have a cowl blanket and IF the
engine oil will stay warm for that length of time then it shouldn't be a
problem. I would plug it in if it was my airplane.
CHTs might be okay but other areas of the engine compartment may be
heating up. I used to fly a B-17 and B-24, we always had the cowlflaps
open on the ground because if they were closed it was possible to heat
damage the sparkplug wires. Big difference in engines I know. If the
POH says leave them open I would. If you've preheated properly the
engine will come up to temp quickly and you'll need them open. Also,
with a change in procedure it would be easy to goof and leave them
closed during takeoff and climb which could really cook things.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old February 15th 04, 10:13 PM
Dennis O'Connor
I started my engines this morning at -4 F... No preheat never do No
problems; though it did take 6 blades each, before they fired - mucho cold
senor... Use 15W50... I get oil pressure indication in less than ten
seconds... That's the way this airplane has been treated ever since
semisynthetic, multiviscosity, oils came out.... Engines go to TBO
routinely...
denny
"Dale" wrote in message
for my
after a flight?
but
CHTs
Dale L. Falk
Old February 15th 04, 11:04 PM
Dale
routinely...
denny
Wow. To each his own. I would never start at those temps without
preheat, and I also used 15W50. I've also tried to pour it when it's
cold. G If it works for you, great.
Dale L. Falk
Old February 16th 04, 04:25 PM
Jay Honeck
Wow. Pretty cavalier attitude with two engines worth close to $20K apiece.
I've found that for periods of four hours or less, the engine will stay
pretty warm with our dark blue cowl cover on -- especially in a bright sun.
For longer periods, plugging in is essential. A couple of weeks ago, while
staying at Lake Lawn Lodge (in Lake Delevan, WI) the oil temperature was 34
degrees at start-up -- even after being plugged in overnight, WITH the cowl
cover on!
The outside temperature was -10, and the wind was howling.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Turbine air start -- too cold? Juan Jimenez Home Built 97 March 14th 05 06:51 PM
Turbine air start -- too cold? Juan Jimenez General Aviation 54 February 2nd 05 04:14 AM
Cold War relic F/A-22 initially designed for air-to-air combat with Soviet MiGs Larry Dighera Military Aviation 7 April 2nd 04 07:05 PM
Soviet Spy Planes over the West during the Cold War Rusty B Military Aviation 6 February 19th 04 04:53 PM
Battery Replacement and Cold Cranking Amps O. Sami Saydjari Owning 27 February 2nd 04 02:38 PM
