Car/Truck to pull glider trailer
Old May 25th 18, 07:26 PM posted to rec.aviation.soaring
George Haeh
Default Car/Truck to pull glider trailer
My 2006 Subaru Forester manual gets 9.6 km/l towing compared to about 11.5 km/l in the summer.
The 2008 SF automatic ate more gas with all the downshifts pulling a trailer.
  #52
Old May 25th 18, 11:30 PM posted to rec.aviation.soaring
Jonathan St. Cloud
I found the Suburban 2500 to be an excellent tow vehicle. Towed my nimbus 4 so well i had to hang a reminder on review mirror that I was towing. Truck and trailer had over a 400 mile range so on long drives I sent myself up for relief on the move. Loved the bench seat for long drives!
On Tuesday, March 24, 2015 at 9:04:01 AM UTC-7, wrote:
Hi All,
I am new to this group and last fall added a glider rating to my ASEL certificate.
I am planning to replace my car this summer and in anticipation of purchasing a glider someday, I would like to purchase a vehicle that would do a good job towing a glider. I also want it to get the best gas mileage that it can while still being a good tow vehicle. I don't want something that is marginal and will make long distance towing a stressful affair, but also don't want a vehicle that is overkill.
What is the typical range o gross weights of a single seat glider plus trailer?
Recommendations on a good tow vehicles?
Thanks for your help
Bill
  #53
Old May 26th 18, 01:47 PM posted to rec.aviation.soaring
Scott Manley[_3_]
The 2017 Tesla Model X I am leasing is a amazing tow vehicle. Other than the range reduction (about 200 mile max between charges) that is more obvious when driving a vehicle that makes you aware of your energy consumption, its 5500 lb weight, low center of gravity, 550 bhp, all-wheel drive, and 500 ftlb of torque instantly available at all speeds (starting at zero) make it a great tow vehicle for my Cobra 30 ft all-aluminum 15m trailer. If I don't look back, I don't even know its back there.
The 200 hundred mile max between charges is conservative, ensuring 20% of battery capacity on arrival. With Tesla's nation-wide network of fast chargers located 50-150 miles apart along all the interstate highways, long distance travel is not problem, and I can usually be recharged in 30 minutes, about the same amount of time it takes be to rest, stretch, and pee.
  #54
Old May 26th 18, 01:51 PM posted to rec.aviation.soaring
Scott Manley[_3_]
The 200 hundred mile max between charges is conservative, ensuring 20% of battery capacity on arrival. With Tesla's nation-wide network of fast chargers located 50-150 miles apart along all the interstate highways, long distance travel is not problem, and I can usually be recharged in 30 minutes, about the same amount of time it takes me to rest, stretch, and pee.
'Sorry if this repeats; I was trying to fix a typo.
  #55
Old May 26th 18, 03:39 PM posted to rec.aviation.soaring
Jonathan St. Cloud
Whoa, it takes you 30 minutes for a pit stop, you might as well be towing a tassel of small children
  #56
Old May 26th 18, 04:16 PM posted to rec.aviation.soaring
Richard Pfiffner[_2_]
What about Reno to Ely to Nephi on the loneliest highway in the US?
  #57
Old May 26th 18, 04:21 PM posted to rec.aviation.soaring
Tango Eight
I think what I like best about my tow vehicle is that it isn't amazing at all. It turns 87 octane into forward motion with tolerable economy and rarely gives trouble.
T8
  #58
Old May 26th 18, 04:35 PM posted to rec.aviation.soaring
Ron Gleason
Tesla charging stations in Nephi next to the JC Mikelson's restaurant on south end of town. So progressive!
  #59
Old May 26th 18, 06:10 PM posted to rec.aviation.soaring
JS[_5_]
Nice, Ron!
Hadn't previously thought of JC Mikelson's as progressive.
The latest vehicle for me works very well, even towing the Duo in the mountains.
32 (US)MPG / 7.35l per 100km average since purchased. But at $30k the GLK250 is my most expensive car.
  #60
Old May 26th 18, 06:20 PM posted to rec.aviation.soaring
son_of_flubber
I've heard that the electric motors of some hybrids can overheat when towing up a long grade. This might explain why the hybrid and non-hybrid version of the same model have different tow ratings.
Not an issue if you live in a flat place.
Uvalde Worlds 2012 - trailer + truck help Tim[_2_] Soaring 0 October 24th 11 04:13 PM
Moving a glider with a U-Haul Truck [email protected] Soaring 11 February 10th 09 08:48 PM
Hauling a trailer by rail or car-carrier truck GM Soaring 11 April 18th 08 09:46 PM
truck + 5th wheel RV + glider trailer ?? Steve Koerner Soaring 16 March 27th 07 03:44 AM
Glider pull-up and ballast M B Soaring 0 September 15th 03 06:29 PM
