iPaq screen reflections - anyone really happy with their solution?
Old December 16th 03, 01:24 PM
Richard Pfiffner
John
A button on the front of the Ipaq can be assigned to 1 Map, this will turn
the terrain on and off and give you the terrain or the white screen.
Menu - edit - touch button on the bottom of the screen - select 1 Map from
the Button function drop down menu.
Richard
www.craggyaero.com
"JohnD" wrote in message
om...
In response to your question Paul:
I 'turn off the color' as a function of the Winpilot program. I don't
remember exactly but I think it is the topographic map display in one
of the setup windows. This feature sounded great when I bought
Winpilot Pro but really isn't necessary if I keep my eyes out of the
cockpit. Viewing the display is significantly improved in B/W vs.
Color.
In regards to comments by others: I do not understand why people are
so concerned about lookout when using a PDA. For me it is a lot easier
to use a PDA than a sectional for most common navigational purposes.
To me is seems all a matter of preparation no matter what you are
using in regards to outside the cockpit awareness. If you are learning
to use one or the other in the air you will not be as aware as you
should be.
Know your PDA's funcionality BEFORE you fly.
"Paul Remde" wrote in message
news:lSvBb.486179$HS4.3733905@attbi_s01...
Hi,
I do finally have a few TEKK cradles for older iPAQs (3100, 3600, 3700).
Paul Remde
Cumulus Soaring Supplies
http://www.cumulus-soaring.com
"Bob Gibbons" wrote in message
On Tue, 09 Dec 2003 14:03:30 -0500, Tony Verhulst
... text deleted ...
Apparently, then, there is more than a little variability in the
Mertins
mounts - quality wise. I was completely satisfied with the fit and
finish of the one I received.
Tony
Same here, I have been very satisified using my Mertins mount for the
past 6 months with my IPAQ 3635. At least at the time I was looking,
the TEKK mounts were not available for the older IPAQ's.
Bob
  #52
Old December 17th 03, 08:59 AM
K.P. Termaat
Hi John,
I use an iPaq 3950 and run WinPilot AV on it. The way I use to improve
readebility of the iPaq is to set a higher contrast and avoid that all of
the landscape gets a color assigned.
With WinPilot running go to 'menu' then 'setting2' and mark elevations to
on. Then press 'edit'. Set Floor level to e.g +1, Color shift to e.g -1 and
Contrast to x2.
I use these settings with good results.
Did not install yet the anti glare film, but better do that I guess.
Karel, NL
"JohnD" schreef in bericht
om...
Color.
should be.
Hi,
Paul Remde
Mertins
Tony
Bob
  #53
Old December 17th 03, 01:26 PM
Richard Pfiffner
Karel
Make sure you get the Clear Touch or Brando (In Europe) Brand Screen
Protectors. The tipical ones you buy in Office Depot etc. do not work.
www.craggyaero.com in the US
http://www.crabb.biz/vl.htm in Europe
Richard
www.craggyaero.com
"K.P. Termaat" wrote in message
Hi John,
and
Contrast to x2.
Karel, NL
om...
Color.
should be.
Hi,
3700).
Paul Remde
Mertins
Tony
Bob
  #54
Old December 17th 03, 02:51 PM
K.P. Termaat
Thanks Richard. I have some "Clear Touch" protectors of BoxWave available
(shipped over from the US at about 9$9,- each). I am not sure this is the
right stuff though.
B.t.w. I use the KEIM iPaq mount in our new Ventus. Quite expensive but high
quality. Works great.
Karel, NL
http://home.wxs.nl/~kpt9
"Richard Pfiffner" schreef in bericht
Karel
Richard
www.craggyaero.com
Hi John,
of
to
and
Contrast to x2.
Karel, NL
om...
Color.
should be.
Hi,
3700).
Paul Remde
Mertins
and
Tony
looking,
Bob
  #55
Old December 17th 03, 06:26 PM
Richard Pfiffner
Those are the ones.
news
right stuff though.
high
Karel, NL
Karel
Richard
www.craggyaero.com
Hi John,
of
to
e.g -1
and
Contrast to x2.
Karel, NL
om...
don't
one
Color.
easier
learning
should be.
Hi,
3700).
Paul Remde
Mertins
and
Tony
for
looking,
Bob
  #56
Old December 19th 03, 05:03 PM
JohnD
I'm glad I got into this thread. Three good tips. Thanks!
Calling all aviation enthusiasts – this is your chance to see two classic RAF movies on the big screen (Hull - Yorkshire). Phillip Rhodes Military Aviation 0 September 7th 04 01:30 PM
Ipaq - GPS_Log Help needed (Long) Steve B Soaring 1 September 27th 03 06:00 AM
iPAQ h2210/h2215 Review Paul Remde Soaring 0 September 3rd 03 03:45 AM
Real World Specs for FS 2004 Paul H. Simulators 16 August 18th 03 09:25 AM
iPaq screen viewability Raphael Warshaw Soaring 7 July 27th 03 06:02 PM
