gel coat
Old October 26th 19, 10:39 PM posted to rec.aviation.soaring
Roy B.
Default gel coat
Per
Do you use the same machine for sanding the primer that you use to remove the gel coat?
ROY
  #52
Old October 27th 19, 12:15 AM posted to rec.aviation.soaring
Default gel coat
On Saturday, October 26, 2019 at 5:39:05 PM UTC-4, Roy B. wrote:
Per
ROY
We use Porter Cable orbital sander with Mirka 23-388-080 adhesive backed discs for most of the removal. Other grits are sometimes useful. Last work is by hand.
Primer/filler is hand shaped. Final finish sand is orbital with finer grit.
Contact directly if you want more info.
UH
  #53
Old October 28th 19, 07:11 AM posted to rec.aviation.soaring
Per Carlin
Default gel coat
I use the same machine for removing gelcote, grinding primer and polishing/waxing both new and old paint. It was an investment of about 500€, i use the machine for all kinds of other grinding jobs than on my glider (furnature, etc) so I consider it as an good investment.
  #54
Old November 1st 19, 07:02 PM posted to rec.aviation.soaring
Charles Longley
Default gel coat
What’s the difference between P80 and 80 grit?
  #55
Old November 1st 19, 08:20 PM posted to rec.aviation.soaring
Dave Nadler
Default gel coat
https://www.grainger.com/content/sup...andpaper-guide
Gel coat removal - is this okay?!? Kevin Christner Soaring 13 July 10th 15 03:44 PM
Gel coat inspection Matt Keast[_2_] Soaring 12 October 26th 07 09:14 PM
Gel Coat Question Gary Emerson Soaring 2 September 12th 07 11:56 AM
Gel Coat for Dummies Ray Lovinggood Soaring 12 December 24th 04 01:12 AM
Gel Coat for Dummies Ray Lovinggood Soaring 2 December 12th 04 08:15 PM
