What is involved regulation wise adding an electric motor to a glider?
Old February 2nd 21, 09:26 PM posted to rec.aviation.soaring
David Scott
Default What is involved regulation wise adding an electric motor to a glider?
I DON'T mean to stir up trouble on this forum with this question, especially being new, but have been wondering about this for some time. I am wondering how feasible it would be to do this with either a homebuilt or experimental glider here in the US?
I figure this has been asked but didn't find any threads on it.
Old February 2nd 21, 11:43 PM posted to rec.aviation.soaring
2G
I assume that you are talking about a glider registered experimental. The major obstacle beyond design, implementation and testing, is to get an AI to sign off on a conditional inspection. I would consult with that AI before you start modifying the glider. You may also have to hire a DAR (designated airworthiness representative). Again, doing this before modifying the glider is highly advisable. Another resource is the EAA. Look up this webinar (https://www.eaa.org/videos):
Webinar- Building an Aircraft - What You Need to Know
You will need to be an EAA member to watch it. Charlie Becker is the presenter and he is presumably building an electric glider, so he could be a great resource.
Tom
Old February 3rd 21, 12:53 AM posted to rec.aviation.soaring
John Sinclair[_5_]
Default What is involved ulation wise adding an electric motor to a glider?
Tom
Probably best to start by reviewing the limitations letter that’s attached to your experimental airworthiness certificate.
Many contain a statement like, “ any major change to this aircraft invalidates this airworthiness certificate”. You will need to request a new airworthiness certificate and prove to the inspector that all is well with your new machine?
JJ
Old February 8th 21, 02:19 PM posted to rec.aviation.soaring
Hank Nixon
Tom
I was not able to find the webinar. Can you give a better guiding link?
Thx
UH
Old February 8th 21, 02:27 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Default What is involved regulation wise adding an electric motor to aglider?
Hank Nixon wrote on 2/8/2021 6:19 AM:
Tom
Thx
UH
This works:
https://www.eaa.org/videos/6226408033001
Old February 8th 21, 03:29 PM posted to rec.aviation.soaring
Hank Nixon
Tom
Thx
UH
This works:
Title for the video?
Thx
UH
Old February 8th 21, 03:46 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
Hank Nixon wrote on 2/8/2021 7:29 AM:
Tom
Thx
UH
This works:
Thx
UH
"Webinar- Building an Aircraft - What You Need to Know"
The link takes me right to it, but it does require logging in as an EAA member to view it.
Old February 3rd 21, 01:09 AM posted to rec.aviation.soaring
David Scott
Thank you for your responses. To be clear I don't have a sailplane but would like to get into the sport and the answers to this question would possibly affect what glider I would get. I am smart enough to get all my ducks in a row before doing anything, and this is the first I have talked about it. From an engineering standpoint, it doesn't look too difficult, navigating the regulations is where I expect the most trouble.
Old February 3rd 21, 02:12 AM posted to rec.aviation.soaring
Mark Mocho
AHHH! The dreaded question, "How hard could it be?" See Dave Nadler's 2020 SSA Convention presentation on motorglider reliability.
https://www.youtube.com/watch?v=R--m0NDR0j8&t=8s
Electric or internal combustion (or jet or warp drive, or....) the problem is lots more complex than it seems. I have been involved with seven jet engine/glider conversions, and everything takes a lot of serious analysis. Hint: start with a glider that already has an engine bay for a fuselage mounted power plant. Or at least check with Emir Sherbi about his Grasshopper electric conversion.
https://www.facebook.com/charlysierragolf/
Old February 3rd 21, 02:26 AM posted to rec.aviation.soaring
David Shelton[_2_]
Thank you for your responses. To be clear I don't have a sailplane but would like to get into the sport and the answers to this question would possibly affect what glider I would get. I am smart enough to get all my ducks in a row before doing anything, and this is the first I have talked about it.. From an engineering standpoint, it doesn't look too difficult, navigating the regulations is where I expect the most trouble.
This would be cost prohibitive to certify; possibly hundred$ of thousands and years of your life. However, there are several ways to accomplish this with experimentals. As you mentioned, you could modify a homebuilt sailplane with an Amateur Built experimental airworthiness certificate. Alternatively, you could put a factory-built sailplane into an experimental category for R&D or Racing and Exhibition.
As somebody mentioned, each experimental airworthiness certificate is issued with a list of operating limitations. Almost always, the operating limitations require you to notify the FAA of any major alterations. The FAA would most likely require an airworthiness inspection, just to make sure you didn't do anything silly. They would also require a flight test period. Usually, this is 40 hours for an amateur built experimental with an uncertified engine/prop.
I've brought numerous aircraft into experimental categories and modified the hell out of them. In every case, the FAA was super easy to work with. I'd recommend that you make an appointment to discuss this with your local FSDO.
A B-52H Nicknamed "Wise Guy" Becomes The Second To Ever Come Back From The Bone Yard [1/5] - note on the panel inside Wise Guy.jpg (1/1) Miloch Aviation Photos 0 May 15th 19 03:46 AM
Pilotless Electric Motor Glider Generates Clean Power Mike Mike Ground Soaring 0 November 27th 11 06:27 PM
Electric motor for hang glider Legend Length Home Built 11 August 27th 09 02:14 AM
electric motor? solarsell Home Built 13 January 12th 07 12:03 AM
Question about adding a second electric AI M Owning 10 January 4th 05 07:29 PM
