#51
![]() T o d d P a t t i s t wrote: I'd say it's the other way around: Lift creates the pressure differential. The pressure differential is caused by the motion of the air as the wing moves through the air. Well how will that work. The air on top is set into motion as a result of the wing pulling on it and the air on bottom is set into motion as a result of the wing pushing on it. How can the motion of the air on the top and bottom of the wing cause a pressure differential? It can't. The pressure differentials are actually caused by the wing pulling and pushing on the air and the air pushing and pulling back. Low pressure does very little to generate lift directly. Example. A ball will suspend in an upward airflow from an air hose. This causes the not to bright people at the NASA web sight to jump to the large and mostly inaccurate conclusion that it is sucked in to the low pressure flow or pushed into it by the higher atmospheric pressure. This is disproved by the fact other shaped object do not seem to be sucked into the flow at all. The shape of the wing, particularly, the upper surface, strongly affects the motion of the air and thereby strongly affects the amount of lift and drag produced. The shape of the wing (the top or bottom) strongly affects the direction of the motion of influenced air. Thereby strongly affecting the amount of lift produced. Example One of the airfoil shapes that generates the most lift at zero degrees angle of attack is the under cambered. It uses shape on top and bottom to divert the low-pressure air. |
#52
Dudley Henriques wrote:
"Hilton" wrote in message ink.net... Peter Duniho wrote: Hilton wrote: Todd's reply to this clearly shows why Roger's statement is wrong. No, it doesn't. See my reply to Todd and Stefan's reply here to understand what we are all talking about. You wrote "Had his definition of lift been correct, he would have been exactly correct." Ummm, OK. But lift is well-defined and it is not defined as the force that opposes weight. So, you can redefine whatever you want, doesn't make it right. Hilton I've always STARTED an explanation of lift by presenting it initially as the aerodynamic force that opposes the relative wind, NOT the force that opposes gravity or weight. (That comes later :-))) Dudley Henriques Lift opposes the Relative Wind? How does lift (and I assume you are talking wing lift here since you mention gravity/weight) *oppose* the relative wind? What do you mean when you use the word "oppose"? Or were you speaking of prop lift? -- Saville Replicas of 15th-19th century nautical navigational instruments: http://home.comcast.net/~saville/backstaffhome.html Restoration of my 82 year old Herreshoff S-Boat sailboat: http://home.comcast.net/~saville/SBOATrestore.htm Steambending FAQ with photos: http://home.comcast.net/~saville/Steambend.htm |
#53
![]() "gregg" wrote in message ... Dudley Henriques wrote: "Hilton" wrote in message ink.net... Peter Duniho wrote: Hilton wrote: Todd's reply to this clearly shows why Roger's statement is wrong. No, it doesn't. See my reply to Todd and Stefan's reply here to understand what we are all talking about. You wrote "Had his definition of lift been correct, he would have been exactly correct." Ummm, OK. But lift is well-defined and it is not defined as the force that opposes weight. So, you can redefine whatever you want, doesn't make it right. Hilton I've always STARTED an explanation of lift by presenting it initially as the aerodynamic force that opposes the relative wind, NOT the force that opposes gravity or weight. (That comes later :-))) Dudley Henriques Lift opposes the Relative Wind? This should read "Lift is the component of aerodynamic force perpendicular to the relative wind.", and not "opposes". My error in presentation. DH |
#54
Dudley,
As usual, excellent post - I totally agree. Hilton |
#55
Roger Long wrote:
The distinction is really a thought convenience to help us talk about what is going on and not a real physical difference. Lift is really drag directed upwards. I have absolutely no idea what you mean. I have never seen lift described as "drag directed upwards". Please explain. Hilton |
#56
Peter,
Todd wrote: Pete, in your reply above, you did the same thing Roger did, (and what I often do too,) you equated the vertical component of aerodynamic force to "lift." [zap] The real issue here is whether lift changes according to airspeed. The generic idea of lift (as in, the force that keeps airplanes aloft) versus the specific physics definition of lift is inconsequential in that context, and not one I feel is worth nitpicking over. It is *exactly* worth discussing and it is not nitpicking. Lift as DEFINED is completely different to the force pointing upwards and there are many examples where they all completely different; some example: spins, steep turns, a plane climbing vertically, a flat spin, the F-18 slow pass... OK, quick question: how much 'lift' (your definition) is an aircraft producing in a 45 degree bank? Equal to the weight? If so, why does my stall speed increase? Nitpicking? Well this nitpicking kills a lot of pilots including very experienced ones. How would you explain to a pilot that even though lift equals weight in a steep turn (your definition), the stall speed increases? Hilton |
#57
k.net... It is *exactly* worth discussing and it is not nitpicking. Not in this context. Still, you have demonstrated you are happy to continue to do so, so please...knock yourself out. |
#58
The hardest thing about teaching someone about lift and drag in trying
to unlearn them the misconceptions they have already learned. The Nasa. Gov web pages are a poster boy for this misconception. They define lift and drag and thrust with narrow-minded characterizations that do not differentiate one from the other. Example lift is THE force that supports the aircraft in flight. Drag opposes the forward motion of an aircraft thru the air. Thrust causes the forward motion of the aircraft. They exclusively refer to drag as resistance force when the major use of lift in aeronautics is to resist gravity. How stupid do they think people are? I am a member in model airplane club whose members are made up mostly by retired pilots (commercial and private). I make it a point to ask any pilot I meet what is the difference between lift and drag and I have never Got a correct answer except for I don't know. I hate it when some one says it's just a matter of semantics. Words are useless without meaning and the words that have simple and accurate definitions are the most useful. Glider pilots look for lift when they fly their craft. But the upward aerodynamic force they are looking for to accelerate their craft upward as a result of this lift is called drag. I like to discuss aerodynamics with people of authority. Please do not think I am picking on you because I think you are one of the smarter people in this group. I find it hard to argue with you because I agree with so much of what you say. I sound like I am on a soap box don't I? |
#59
![]() "Dudley Henriques" dhenriques@noware .net wrote in message hlink.net... snip This should read "Lift is the component of aerodynamic force perpendicular to the relative wind.", and not "opposes". My error in presentation. DH Hello Dudley, Nicely stated, Are we not really looking at two different concepts of lift here? A - The aerodynamic resultant reaction of an airfoil pulling air downward. B - The flight physics teaching concept that an aircraft (in unaccelerated flight) must generate a force (lift, thrust ,drag) that balances its (apparent) weight. ISTM that A is the description of the dynamics of motion through a fluid and B is the description of the dynamics of motion of a mass. The fact that the mass is moving through a fluid makes it a complex problem that is straining our definitions, and perhaps is more of a problem of conceptual semantics. In regards to "not AGAIN", here in Canada we have an ongoing debate on Quebec nationalism/referendum that we wags refer to as the "neverendum". regards, |
#60
![]() "Ash Wyllie" wrote in message ... snip Lift = Cl(AOA) * Area * V^2 snip I believe this is more correctly stated as Lift = Cl(AOA and some other stuff including shape) * Area * P/2 * V^2 |
Lift Query | Avril Poisson | General Aviation | 8 | April 21st 05 07:50 PM |
Tamed by the Tailwheel | [email protected] | Piloting | 84 | January 18th 05 04:08 PM |
New theory of flight released Sept 2004 | Mark Oliver | Piloting | 70 | October 10th 04 10:50 PM |
Lift and Angle of Attack | Peter Duniho | Simulators | 9 | October 2nd 03 10:55 PM |
Across Nevada and Part Way Back (long) | Marry Daniel or David Grah | Soaring | 18 | July 30th 03 08:52 PM |
