#51
Bill writes:
Contrary to the static you are getting, you asking exactly the right question. Those who don't investigate such things run into stuff. Safety first. A great reference to how the procedures are constructed is Eckalbar "IFR A Structured Approach" chapter 9. It discuses what "standard" is. How far is it assumed that you climb straight ahead when departing? It's all covered. I was hoping it would be in the books I can download for free from the FAA, but I haven't found much, and I'm at least as confused now as I was when I asked the question. For fun, look at the Sand Point ID approach plate. Can you depart this place safely with a 900' ceiling in your Bonanza? How would you do it? I found the airport, but I'm not sure what you mean by ID approach plate. There are a couple of approaches listed. |
#52
Viperdoc wrote:
He doesn't have a congressman- he lost his job in the States, and now lives hand to mouth in Paris, where he (not surprisingly) also can't find or hold a regular job. I knew that, but forgot. Maybe the U.S. Ambassador to France could help him out. Big Bear, California Airport is a high-profile location for U.S.-Franco relationships. ;-) |
#53
On Jan 15, 6:20*pm, Sam Spade wrote:
Robert M. Gary wrote: . The procedure has to be published for your runway. So in our sim guys case he could have made up his own departure because the runway he was using does not have a published departure procedure. To my knowledge there are no non-towered airports that prohibit IFR departures from a certain runway. -Robert Sure there are, but for Part 91 it is iffy. *If I am operating Part 135 IFR out of Big Bear, I better damn well not use Runway 26 unless I get a VFR climb clearance from center. Part 135 is different. Are you aware of an non-towered airport that prohibits IFR depatures from a given runway? Can you post the airport identifier? -Robert |
#54
On Jan 15, 6:20 pm, Sam Spade wrote: Robert M. Gary wrote: . The procedure has to be published for your runway. So in our sim guys case he could have made up his own departure because the runway he was using does not have a published departure procedure. To my knowledge there are no non-towered airports that prohibit IFR departures from a certain runway. -Robert Sure there are, but for Part 91 it is iffy. If I am operating Part 135 IFR out of Big Bear, I better damn well not use Runway 26 unless I get a VFR climb clearance from center. Part 135 is different. Are you aware of an non-towered airport that prohibits IFR depatures from a given runway? Can you post the airport identifier? -Robert The airport we are discussing is good enough. It doesn't have a tower, it is an IFR airport, and takeoff minimums are NA for Runway 26. Without takeoff minimums there cannot be a diverse departure area or ODP. Now, can you roll your own ODP for Runway 26 as a 91-only operator? I think that is something only FAA legal could answer with certainty. |
#55
Bill wrote:
Contrary to the static you are getting, you asking exactly the right question. Those who don't investigate such things run into stuff. A great reference to how the procedures are constructed is Eckalbar "IFR A Structured Approach" chapter 9. It discuses what "standard" is. How far is it assumed that you climb straight ahead when departing? It's all covered. For fun, look at the Sand Point ID approach plate. Can you depart this place safely with a 900' ceiling in your Bonanza? How would you do it? Bill Hale BPPP instructor Most light aircraft don't have sufficent performance to use standard takeoff minimums at Sandpoint. |
#56
![]() This is not my understanding. According to old Wally Roberts, who once published great IFR articles for the IFR Refresher, the TERPS guys are required to evaluate departures for every runway for any airport for which an IAP is published, and if obstacles penetrate the 200:1 plane, then an ODP is required. Therefore if a pilot follows the 200:1 plane in all cases where there is an IAP published, and no ODP, he is assured of obstacle clearance (unless the runway is designated NA). There is no need for published IFR Takeoff Minimums for this to apply, as I understand it. This has always been my understanding. If there is a source that proves this to be incorrect, I would appreciate being so enlightened. On Tue, 15 Jan 2008 06:59:34 -0800, Sam Spade wrote: wrote: I believe the rule is that if there is a departure procedure published, fly the departure procedure. If there is an approach chart published, but but no departure procedure, the rule is no turns before 400' AGL, and maintain 200 FPNM and you will be clear of obstructions. Known as a diverse departure area as per the AIM No approach plate, you are on your own. Does this not cover everything? No. The runway has to have published IFR takeoff minimums AND no ODP for you to make a diverse departure. |
#57
#58
On Jan 16, 8:43*am, Sam Spade wrote:
Robert M. Gary wrote: On Jan 15, 6:20 pm, Sam Spade wrote: Robert M. Gary wrote: . The procedure has to be published for your runway. So in our sim guys case he could have made up his own departure because the runway he was using does not have a published departure procedure. To my knowledge there are no non-towered airports that prohibit IFR departures from a certain runway. -Robert Sure there are, but for Part 91 it is iffy. *If I am operating Part 135 IFR out of Big Bear, I better damn well not use Runway 26 unless I get a VFR climb clearance from center. Part 135 is different. Are you aware of an non-towered airport that prohibits IFR depatures from a given runway? Can you post the airport identifier? -Robert The airport we are discussing is good enough. *It doesn't have a tower, it is an IFR airport, and takeoff minimums are NA for Runway 26. Without takeoff minimums there cannot be a diverse departure area or ODP. *Now, can you roll your own ODP for Runway 26 as a 91-only operator? *I think that is something only FAA legal could answer with certainty.- Hide quoted text - But there is no requirement for part 91 to have published takeoff mins. Many of us depart IFR from airports that do not have terminal procedures published of any kind. There is no restrictions on part 91 to have an ODP. Note that 91.175 (f) (depature mins) says "This paragraph applies to persons operating an aircraft under part 121, 125, 129, or 135 of this chapter.". So the only requirement under part 91 is what you do not hit anything. -Robert |
#59
On Jan 16, 8:43 am, Sam Spade wrote: Robert M. Gary wrote: On Jan 15, 6:20 pm, Sam Spade wrote: Robert M. Gary wrote: . The procedure has to be published for your runway. So in our sim guys case he could have made up his own departure because the runway he was using does not have a published departure procedure. To my knowledge there are no non-towered airports that prohibit IFR departures from a certain runway. -Robert Sure there are, but for Part 91 it is iffy. If I am operating Part 135 IFR out of Big Bear, I better damn well not use Runway 26 unless I get a VFR climb clearance from center. Part 135 is different. Are you aware of an non-towered airport that prohibits IFR depatures from a given runway? Can you post the airport identifier? -Robert The airport we are discussing is good enough. It doesn't have a tower, it is an IFR airport, and takeoff minimums are NA for Runway 26. Without takeoff minimums there cannot be a diverse departure area or ODP. Now, can you roll your own ODP for Runway 26 as a 91-only operator? I think that is something only FAA legal could answer with certainty.- Hide quoted text - But there is no requirement for part 91 to have published takeoff mins. Many of us depart IFR from airports that do not have terminal procedures published of any kind. There is no restrictions on part 91 to have an ODP. Note that 91.175 (f) (depature mins) says "This paragraph applies to persons operating an aircraft under part 121, 125, 129, or 135 of this chapter.". So the only requirement under part 91 is what you do not hit anything. -Robert I agree that Part 91 can roll your own at VFR airports. I also agree that takeoff minimums do not legally apply to Part 91 only. My question is about an IFR airport where takeoff minimums are denied altogther for a particular runway. I think the "hazards of litigation" exist for that circumstance. It certainly is not clear cut, of course, but if something goes wrong it would become a factor. |
#60
On Jan 16, 3:45*pm, Sam Spade wrote:
Robert M. Gary wrote: I agree that Part 91 can roll your own at VFR airports. *I also agree that takeoff minimums do not legally apply to Part 91 only. *My question is about an IFR airport where takeoff minimums are denied altogther for a particular runway. *I think the "hazards of litigation" exist for that circumstance. It certainly is not clear cut, of course, but if something goes wrong it would become a factor.- Hide quoted text - Possible but I know of no precedent set where a court held a pilot to 135 standards when operating under 91. Even for part 135 the procedure does not say you cannot take off from runway 20, it just says that the given ODP is not authorized for runway 20. -Robert |
Final Glide Calculation over Obstacle | [email protected] | Soaring | 3 | February 7th 07 04:49 PM |
How to adhere to this obstacle departure procedure? | Peter R. | Instrument Flight Rules | 38 | April 25th 05 09:00 PM |
Garmin 196 & obstacle database. | max | Instrument Flight Rules | 11 | March 16th 05 08:51 AM |
Obstacle Clearance Altitude / Height | Tim | Instrument Flight Rules | 2 | November 21st 04 10:33 AM |
Notes on NACO Obstacle Departure Procedures | John Clonts | Instrument Flight Rules | 1 | July 15th 04 10:20 PM |
