Obstacle Clearance Altitude / Height
Old November 12th 04, 09:20 AM
Tim
Default Obstacle Clearance Altitude / Height
Hi,
Could anyone give me a good explanation for OCA/OCH. I know it has
something to do with the minimums of ILS-approaches and it should
always be lower than or equal to the DA/DH. I assume it provides you
with a certain obstacle clearance at DA/DH. But how is it
determined????
Best regards,
Tim
Old November 12th 04, 09:55 PM
Julian Scarfe
"Tim" wrote in message
om...
Hi,
determined????
[ICAO version, YMMV, particularly if you use different sized miles.]
Obstacle clearance altitude OCH is the height on an IAP with the minimum
permitted clearance above obstacles on the final approach. It does not take
account the limitations associated with the navaid (system minimum). Thus
the DH or MDH is the higher of the OCH or the system minimum. The OCA is
obviously the altitude corresponding to the OCH.
For non-precision approaches the OCH is the height of the highest obstacle
on the final approach segment plus a speed-dependent margin. Precision
approach OCHs are more complex, I think. Most Cat I ILSs are limited by the
system minimum of 200 ft rather than the OCH.
Julian Scarfe
Old November 21st 04, 10:33 AM
Tim
Thanks a lot.
Happy landings,
Tim
Report Leaving Assigned Altitude? John Clonts Instrument Flight Rules 81 March 20th 04 02:34 PM
Q about lost comms on weird clearance Paul Tomblin Instrument Flight Rules 34 February 2nd 04 09:11 PM
GPS Altitude with WAAS Phil Verghese Instrument Flight Rules 42 October 5th 03 12:39 AM
Picking up a Clearance Airborne Brad Z Instrument Flight Rules 30 August 29th 03 01:31 AM
