#51
In rec.aviation.soaring Larry Dighera wrote:
I wonder if those power consumption figures include the heater in the encoder. Perhaps it's a good idea to require equipping all gliders with transponders after all. :-( Keep in mind that the recommendation is not to require equipping all gliders with transponders. It's to remove the exemption given to gliders and give them the same rules as powered aircraft with electrical systems, to require them to have a transponder for flight into a mode C veil or above 10,000ft. In some places this would do almost nothing; where I fly we are outside the veil (barely) and hit 10,000ft maybe a couple of times a year. In other places it would severely limit activity for gliders without transponders to the extent that it would essentially be required. The power requirements are a secondary concern, the primary concern is cost. Power requirements of course influence cost. There are gliders with transponders out there, so obviously it can be done. But there are a lot of gliders for which the cost of a transponder installation would be a sizable fraction of the total value of the aircraft, and this change could put their owners in a very bad spot. -- Michael Ash Rogue Amoeba Software |
#52
In article
Larry Dighera quotes the NTSB report: Before the collision, the Hawker had been descending toward RNO on a stable northwest heading for several miles, and the glider was in a 30 [degree], left-banked, spiraling climb. . . . Because of the lack of radar data for the glider's flight, it was not possible to determine at which points in each flight each aircraft may have been in the other's available field of view. Although Federal Aviation Regulations (FARs) require all pilots to maintain vigilance to see and avoid other aircraft (this includes pilots of flights operated under IFR, when visibility permits), a number of factors that can diminish the effectiveness of the see-and-avoid principle were evident in this accident. For example, the high-speed closure rate of the Hawker as it approached the glider would have given the glider pilot only limited time to see and avoid the jet. Likewise, the closure rate would have limited the time that the Hawker crew had to detect the glider, and the slim design of the glider would have made it difficult for the Hawker crew to see it. Am I the only one to question this? If the glider was in a 30 degree left banked spiraling climb, we should be able to predict where it was for several minutes prior to the collision --- it was spiraling in the thermal, moving upwards. His nominal thermal airspeed can be looked up for the model of glider; the actual value, and the rate of climb can be determined from the glider pilot. Since the jet was flying in a straight line (rate of descent, if any can be found from radar data), it should be fairly easy to figure where the glider was in the field of view of the jet pilots. As the glider was probably moving about 50 kt, and the jet was reported at 300 kt, the glider would have been within no more than about 9 degrees from directly ahead of the jet. The glider didn't jump in front of the jet. I guess the NTSB did not want to do this calculation. Alan |
#53
In article "BT" writes:
But not all aircraft are required to have a transponder in all categories of airspace... Sure.. all AIRPLANES with electrical generating systems should have a transponder, but not all AIRCRAFT have electrical generating systems. Even ones built today, sort of a Catch-22. Quite true. Aside from things like Balloons, even things like hang gliders and paragliders fly. Some quick searching tells that hang gliders get up above 10,000 feet as well. Where does one mount the transponder and battery on a hang glider or paraglider? Alan |
#54
WingFlaps wrote:
Only perfectly flat surfaces are more stealthy because they bounce the radar away from the source, whereas a convex surface always bounces some energy back (falling rapidly with distance). A concave surface starts to act as a retroreflector. I am sure that the nicely curved body of a high performance glass glider has a much lower radar cross section than any aluminium GA aircraft. It's not stealth but fiberglass is so transparent it's used for radomes. But, gliders have been made with carbon fiber for decades now, and even fiberglass gliders have metal parts. Do pilots in your area find ATC (typically "approach" ATC) unable to detect ANY of your gliders? -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#55
Locally, approach radar has no trouble finding our transponderless gliders (when we call them), tracking them, and warning/diverting other traffic. We generally do this within 15-20 miles of our towered airports. It works well for us, given the altitudes we fly at. Thank you for this information. Would the gliders you mention be of glass-fiber, aluminum, or carbon-fiber composite construction? I would expect a glass ship with few metal parts to be rather transparent to radar. In my local area, some glider are fiberglass with some carbon, like a spar (like a PIK 20 E), or are entirely carbon. All are motorgliders. At Ephrata, WA, where most of the state's gliders fly, the construction varies from fiberglass through carbon. Only a few of the gliders are motorgliders. I expect materials to make a difference, but it's hard to tell from the anecdotal information. The biggest difference seems to be making that radio call to ATC. It's worth contacting ATC in your area to see if they are willing and able to do the same for you. It's not practical everywhere, but it's cheap and easy if it is. I'm not so much concerned about my personal situation as I am about the FAA rescinding the glider exemption from FARs that require transponder use. If we can give the FAA some guidance on this issue, the outcome will likely be more acceptable, than if the draft their NPRM without pilot input, IMO. My thought is pilots, ATC, and FAA might discover contacting ATC achieves enough of what everyone wants, that a complete revocation of our exemption might be avoided. To make the case, we need to try the ATC system to determine this. A problem the reflector can not solve is TCAS will still not detect the glider. This might be deal-breaker for the FAA/NTSB people. I agree. But rescinding the glider exemption from FARs requiring transponder use won't address that issue with powered aircraft that lack an electrical system either. True. I don't know where that is going, but maybe if a jet runs into a Champ, they'll get their exemption removed, too. Or maybe they are next to lose it, regardless. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#56
![]() "Peter Dohm" wrote ... "Big John" wrote ... Does ATC use skin paint any more???? Yes. The story I heard was that they were about to do away with it--but some sort of incident occured in the third quarter of '01 and they changed their minds... Yeah,... I can just see the FAA/DOT b-crats spending a few years trying to schmooze the congress criters on how much money can be saved if they get rid of those pesky & troublesome primary radar sites, then 911 happens the whole ADS-B sales job goes back to the drawing board. |
#57
Alan wrote:
Likewise, the closure rate would have limited the time that the Hawker crew had to detect the glider, and the slim design of the glider would have made it difficult for the Hawker crew to see it. Am I the only one to question this? If the glider was in a 30 degree left banked spiraling climb, we should be able to predict where it was for several minutes prior to the collision --- it was spiraling in the thermal, moving upwards. His nominal thermal airspeed can be looked up for the model of glider; the actual value, and the rate of climb can be determined from the glider pilot. Since the jet was flying in a straight line (rate of descent, if any can be found from radar data), it should be fairly easy to figure where the glider was in the field of view of the jet pilots. As the glider was probably moving about 50 kt, and the jet was reported at 300 kt, the glider would have been within no more than about 9 degrees from directly ahead of the jet. The glider didn't jump in front of the jet. I guess the NTSB did not want to do this calculation. Lets cut the NTSB (and the Hawker pilots) some slack: sometimes *I* can't spot a glider that is only a mile or two away, even though we're talking to each other, and sometimes, he doesn't see me either! And we aren't closing at 300 knots, maybe not closing at all. It's not just gliders, but the small GA aircraft, too. I'm much more aware of this since I got a Zaon MRX, because I sometimes get an alert but still don't find the airplane. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#58
You are correct. Here's another with even less power consumption: http://www.sportflyingshop.com/Avion...ansponder.html Microair T2000 Transponder, $1,825 Wiring harness for T2000, $149 Ameri-King AK-350 Blind Encoder, $179 Power input: .25 amps @ 27.50 volts; .4 amps @ 13.75 volts TX, 80 mA RX I wonder if those power consumption figures include the heater in the encoder. No, that figure doesn't include the encoder. The heater can be 200-300 ma when it's fully on, but the typical unit won't be fully on unless it's "really" cold outside. In my glider, that seems to be lower than ~10 deg F - winter wave flying for me. There are encoders with less low temperature draw, but they tend to be expensive. -- Eric Greenwell - Washington State, USA * Change "netto" to "net" to email me directly * Updated! "Transponders in Sailplanes" http://tinyurl.com/y739x4 * New Jan '08 - sections on Mode S, TPAS, ADS-B, Flarm, more * "A Guide to Self-launching Sailplane Operation" at www.motorglider.org |
#59
In article dSuRj.7182$r12.6971@trndny03,
Eric Greenwell wrote: But, gliders have been made with carbon fiber for decades now, and even fiberglass gliders have metal parts. Is carbon more reflective than glass? |
#60
On Tue, 29 Apr 2008 00:48:35 +0000 (UTC),
(Alan) wrote in : Where does one mount the transponder and battery on a hang glider or paraglider? Not to worry. The EAA is workin' on it: :-) http://www.eaa.org/news/2008/2008-04-26_symposium.asp EAA Asks FAA to Authorize Electric Motors in Ultralights and Light-Sport Aircraft Announcement at Electric Aircraft Symposium draws applause April 26, 2008 — In an effort to gain attention and support for electric aircraft innovation and to help advance efforts to bring affordable electric aircraft to recreational aviators, EAA at today’s CAFE Foundation 2008 Electric Aircraft Symposium announced a significant advocacy measure. As the final speaker on the Symposium agenda, EAA Lifetime Member Craig Willan wrapped up the one-day event in San Francisco announcing that EAA this week filed a request to the FAA for regulatory exemptions that would allow the use of electric motors in ultralight and light-sport aircraft. “The announcement drew enthusiastic applause,” Willan reported shortly after the event’s conclusion. “After a full day’s in-depth exploration of the cutting-edge work being done, the group was already energized by the promising developments in the science and engineering arenas. When I announced at the end of the day EAA’s action in the regulatory arena aimed at allowing the application of this technology, it was like an additional shot of adrenaline,” he said. “I also informed the group that this is only a first step. I’m participating on an EAA task force charged with further facilitating progress in the use of electric energy to power aircraft,” he said. “The EAA community is committed to this direction. More announcements are coming.” EAA’s petition to the FAA specifically proposes specifications for battery-pa... |
Gliders, transponders, and MOAs | Greg Arnold | Soaring | 2 | May 26th 06 05:13 PM |
Cessna forced down by the Feds | C J Campbell | Piloting | 51 | February 8th 05 01:29 PM |
U$ Says Prisoners Beaten With Hand-Held Radios, NOT Clock Radios! *snicker* | JStONGE123 | Military Aviation | 1 | May 11th 04 06:22 AM |
Transponders and Radios - USA | Ray Lovinggood | Soaring | 1 | February 27th 04 06:10 PM |
Transponders, Radios and other avionics procurement questions | Corky Scott | Home Built | 5 | July 2nd 03 11:27 PM |
