#61
Simple, just don't descend until you can glide to the Runway. Give
yourself at least a 1000' feet to react if you need to put yourself in a situation where a landing at a location other than the runway is your only option. Brian CFIIG/ASEL |
#62
Ok what kind of aircraft do most of us fly?
Aeronca 7AC with a Wood prop will stop fairly easily if you slow down below 50 mph. C-150/C-152 Need to hold on the edge of a Stalll for a about 30 seconds C-172 Need to hold on the edge of a Stall for a about 30 seconds C-182 Have never been able to stop the prop PA28-151 Need to hold on the edge of a Stall for a about 30 seconds PA38-112 Need to hold on the edge of a Stall for a about 30 seconds I have yet to fly and airplane where at the best glide speed the propeller will not continue to windmill. YMMV. Brian CFIIG/ASEL |
#63
Depends on the airplane, most small trainers the smaller prop and low
approach speeds the drag from a windmilling prop is hardly noticable from an idling engine. On bigger airplanes the larger prop, Bigger engine (develops more HP even at idle) and the higher approach speed( Drag goes up by the Square of the speed) the difference between windmilling and idling can be more noticable (Especially if the idle speed on the engine is set to high) Brian CFIIG/ASEL |
#64
I can think of two at my airport in the past 5 years. A C-182 landed
short in the power lines because the engine did not respond when he added power.. And a Piper Cherokee that ran out of fuel on final and landed in a feild short of the runway this summer.. Brian CFIIG/ASEL |
#65
![]() Brian wrote: Let's see: 1/4 @ 200 ft that would be: 1/4 mile = 6040/4 = 1510 ft 1510/200 = 7.55 L/D required. OK maybe flaps up and best L/D Speed a C-172 might have 7.5 L/D ratio. At 60 knots, a Cessna 172 demonstrates a 12.2:1 glide ratio with flaps up. Plenty of margin if you were in that configuration. http://www.swaviator.com/html/issueAM00/basicsAM00.html In my Maule, I will probably have 24 degrees of flaps down and be doing 65-70 mph. I will cover that quarter mile in less than 15 seconds, and it will take me a few to react and drop that Johnson bar. Once I do, though, my rate of descent will be a bit less than 500 fpm. Judging from the experiment in the above article, the ROD of a 172 at 60 knots is also about that. Again, plenty of margin. George Patterson The desire for safety stands against every great and noble enterprise. |
#66
![]() george wrote: The engine quits the prop stops ! This will only happen if the engine seizes. As Hilton stated, usually you must slow to nearly stall speed to stop the prop. One of the AOPA Pilot authors ran some empirical experiments with this and determined that, if you're below about 6,000' AGL, you will not gain enough efficiency by stopping the prop to make up for the distance lost by slowing down below best glide speed. As Hilton also points out, there could be times when there are more important considerations than glide distance. George Patterson The desire for safety stands against every great and noble enterprise. |
#67
![]() G.R. Patterson III wrote: george wrote: The engine quits the prop stops ! This will only happen if the engine seizes. As Hilton stated, usually you must slow to nearly stall speed to stop the prop. One of the AOPA Pilot authors ran some empirical experiments with this and determined that, if you're below about 6,000' AGL, you will not gain enough efficiency by stopping the prop to make up for the distance lost by slowing down below best glide speed. As Hilton also points out, there could be times when there are more important considerations than glide distance. Thank you . You get the prize :-) Some of the posts had me looking for the feathering lever in the C152 (That is a tongue in cheek remark) |
#68
On 24 Jan 2005 06:27:52 -0800, "Brian" wrote:
I have yet to fly and airplane where at the best glide speed the propeller will not continue to windmill. YMMV. Not a definitive answer, of course, since the pilot could have brought the nose up to 40 mph or so, but in this piccy the prop isn't turning (yet!): http://www.pipercubforum.com/handprop.htm (Or at least I *hope* it's not turning!) -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#69
On 24 Jan 2005 06:02:38 -0800, "Brian" wrote:
A much better technique is to fly the extending downwind, base and maybe even part of final at a 1000' AGL. Once within gliding range, then reduce power. At least at 1000' feet you should have 20-30 seconds to consider you options of where you are going to land should the engine fail. At 300' your going to hit what ever is directly in front of you. Well, that puts you at a different altitude than everyone else in the pattern (especially at 7B3 where p.a. is 800 ft AGL ![]() the second sentence correctly, you're not within gliding range until you're on final, so if your engine quits you will go plop. Why look around in search of a landing place when you've got an airport in sight? Why not fly the pattern so that you can glide to the runway from downwind or base? (As posted, if I knew how to fly a 45 within gliding distance, I'd do that too! The only things around 7B3 are houses, trees, and a one-track railroad bed.) -- all the best, Dan Ford email (put Cubdriver in subject line) Warbird's Forum: www.warbirdforum.com Piper Cub Forum: www.pipercubforum.com the blog: www.danford.net |
#70
Nobody has mentioned that one of the reasons to avoid aiming for the numbers
and to plan your touchdown point to be at the 1/3 point of a std 3000' training rwy is to allow a margin for an engine failure on short final. Boy, I've been flying for a looooong time, and I never heard that one before! Strikes me as developing one bad habit to correct for another bad habit. If you fly a proper approach, you'll make the runway whether or not the engine keeps running. Unless you're landing at a place like Dulles, where touching down on the numbers means a hell of along taxi, it's good practice to hit the numbers. Someday it may save your hide. vince norris |
"Cleared Straight-In Runway X; Report Y Miles Final" | Jim Cummiskey | Piloting | 86 | August 16th 04 06:23 PM |
Diesel engine | Bryan | Home Built | 41 | May 1st 04 07:23 PM |
Night engine failure in Boston | Dan Luke | Piloting | 8 | February 13th 04 05:33 AM |
Real stats on engine failures? | Captain Wubba | Piloting | 127 | December 8th 03 04:09 PM |
Corky's engine choice | Corky Scott | Home Built | 39 | August 8th 03 04:29 AM |
