#61
In article et,
"Steven P. McNicoll" wrote: Why can't the incoming pilot see you and go around? Is the threshold always visible to the pilot for all aircraft when in normal landing configuration? -- Bob Noel no one likes an educated mule |
#62
![]() "Bob Noel" wrote in message ... Is the threshold always visible to the pilot for all aircraft when in normal landing configuration? In conditions where a pilot in position could see an approaching aircraft, except for very short final, yes. |
#63
In article et,
"Steven P. McNicoll" wrote: Is the threshold always visible to the pilot for all aircraft when in normal landing configuration? In conditions where a pilot in position could see an approaching aircraft, except for very short final, yes. Then why did one airliner land on top of a commuter (iirc) a number of years ago? -- Bob Noel no one likes an educated mule |
#64
![]() "Bob Noel" wrote in message ... Then why did one airliner land on top of a commuter (iirc) a number of years ago? Were the conditions such that a pilot in position could see an approaching aircraft? |
#65
In article . net,
"Steven P. McNicoll" wrote: Then why did one airliner land on top of a commuter (iirc) a number of years ago? Were the conditions such that a pilot in position could see an approaching aircraft? My understanding is that the airport was VFR at at the time. -- Bob Noel no one likes an educated mule |
#66
![]() "Bob Noel" wrote in message ... My understanding is that the airport was VFR at at the time. Let me know when you're sure. |
#67
Steven P. McNicoll wrote:
Let me know when you're sure. http://www.ntsb.gov/ntsb/GenPDF.asp?...1MA018A&rpt=fa http://www.ntsb.gov/ntsb/GenPDF.asp?...1MA018A&rpt=fi 16 miles reported visibility, 30000 scattered. That should qualify as VFR for most people. Ben Hallert PP-ASEL |
#68
![]() "Ben Hallert" wrote in message ups.com... http://www.ntsb.gov/ntsb/GenPDF.asp?...1MA018A&rpt=fa http://www.ntsb.gov/ntsb/GenPDF.asp?...1MA018A&rpt=fi 16 miles reported visibility, 30000 scattered. That should qualify as VFR for most people. Yup, but Bob's question was, "Is the threshold always visible to the pilot for all aircraft when in normal landing configuration?" The aircraft in position on the runway was an intersection departure. The question remains, if neither pilot aboard the landing 737 could see the Fairchild 227 on the runway, why should we believe the crew of the Fairchild 227 could have seen the incoming 737 if they had been cocked some thirty degrees or so from the runway centerline? |
#69
Hi Steve,
My post was in response to the following exchange: Bob Noel: My understanding is that the airport was VFR at at the time. Steven P. McNicoll: Let me know when you're sure. Best regards, Ben Hallert PP-ASEL |
#70
Fairchild 227 on the runway, why should we believe the crew of the Fairchild 227 could have seen the incoming 737 if they had been cocked some thirty degrees or so from the runway centerline? The accident happened shortly before sunset on runway 24. So the pilots on the 737 would have been looking nearly into the sun whereas a pilot looking back would be seeing a landing light in a darkening sky. But regardless of the details of this particular incident, why not have the redundancy of having both aircraft crews in a position where they could observe and possibly avert an imminent collision? |
Mini-500 Accident Analysis | Dennis Fetters | Rotorcraft | 16 | September 3rd 05 11:35 AM |
Parachute fails to save SR-22 | Capt.Doug | Piloting | 72 | February 10th 05 05:14 AM |
Position and Hold at uncontrolled field | dave | Piloting | 42 | February 26th 04 01:25 AM |
Hold "as published"? | John Clonts | Instrument Flight Rules | 83 | November 13th 03 03:19 PM |
USAF = US Amphetamine Fools | RT | Military Aviation | 104 | September 25th 03 03:17 PM |
