Learning from an owner annual
Old May 14th 06, 07:11 AM posted to rec.aviation.piloting,rec.aviation.owning
Default Learning from an owner annual
After 6 years of Mooney ownership I'm doing my first owner assisted
annual. Most of my previous annuals have been done by factory service
centers. I'm quite a good wrench around cars so this experience is
mostly about me learning the standards & practices of aircraft work.
I'm amazed by a couple things...
1) The number of things I found that were not done that I'd paid to
have done at previous annuals.
2) The number of things done wrong (like no cotter key in the wheel).
3) The amount of work an annual really requires. It took me 6 hours
just to remove all the inspection panels (including drilling out
several dozen screws). Lubing the 150 lube points wont go too quick
either.
Its also interesting to me how many things are safety wired while other
things (that seem more important) are not. Brake calapers are safety
wired but fuel lines are not, etc. Its quite depressing to see my plane
in so many pieces. I've also discovered that its extreamly irritating
that the aircraft parts places are closed on weekends.
I would highly recommend this experience to any aircraft owner who is
comfortable with a wrench.
-Robert
Old May 14th 06, 07:48 AM posted to rec.aviation.piloting,rec.aviation.owning
Good maintenance takes time and time equals money. There is
too much poor maintenance, sometimes because the aircraft
owner just doesn't have the money to do the work and
sometimes because the shop, trying to keep cost down cuts
corners. All aircraft owners should have the basic library
of the shop manuals and FAA regs in parts 43 and 91. The
FAA manual 43.13 [latest edition and all parts] as well as
some of the mechanics handbooks that are on the commercial
market will help the owner do a better job and save money
[and maybe lives] in the long run.
You will understand more about your airplane, why certain
parts are cheaper to replace anytime you have access to
them, such as alternator belts when the prop is off. You'll
know why it costs $30 in labor to put 15 cents worth of
grease in a landing gear bushing.
As you're doing the owner assisted annual, have the A&P
point out the things you can do as an owner as preventative
maintenance and how to make the logbook entry. Things like
lubrication and cleaning, replacing light bulbs and such
will save you money and reduce wear and tear on the
airplane. You have to use the right grease and oils, not 3
in 1 from the grocery store. You can also get some aircraft
grade cotter pins and safety wire and replace those that are
damaged or missing.
Buy your A&P some of his favorite ______ or take him [and
maybe his wife too] to a nice place to eat, like Outback or
whatever is good locally. Say Thank You, mechanics don't
hear that often enough.
James H. Macklin
ATP,CFI,A&P
some support
assisted
factory service
experience is
aircraft work.
I'd paid to
the wheel).
me 6 hours
drilling out
too quick
| either.
wired while other
are safety
see my plane
irritating
owner who is
| -Robert
Old May 14th 06, 04:33 PM posted to rec.aviation.piloting,rec.aviation.owning
corners.
Well you can't get more expensive than the factory service centers I'd
been using. I no longer believe in the top dollar = good maintenance
anymore. When you're paying $105/hr for a $12/hr kid to replace your
access panels and he installs the antennas all backwards, you figure
money doens't necessarily equal good work.
-Robert
Old May 14th 06, 05:26 PM posted to rec.aviation.piloting,rec.aviation.owning
Spending money can be a waste. Money spent on a good shop
for work done right is cheap at almost any price. There are
good shops wit good mechanics and there are bad shops and
bad mechanics, and often the bad shop charges more dollars.
But if your mechanic tells you that a certain part needs to
be overhauled or replaced he may be trying to save your
life. If the shop rules don't let you actually speak with
the mechanic and they want you to deal with a service
manager, find a different shop or insist on talking with the
mechanic in private. You can describe the squawks you have
and he can tell you what he finds. He can show you the
V-belt that is worn but serviceable, but it is cheaper to
replace the belt because right now the prop is already off,
for example.
James H. Macklin
ATP,CFI,A&P
some support
is
aircraft
cuts
| corners.
centers I'd
maintenance
replace your
you figure
| -Robert
Old May 14th 06, 11:35 AM posted to rec.aviation.piloting,rec.aviation.owning
-Robert
I couldn't agree more. Knowing more about the aircraft systems will make
you more aware of potential problems. You'll be a safer pilot because you
inspect and test things more intelligently.
Old May 14th 06, 11:37 AM posted to rec.aviation.piloting,rec.aviation.owning
Yep, I found that when I got started, too. (I recently finished my 8th
owner-assisted annual)
Yep. And wires poorly routed in the engine compartment. And heat
ducts carpeted over. The list was fairly extensive.
This seems odd, Robert. Is your plane parked outside? Why would those
inspection panel screws be so corroded? Unless...were they never
removed recently? (More work undone-but-paid-for?)
I strip a fair number of screws every year -- but I've NEVER had to
drill any out on either of the planes we've owned.
What I like is when you have everything in neat little tupperware cups
underneath the appropriate parts of the plane -- and then the shop
moves the plane. Or they pull an extension cord under your plane, and
lasso all the parts buckets. Or they get kicked over. THAT is my pet
peeve about doing an annual.
Agree 100%. I have a voluminous knowledge of the inner workings of my
aircraft, solely because of doing the owner-assisted annuals.
Jay Honeck
Iowa City, IA
Pathfinder N56993
www.AlexisParkInn.com
"Your Aviation Destination"
Old May 14th 06, 02:08 PM posted to rec.aviation.piloting,rec.aviation.owning
Buy a [big] box or two of slide-lock baggies, put the
parts, with a label and tape them to the area near the
inspection cover. You can even add notes to yourself or the
other mechanic who is working on the airplane.
I've heard of owners replacing the standard fasteners with
nice shiny stainless steel screws. Trouble is you can get
dissimilar metal galvanic reactions and then you have to
drill them out.
James H. Macklin
ATP,CFI,A&P
some support
"Jay Honeck" wrote in message
I'd paid to
finished my 8th
in the wheel).
And heat
me 6 hours
drilling out
Why would those
they never
NEVER had to
tupperware cups
the shop
your plane, and
THAT is my pet
owner who is
workings of my
annuals.
| Jay Honeck
| Iowa City, IA
| Pathfinder N56993
Old May 14th 06, 06:04 PM posted to rec.aviation.piloting,rec.aviation.owning
"Jim Macklin" wrote in message
news:EZF9g.20244$ZW3.18025@dukeread04...
drill them out.
snip
Just what I did several years ago in A&P school. During recip overhaul, we
were in groups of 3. I noticed that the other groups seemed to be reckless
with the parts and fasteners they were removing. I went to Sam's and bought
the gallon freezer bags and my group kept everything in the bags and labled.
Made our engine assembly much smoother than the others. We were also the
first one's completed and that engine fired right up and purred like a
kitten!
avast! Antivirus: Outbound message clean.
Virus Database (VPS): 0619-3, 05/12/2006
Tested on: 5/14/2006 12:04:18 PM
avast! - copyright (c) 1988-2006 ALWIL Software.
http://www.avast.com
Old May 14th 06, 07:31 PM posted to rec.aviation.piloting,rec.aviation.owning
Great movie THE BEST of TIMES with Kurt Russell and Robin
Williams...
one line, "we've got to get organized" followed by "it's
against the rules" "What?" "To get organized"
Another good line, "I'm not a has-been, I'm a never-was."
James H. Macklin
ATP,CFI,A&P
Spartan 1972-74
some support
C. Massey" wrote in message
. net...
| "Jim Macklin" wrote
in message
with
get
| drill them out.
| snip
recip overhaul, we
Sam's and bought
were also the
purred like a
| kitten!
Old May 15th 06, 06:02 PM posted to rec.aviation.piloting,rec.aviation.owning
drill them out.
I am aware of galvanic corrosion, which often corrodes aluminum when it is
in contact with steel, especially if in the presence of moisture and even
more especially moisture with salt. The use of stainless fasteners should
AFAIK greatly reduce corrosion of the fasteners but am unaware of any change
to the galvanic corrosion rates on the aluminum. Are you suggesting an
increase in galvanic action between a stainless fastener and a plain steel
nut? Please expand.
I would also appreciate comment on the use of thread lubricants like
'Nevr-Seize' which IMHO allow increased clamping force and also greatly
reduce thread seizing from corrosion.
2006 Annual -- My 8th Owner Assisted -- Update Jay Honeck Owning 14 March 27th 06 07:11 PM
molding plexiglas websites? [email protected] Owning 44 February 17th 05 09:33 PM
Christmas Annual - long drivel Denny Owning 23 December 31st 04 08:52 PM
Which aircraft certification is required for R&D? Netgeek Home Built 5 November 23rd 04 05:59 AM
Annual Costs - Take the Pledge Roger Long Owning 25 February 1st 04 03:41 PM
