#61
Recently, Steven P. McNicoll posted:
"Neil Gould" wrote in message t... It really is a good idea, especially at fields with more than one runway and no established pattern. Every airport has an established pattern. Look up Lost Nation Municipal airport (LNN). There is only a pattern altitude. Direction is up to the pilot. Neil |
#62
"Neil Gould" wrote in message . .. Look up Lost Nation Municipal airport (LNN). There is only a pattern altitude. Direction is up to the pilot. That's not correct. When approaching to land LNN each pilot of an airplane must make all turns of that airplane to the left . |
#63
On Tue, 1 May 2007 13:13:18 -0500, "Neil Gould"
wrote in : Where is that established? Unless you see 'RT' in the information block on the sectional chart, the traffic is left. |
#64
Neil Gould wrote:
Where is that established? Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. 14 CFR 91.126 --Sylvain |
#65
"Neil Gould" wrote in message . .. Look up Lost Nation Municipal airport (LNN). There is only a pattern altitude. Direction is up to the pilot. That's not correct. When approaching to land LNN each pilot of an airplane must make all turns of that airplane to the left . Where is that established? Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. While most of the time people fly left traffic, it certainly isn't what happens all of the time. Neil |
#66
On May 1, 1:56 pm, Sylvain wrote:
Neil Gould wrote: Where is that established? Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. 14 CFR 91.126 --Sylvain We have had endless discussion of 91.126 before... Taken literally you cannot even perform a RH 45 degree entry to the downwind leg unless you are outside the airport traffic area (5 statute miles), can't do instrument approaches with a miss at the MAP, can't do engine out training on the upwind side of the runway, and so on... Like many of the regs it is a bad joke... denny |
#67
Recently, Larry Dighera posted:
On Tue, 1 May 2007 13:13:18 -0500, "Neil Gould" asked regarding LT @ LNN: Where is that established? Unless you see 'RT' in the information block on the sectional chart, the traffic is left. That was my presumption, as well, until my last flight review. It puzzled me as to why aircraft can execute right traffic at this airport (not all that infrequently, either). The CFI claimed that LNN was an exception, and that there was no established pattern. My BFR happens to be due this month, so maybe I'll ask another CFI. ;-) Neil |
#68
"Neil Gould" wrote in message t... Where is that established? § 91.126 Operating on or in the vicinity of an airport in Class G airspace. a) General. Unless otherwise authorized or required, each person operating an aircraft on or in the vicinity of an airport in a Class G airspace area must comply with the requirements of this section. (b) Direction of turns. When approaching to land at an airport without an operating control tower in Class G airspace- (1) Each pilot of an airplane must make all turns of that airplane to the left unless the airport displays approved light signals or visual markings indicating that turns should be made to the right, in which case the pilot must make all turns to the right; and (2) Each pilot of a helicopter or a powered parachute must avoid the flow of fixed-wing aircraft. (c) Flap settings. Except when necessary for training or certification, the pilot in command of a civil turbojet-powered aircraft must use, as a final flap setting, the minimum certificated landing flap setting set forth in the approved performance information in the Airplane Flight Manual for the applicable conditions. However, each pilot in command has the final authority and responsibility for the safe operation of the pilot's airplane, and may use a different flap setting for that airplane if the pilot determines that it is necessary in the interest of safety. (d) Communications with control towers. Unless otherwise authorized or required by ATC, no person may operate an aircraft to, from, through, or on an airport having an operational control tower unless two-way radio communications are maintained between that aircraft and the control tower. Communications must be established prior to 4 nautical miles from the airport, up to and including 2,500 feet AGL. However, if the aircraft radio fails in flight, the pilot in command may operate that aircraft and land if weather conditions are at or above basic VFR weather minimums, visual contact with the tower is maintained, and a clearance to land is received. If the aircraft radio fails while in flight under IFR, the pilot must comply with §91.185. [Doc. No. 24458, 56 FR 65658, Dec. 17, 1991, as amended by Amdt. 91-239, 59 FR 11693, Mar. 11, 1994; Amdt. 91-282, 69 FR 44880, July 27, 2004] Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. While most of the time people fly left traffic, it certainly isn't what happens all of the time. It appears most of them are aware. |
#69
t: Where is that established? Apparently, you are aware of something that the CFIs and other pilots based at LNN don't know. While most of the time people fly left traffic, it certainly isn't what happens all of the time. Me thinks the CFIs there should check the AIM. Although they're not regulatory, they show good operating practices. Does the airport have a segmented circle? Check 4-3-4(b)(5) and 4-3-4(c) -- |
#70
"Neil Gould" wrote in message t... That was my presumption, as well, until my last flight review. It puzzled me as to why aircraft can execute right traffic at this airport (not all that infrequently, either). The CFI claimed that LNN was an exception, and that there was no established pattern. My BFR happens to be due this month, so maybe I'll ask another CFI. ;-) Find another CFI, preferably at another school. |
| Thread Tools | |
| Display Modes | |
| Interesting experience yesterday | Paul Folbrecht | Instrument Flight Rules | 5 | January 2nd 06 11:55 PM |
| "Interesting" wind yesterday | Jay Honeck | Piloting | 36 | March 10th 05 05:36 PM |
| A Moment of Thanks. | Peter Maus | Rotorcraft | 1 | December 30th 04 09:39 PM |
| Looking For W&B Using Arm Instead of Moment | John T | Piloting | 13 | November 1st 03 09:19 PM |
| Permit me a moment, please, to say... | Robert Perkins | Piloting | 14 | October 31st 03 03:43 PM |
