My September 2017 visit to GP Gliders
Old August 18th 20, 04:41 PM posted to rec.aviation.soaring
jld
Default My September 2017 visit to GP Gliders
You probably have reasons to be skeptical but, they should only "expect" until the validation (ground/flight tests) are performed and don't force design changes.
If they updated their configuration this year, it makes sense for the validation tests to happen in Q1 next year.
Because this is not a complete redesign, they should be confident enough to pass validation tests and take the risk to start production using new configuration right now. Therefore I am not surprised to hear they are updating already produced gliders and produce new ones with latest configuration.
"wasn't design driven, but regulatory driven, meaning it can't be relied upon"
I don't get your point, the same situation would be true for anybody designing under FAA/EASA or UL. Until you apply for TC, if authorities changes the rules, you have to adjust.
The UL regulation changes in EU took a long time to get delivered and I am confident it is going to be stable for quite a bit of time.
GP did their best to come up with design targets and now they adjust them to fit most authorities requirements.
Concerning the MTM, if the structure is not the limiting factor, GP will eventually have to adjust it to pass the Vso requirement for UL in EU (i.e. 45 Kts for Germany and 38 Kts in France).
If structure is capable, US experimental could use a higher MTM but, who want to fly above 60 kg/m2 anyway?
  #72
Old August 18th 20, 05:08 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
jld wrote on 8/18/2020 8:41 AM:
Glider pilots on the Allegheny Ridges (ridge soaring), in Western US high deserts
(thermal soaring), and in the Sierra wave sometimes use higher wing loadings. For
my flying in the US, I expect 60 kg/m2 will be plenty high enough, and far above
the 42 kg/m2 (8.5 lb/ft2) I fly at in my ASH26E.
  #73
Old August 18th 20, 05:57 PM posted to rec.aviation.soaring
jld
"Glider pilots on the Allegheny Ridges (ridge soaring), in Western US high deserts (thermal soaring), and in the Sierra wave sometimes use higher wing loading"
Then the GP15 might be able to satisfy these US pilots as long as they use antifreeze in the ballast :-).
Also you might not be able to get all the benefits of high WL if you are limited by Vne due to high altitude.
I have been lucky to fly in Minden before.
Unless you compete in the WGC or are trying to beat a world record, 60 kg/m2 would already be A lot.
Bottom line, lets look for news from GP or the dealers to get confirmation of configuration and delivery dates...
  #74
Old August 18th 20, 06:38 PM posted to rec.aviation.soaring
Eric Greenwell[_4_]
jld wrote on 8/18/2020 9:57 AM:
No antifreeze needed in the summer, as the temperatures at 18,000' are not cold
enough to freeze the water in the wings. Winter wave flying is much colder, of
course, and wave runners that get permission to fly above 18,000' have to consider
the temperature at any time of the year.
According to the recent provisional manual, the GP15 VNE is 162 kts IAS up to 3000
meters; 143 kts IAS at 6000 meters. That's about 195 kts TAS from 3000 meter on
up, so a pretty high limit, especially compared to my ASH26E, with it's 143 kt
VNE. I don't know what modern gliders have for VNE, or wing loading, for that matter.
  #75
Old August 18th 20, 09:49 PM posted to rec.aviation.soaring
andy l
Adding together some of the recent comments, it sounds like this glider might be stronger and lighter than others, and possibly faster as well
Does it use different materials?
And what are all the changes? You can't easily modify already existing gliders for a much higher all up weight, just by writing it down somewhere; it needs to be stronger, for instance thicker spar caps
  #76
Old August 18th 20, 10:00 PM posted to rec.aviation.soaring
andy l
On Monday, 17 August 2020 at 00:16:03 UTC+1, jld wrote:
We have yet to see clear communication from SH or JS on the number of years it takes to get delivery of a new V3 or JS3!
This is not an excuse but probably a bad habit from this whole business!
Who are the 'we' in this remark? Have you made such enquiries yourself?
These gliders have been in production for a while. Some friends have received theirs, so it isn't hard to figure out their effective delivery times. Going forward, the other day I heard some current info on likely timing for new Ventus orders. It doesn't seem to be a state secret.
  #77
Old August 18th 20, 11:07 PM posted to rec.aviation.soaring
2G
They claim to use different materials that make GP gliders lighter and stronger than the competition:
"We use the most advanced composites and construction methods that allow for the exceptional strength requirements of the design. They also contribute to the quality and reliability of the structure. This allows gliders of far lower weight to be as strong as gliders produced using conventional methods."
GP doesn't just claim "lower weight," but "far lower weight" than other gliders, but w/o any evidence to support this claim. The only real evidence I have seen is that Sebastian Kawa was very unhappy with the glider GP delivered to him and switched gliders at the last minute. Kawa also had a propulsion failure while flying a GP-14 in Italy, yet GP gliders makes this bizarre claim on their website:
"The motor can be deployed and running at full power within five seconds providing confidence in the event of when a ‘low save’ is on the cards."
I guess Sebastian didn't get the memo on how reliable GP propulsion systems are. You are certainly welcome to accept all of GP's claims w/o any evidence, but I won't. And I certainly wouldn't send them six figures in cash for it.
Tom
  #78
Old August 18th 20, 11:54 PM posted to rec.aviation.soaring
Eric, what air temp do you regard as cold enough to freeze water in the wings?
  #79
Old August 19th 20, 12:01 AM posted to rec.aviation.soaring
kinsell
Tom
Sebastian's disinterest in flying the Jeta in 2018 was addressed in the
November Soaring article. The wings weren't adequately cured and sagged
fore and aft of the spars. These same wings were what the U.S. dealer
test flew for the article. Putting his best spin on it, he said 51:1
remains a reasonable goal for the small fuselage version. Not exactly
the same as a Dick Johnson test report.
On the propulsion failure, Eric has claimed it was pilot error. If it's
too complicated for a world-class pilot to get right, maybe it needs to
be simplified? "Alexa, save my ass!!"
Sebastian for his part hasn't admitted to error, he made it sound like a
sensor failure indicating the boom wasn't fully up, as can happen on any
boom system. He did press on from an area with good landing options
when getting low to one with poor options, so there was a judgement
error there.
-Dave
  #80
Old August 19th 20, 01:45 AM posted to rec.aviation.soaring
2G
Tom
error there.
-Dave
Ok, let's blame the victim here. GP delivered a poorly constructed glider to Kawa - maybe that's Kawa's fault as well. AFAIK, no GP-15s have received airworthiness certificates in the US (or elsewhere for that matter). The point is that the very limited quality control data we have on GP Gliders is not encouraging, and their wild advertising claims are unsupported.
Tom
FAR 2017 ADS-B re gliders Eric Bick (ZN7) Soaring 4 January 24th 17 04:40 PM
Koenigsdorf 08 September 2012 - File 1 of 1 - Koenigsdorf Segelflugzentrum 08 September 2012 Compressed Contact Sheet.jpg (1/1) Transistor Bubblezap Aviation Photos 0 September 9th 12 09:57 PM
The Last Place I Would Want To Visit. Michael Baldwin, Bruce[_2_] Products 2 September 1st 07 04:38 AM
Pensacola Visit Lee Witten Naval Aviation 10 January 20th 05 06:55 PM
Boston Visit PaulH Piloting 8 August 22nd 04 03:38 PM
