FAR 2017 ADS-B re gliders
Old December 23rd 16, 05:18 AM posted to rec.aviation.soaring
Eric Bick (ZN7)
Default FAR 2017 ADS-B re gliders
This is a separate item from the ANPRM withdrawal re transponders in gliders.
§91.225
Automatic Dependent Surveillance-Broadcast (ADS-B) Out equipment and use.
Old December 23rd 16, 04:29 PM posted to rec.aviation.soaring
Dan Marotta
In typical governmentese, that reads like a plate of spaghetti. I
understood that to mean that gliders are exempt from having ADS-B Out
installed. I will still pursue and installation for my ship, however.
§91.225
Dan, 5J
Old December 23rd 16, 05:55 PM posted to rec.aviation.soaring
Darryl Ramm
§91.225
I am not following, Is there a question or point you are making here?
Nothing has changed related to this regulation in a long time and this has all been discussed on DUC many times. The significant change to 14 CFR 91.225 back in early 2015 was the adoption of "meets requirements of" wording which allows experimental aircraft to meet requirements of 14 CFR 91.225 by using non-TSO but "meets requirements of TSO..." devices for ADS-B Out. (and that change was less intersting for experimental gliders than other experimental aircraft because of their overriding exemption).
Old January 24th 17, 03:22 PM posted to rec.aviation.soaring
Steve Hill[_2_]
https://www.faa.gov/about/office_org...rpretation.pdf
Old January 24th 17, 04:40 PM posted to rec.aviation.soaring
Thanks for the link, I know the person that asked the question.
Akaflieg Arnold Winter 2017 Bob Kuykendall Soaring 0 December 21st 16 12:45 AM
WGC 2017 - Benalla Renny[_2_] Soaring 6 October 26th 16 12:38 PM
Duo Discus Rides in 2017 ? [email protected] Soaring 3 October 14th 16 04:19 PM
2017 Senior Soaring Championship - registration is open Discus277 Soaring 0 July 19th 16 07:05 PM
The World Games 2017 Maciek K. Soaring 0 February 16th 14 08:27 PM
