#71
"UltraJohn" wrote in message k.net... Juan Jimenez wrote: No, Bisbee, no one was talking to you. The only one who has crashed around here is one of your own gaggle. Besides, what are you talking about, you can't even keep a marriage together, let alone an airplane. Shoo. Get over it. You have to fly it first to be able to crash it! John Good point. did you hear that, frisbee? |
#72
wrote in message ups.com... This is a UseNet Newsgroup. We all talk to each other, and to whomsoever reads the archives later, each time we post. No, in _this_ planet we point out when people should keep their mouths shut. ![]() BTW, Mr Jimenez, you mentioned that your engine was lighter than that used in the other BD4Js. Others have suggested that it is lighter by virtue of not having an integral starter. There are no BD-4J's. It's a BD-5J. The 022 Couguar weighs 68 lbs soaking wet. It has no starter/generator. How hard is it to start the engine? Not hard at all. Ignition on, fuel pump on, 145 psi, wait for 11-13% N1, fuel solenoid valve on, light off. Juan |
#73
#74
Juan Jimenez wrote: wrote in message ups.com... There are no BD-4J's. It's a BD-5J. The 022 Couguar weighs 68 lbs soaking wet. It has no starter/generator. Hmm, shifts the CG forward a tad reducing the counterweight needed up front, and thereby the total weight by a bit more too, right? Or don't the 5js need a forward counterweight. How hard is it to start the engine? Not hard at all. Ignition on, fuel pump on, 145 psi, wait for 11-13% N1, fuel solenoid valve on, light off. OK, what's 'N1'? And what happens next after 'light off'? -- FF |
#75
#76
wrote in message oups.com... Hmm, shifts the CG forward a tad reducing the counterweight needed up front, and thereby the total weight by a bit more too, right? Or don't the 5js need a forward counterweight. That's a very good observation. Yes, it does. On most BD-5J's you are required to have some type of ballast on the nose, usually lead bars. On Bishop's jets, the ones being used for surrogate cruise missile work for the military, we resolved this by replacing the huge NICAD batteries with gel cells and moving them forward behind the panel. We also moved just about everything else that could fit in there. The specialists who did the installation said they had never before managed to fit 2 pounds of **** in a 1 pound box. I can send you pictures of that installation if you like, it's amazing. I designed the panel layout but the real work was done by the installers. OK, what's 'N1'? N1 is the turbine rotation speed, expressed in percentage. This is a plain-jane turbojet. And what happens next after 'light off'? Watch your EGT, don't let it go too high, slowly bring the RPM up to a stabilized idle around 51-55%. Make sure everything's in the green. It's really a very simple setup. Juan |
#77
"Dan, U.S. Air Force, retired" wrote in message news:YxoTe.9697$dm.8569@lakeread03... wrote: N1 is turbine one in a two spool engine, N2 would be spool 2. He's using the term to impress us since his motor is single spool. Doubtful, Frisbee. That's your style, not mine. N1 is the term for turbine RPM speed used in all single-spool turbines. Get over it. ![]() Juan |
#78
Juan Jimenez wrote: ... N1 is the turbine rotation speed, expressed in percentage. This is a plain-jane turbojet. And what happens next after 'light off'? Watch your EGT, don't let it go too high, slowly bring the RPM up to a stabilized idle around 51-55%. ... And after that? -- FF |
#79
Juan Jimenez wrote:
"Dan, U.S. Air Force, retired" wrote in message news:YxoTe.9697$dm.8569@lakeread03... wrote: N1 is turbine one in a two spool engine, N2 would be spool 2. He's using the term to impress us since his motor is single spool. Doubtful, Frisbee. That's your style, not mine. N1 is the term for turbine RPM speed used in all single-spool turbines. Get over it. ![]() Juan I worked on several jets with single spools. Not one used N1, it was simply RPM. Dan, U.S. Air Force, retired |
#80
| Thread Tools | |
| Display Modes | |
| Removing water repelent from fiberglass lay-up? | Roger | Home Built | 2 | December 3rd 04 12:15 AM |
| You can now by water-slip inkjet decals by the sheet | Charlotte Gaisford | Restoration | 0 | November 8th 04 03:00 PM |
| You can now by water-slip inkjet decals by the sheet | Charlotte Gaisford | Aviation Marketplace | 0 | November 8th 04 02:59 PM |
| Removing old antennas | Jay Honeck | Owning | 30 | March 21st 04 05:34 PM |
| Info needed to make decals for missiles | TJ | Simulators | 1 | January 16th 04 03:29 PM |
