#71
Thomas Borchert writes:
Problem is, you still answer! This newsgroup is now mainly filled with longwinded discussions on a simmer's questions about reality. Sad! Why do you find questions about real flying in a piloting newsgroup sad? What would you prefer to discuss? -- Transpose mxsmanic and gmail to reach me by e-mail. |
#72
Gene Seibel writes:
It's not real. It's not the same as flying. There's no pressures on the seat of the pants, or feeling of movement, or wind noise. I don't do well on MSFS either. But why would I want to? It'll only get you from Point A to Point A. I consider that an advantage, as the objective is to fly, not to get somewhere. Going from one real-life airport to another would be a huge inconvenience unless I actually had a legitimate reason to travel, which I virtually never do (I hate travel). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#73
"Don Poitras" wrote in message
... Regulations are written to get the maximum meaning in the fewest words. You base that assertion on what? The FARs certainly don't bear that out. There's plenty of verbiage there, much of it excess if one takes the position that one must make inferences with respect to definitions of words in the regulations. Sometimes that requires one to make some common sense interpretation of the words. One does need to occasionally use "common sense" definitions, yes. However, when the FAA has provided a definition (as they have here), that is not required. You seem to want "operation" to mean "when the wheels turn" or perhaps "when the wheels leave the ground". Most of us think it means "when the engine starts" (for planes with engines). YOU seem to want "operation" to mean "when the engine starts". This isn't how the FAA defines it, nor does it make any sense that the FAA would write a regulation that applies to all aircraft, but have some sort of implicit exclusion for powered aircraft in which only "engine start" defines the course of operation. What happens with a motor glider? Is the aircraft not being operated when the engine is shut down in flight? How about a regular powered airplane? Does shutting the engine down in flight allow the pilot to stop using anticollision lights? What about a balloon? Are lights required only when the burner is operating? Arguing over a definition like this is a common, yet tiring, USENET exercise. It's especially tiring when the FAA has already provided a definition, and yet people insist that their definition is incomplete or that one should infer additional meaning beyond that provided in the official definition. It's especially tiring when the entire thread is posted to multiple groups. Followups set to RAS. If you think that your comments and replies to them belong only in r.a.student, then don't post your comments to another newsgroup in the first place. Pete |
#74
"Neil Gould" wrote in message
. com... Note that YOU were the one that set the parameters that the "aircraft's engines are running", therefore, the regs quoted directly answered your original question, as the PIC is always "operating an aircraft" if the engines are running, and therefore it is not "just a polite custom". The PIC is NOT "always 'operating an aircraft' if the engines are running". The FAA specifically defines "operate" to relate to "air navigation". There is nothing in the definition that suggests that simply having the engine running constitutes "operating". Is it a good idea to turn on the anticollision lights if you've got the engine running? Sure, especially if you are going to move the airplane (for example, taxiing from one spot on the ground to another). Is it a regulatory requirement? No, it is not. If you are not engaged in "air navigation", you are not "operating" the aircraft as far as the FARs are concerned. Once again, you choose to argue rather than learn. Seems to me, that accusation is more appropriately leveled at many of the other participants in this thread, this time. Pete |
#75
But it's not flying. It's making pictures on a computer screen.
-- Gene Seibel Tales of Flight - http://pad39a.com/gene/tales.html Because I fly, I envy no one. Mxsmanic wrote: Gene Seibel writes: It's not real. It's not the same as flying. There's no pressures on the seat of the pants, or feeling of movement, or wind noise. I don't do well on MSFS either. But why would I want to? It'll only get you from Point A to Point A. I consider that an advantage, as the objective is to fly, not to get somewhere. Going from one real-life airport to another would be a huge inconvenience unless I actually had a legitimate reason to travel, which I virtually never do (I hate travel). -- Transpose mxsmanic and gmail to reach me by e-mail. |
#76
Gene Seibel writes:
But it's not flying. It's making pictures on a computer screen. Sitting in an aircraft isn't flying, either. The aircraft flies; you sit and watch. Only birds actually fly. -- Transpose mxsmanic and gmail to reach me by e-mail. |
#77
Mxsmanic wrote:
RK Henry writes: 1. In FARs part 1.1, Definitions, "Operate" is defined: "Operate, with respect to aircraft, means use, cause to use or authorize to use aircraft, for the purpose (except as provided in §91.13 of this chapter) of air navigation including the piloting of aircraft, with or without the right of legal control (as owner, lessee, or otherwise)." I don't see the word "engine" anywhere in the quoted text--again. It's best to read what regulations say, and not try to guess what you'd like them to mean. Legal documents are generally explicit; imagination is neither required nor recommended. If you're planning on using the airplane for flying, I'd interpret that as beginning with the moment you turn the key 'til the airplane is back in the hangar. So it's your interpretation; it's not written in the regulations. You are such a little cock wad. If you are starting the aircraft to fly you are operating the aircraft. |
#78
601XL Builder wrote:
... If you are starting the aircraft to fly you are operating the aircraft. Apparently less then even that. In the Florida state criminal trial of the drunk airline pilots, they were stopped during the pushback which they commanded before even starting the engines. There was expert testimony, by either FAA or expert with prior FAA exp, that the the mere authorization to push it back was operating the aircraft for purpose of flight under FAA rules, and therefore "operate" as one necessary element of the state crime was there and the jury agreed. F-- |
#79
Mxsmanic wrote: RK Henry writes: 1. In FARs part 1.1, Definitions, "Operate" is defined: "Operate, with respect to aircraft, means use, cause to use or authorize to use aircraft, for the purpose (except as provided in §91.13 of this chapter) of air navigation including the piloting of aircraft, with or without the right of legal control (as owner, lessee, or otherwise)." I don't see the word "engine" anywhere in the quoted text--again. It's best to read what regulations say, and not try to guess what you'd like them to mean. Legal documents are generally explicit; imagination is neither required nor recommended. If you're planning on using the airplane for flying, I'd interpret that as beginning with the moment you turn the key 'til the airplane is back in the hangar. So it's your interpretation; it's not written in the regulations. You are such a little cock wad. If you are starting the aircraft to fly you are operating the aircraft. Personally, I think we should point him in the direction of the FAA. As much as I hate to defend them, I think that they'd love to hear that this particular reasonably well written reg is open to interpretation. |
#80
Jim Macklin wrote:
The 727 has a prop. They install it under the tail while parked. Either that or you drop the rear airstairs if the plane is so equipped. Don't know about the 727, but some of the DC-9's you HAD to do that. When the plane was empty it only took a couple of guys standing in the back to tip it up off the nose gear. |
[VERY LONG} MD airplanes, complete and projects, engines, gliders, many other items. | [email protected] | Aviation Marketplace | 0 | June 10th 06 10:51 PM |
Landing lights | Robert Barker | Owning | 20 | May 11th 06 02:33 AM |
Jet sailplane update | Bob C | Soaring | 0 | April 13th 06 08:06 AM |
Buying an L-2 | Robert M. Gary | Piloting | 13 | May 25th 04 04:03 AM |
36HP VW Engine | Claton Cadmus | Home Built | 12 | October 24th 03 05:18 AM |
