#71
#72
In article , Tim
wrote: And those of us without that magical device? You would not have been able to navigate direct from SNS to KVNY (or any of its IAFs) so this whole discussion would have been moot. rg |
#73
In article , Tim
wrote: Ron Garret wrote: In article , Tim wrote: The OP was confused about what to do at a clearance limit - regardless ^^^^^^^^^ of radio contact. ^^^^^^^^^^^^^^^^ Not so. My original question was: "what should I have done if I'd been in IMC and lost comm before they changed my routing? ^^^^^^^^^^^^^ This is the fourth or fifth time you've incorrectly put words in my mouth. What is your problem? rg Are you ****ing kidding me? No. Please re-read the exchange and pay particular attention to the highlighted passages. rg |
#74
In article , Tim
wrote: Yes, I understand that. And they gave you that clearance limit because that is what you requested from them - when you filed. That is the end of your flight and they gave you a clearance to there. It is not a clearance to hold there is it? Because what you are arguing is that you really only have a clearance to circle the airport every time you get a clearance that starts with "cleared to xxx airport" and ends in "...direct." No, that is not what I am arguing. I have never said any such thing (because that's clearly ridiculous). You are. You state that you are going to your clearance limit - which is the airport, THEN, you have to go somewhere else then back to the airport which was your clearance limit. That is not the same thing as circling the airport, which is what you said. I draw your attention to FAR 91.181(b) and 91.185(c)(3)(ii) which seem to me to support my position that if your clearance is direct to an airport and you lose comm in IMC you are supposed to fly to (i.e. over) the airport first, THEN to an IAF, then land. We both seem to agree that this would be a stupid thing to do. So could you please either 1) cite the reg that says that a direct clearance to an airport is in fact a direct clearance to some unspecified IAF for that airport or 2) admit that the procedure that we both agree would be the prudent course of action in fact violates the regs? rg |
#75
Ron,
what should I have done if I'd been in IMC and lost comm before they changed my routing? Never, ever accept a vector without a reason for it. If they don't give it (which ATC should, per the regs), ask. It can be "for the ILS", "for traffic", "for spacing", whatever. In any case, since you know the reason, in case of lost comm, work around that reason back to your original clearance. -- Thomas Borchert (EDDH) |
#76
Tim,
Do you always argue with people when they give you answers after you have insulted them, told them don;t know the answer and then actually get a correct response? Uhm, that's his SOP. It's pretty much all he does here. But you knew that going in ;-) -- Thomas Borchert (EDDH) |
#77
Ron,
"The minimum IFR altitude is not easily determined." Yes, but don't the regs elsewhere say that on off-airway routings, the pilot is responsible for it? -- Thomas Borchert (EDDH) |
#78
Tim,
If you are saying that an inop radio is an emergency then I would question your judgment as a pilot. If the pilot thinks it is an emergency, then by all means, "declare" one and treat it as such. And if it were an emergency, why are there different transponder codes for emergency and lost comm. -- Thomas Borchert (EDDH) |
#79
Roger wrote:
On Sat, 10 Mar 2007 00:03:57 -0800, Ron Garret wrote: Last night I flew from SJC to VNY. To my astonishment I was cleared vectors to SNS, then direct VNY (despite having filed a more standard routing) at 9000 feet. I knew perfectly well that the routing was going to change because I've done that route a zillion times, and indeed, near Bakersfield they switched me over to the standard LHS, LYNXX8 arrival, followed by vectors to the ILS RWY 16R. My question is: what should I have done if I'd been in IMC and lost comm before they changed my routing? By the book I should have continued to fly my clearance, which would have run me into a mountain around GMN, so that's probably not the right answer. Viable possibilities seem to include: There's only one. You fly it as last cleared. You arrive at the expected time as the expected place. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Radio failure is an emergency. You fly where ever you need to in order to safely get on the ground. ATC will sort it out and keep other aircraft out of your way. |
#80
Ray Andraka wrote:
Roger wrote: On Sat, 10 Mar 2007 00:03:57 -0800, Ron Garret wrote: Last night I flew from SJC to VNY. To my astonishment I was cleared vectors to SNS, then direct VNY (despite having filed a more standard routing) at 9000 feet. I knew perfectly well that the routing was going to change because I've done that route a zillion times, and indeed, near Bakersfield they switched me over to the standard LHS, LYNXX8 arrival, followed by vectors to the ILS RWY 16R. My question is: what should I have done if I'd been in IMC and lost comm before they changed my routing? By the book I should have continued to fly my clearance, which would have run me into a mountain around GMN, so that's probably not the right answer. Viable possibilities seem to include: There's only one. You fly it as last cleared. You arrive at the expected time as the expected place. Roger Halstead (K8RI & ARRL life member) (N833R, S# CD-2 Worlds oldest Debonair) www.rogerhalstead.com Radio failure is an emergency. You fly where ever you need to in order to safely get on the ground. ATC will sort it out and keep other aircraft out of your way. So any time a piper cub flies it is an emergency? So you can fly anywhere you want and atc is supposed to guess where you are going or magically know whom to keep away from your unknown position? They cancel and stop all flights while you fly wherever you want? Does not sound good to me. |
Real-world IFR currency | Paul Folbrecht | Instrument Flight Rules | 47 | March 23rd 05 04:19 PM |
Real World Problem in FS9 | The Real Cali Kid | Simulators | 12 | December 6th 03 11:15 AM |
Real World Weather (Isabelle) | [email protected] | Simulators | 1 | September 21st 03 09:53 PM |
Real-time real world air traffic in flight sims | Marty Ross | Simulators | 6 | September 1st 03 04:13 AM |
Real World Specs for FS 2004 | Paul H. | Simulators | 16 | August 18th 03 09:25 AM |
