This questions has been killing me, what is the name of the leading
edge flaps that you find on airliners for example. Ive heard the name slats, but I know there is another name for it. |
Arquebus257WeaMag wrote:
This questions has been killing me, what is the name of the leading edge flaps that you find on airliners for example. Ive heard the name slats, but I know there is another name for it. Droops? John |
krueger flaps
Not sure if this applies, but the Tornado used to have Krueger (think thats
how its spelt) on the leading edge where the wing pivots. "Arquebus257WeaMag" wrote in message m... This questions has been killing me, what is the name of the leading edge flaps that you find on airliners for example. Ive heard the name slats, but I know there is another name for it. |
On Sat, 10 Jan 2004 10:07:10 -0800, "Tarver Engineering"
wrote: Ed Rasimus wrote: There are all sorts of variations including Krueger flaps, Fowler flaps, "BLC" (boundary layer control) blown flaps, flaperons that combine both flap and aileron functions, and spoilers which disrupt airflow across the top of the wing to reduce lift/increase drag. Ed did not address the use of spoiler flap as used to cancel adverse Yaw, produced by roll steering. One can only say so much in a newsgroup response. There's little time to address all possible options of control surfaces at all times. But, since you brought it up, let us note that some aircraft use "spoilers" (not spoiler flaps) as a control surface. It is an effective way to counter adverse yaw--the tendency of the drag of a downward deflected aileron to be greater than that of the upward deflected one, which causes the aircraft to way opposite the direction of intended roll. The B-52 for example uses spoilers for roll control and the F-105 had eight spoilers on the top of the wing on each side for the same purpose. Not sure what "roll steering" is. Roll is defined as rotation around the longitudinal axis of the aircraft. Yaw as rotation around the vertical, and pitch as rotating relative to the horizontal. One "steers" the aircraft by inducing bank, which then creates a lift component to divert the aircraft from straight ahead flight. Ed's description of the spoiler is refers only to a spolier flap in a speedbrake configuration and while textbook in nature, has been false for airliners since the 707; Spoilers, surfaces that extend from the top surface of the wing are used to "spoil" lift. They disrupt the smooth, accelerated flow over the top surface of the wing which causes the low pressure area which is different than the high pressure area on the bottom surface (maybe wings don't lift, they "suck" the airplane up?) When these lift-destroying devices are deployed, they help an aircraft descend without gaining a lot of airspeed. Speedbrakes, are traditionally drag devices, used to increase the form or parasite drag on the airframe. Same thing gets accomplished but spoilers operate through induced drag/destruction of lift while speedbrakes operate by parasite drag. Got nothing to do with aircraft specific types. except twins. (engine out regulations for twins require a tall tail, so the mechinisation of a spoiler flap carrys too large a weight penalty to be practical) What does tail size have to do with weight lifting capability? Twins don't always have a tall tail, and regardless, the mechanics of a flight control system, whether spoilers, flaps, slats, slots, speedbrakes, ailerons, flaperons, spoilerons, stabilizers, stabilators, or whatever is about the same. Ed Rasimus Fighter Pilot (USAF-Ret) "When Thunder Rolled" Smithsonian Institution Press ISBN #1-58834-103-8 |
"Ed Rasimus" wrote in message ... On Sat, 10 Jan 2004 10:07:10 -0800, "Tarver Engineering" wrote: Ed Rasimus wrote: There are all sorts of variations including Krueger flaps, Fowler flaps, "BLC" (boundary layer control) blown flaps, flaperons that combine both flap and aileron functions, and spoilers which disrupt airflow across the top of the wing to reduce lift/increase drag. Ed did not address the use of spoiler flap as used to cancel adverse Yaw, produced by roll steering. One can only say so much in a newsgroup response. There's little time to address all possible options of control surfaces at all times. But, since you brought it up, let us note that some aircraft use "spoilers" (not spoiler flaps) as a control surface. I think aircraft use spoiler flaps as a control surface, as opposed to a fixed spoiler. Just as I might write the full name of a kreuger flap, or a fowler flap. (nice description in your post, by the way, Ed) If you mean to claim that the introduction of aerodynamics to the discussion is problematic, you can't possibly know the depths of the buffarilla operator's consternation that USAF had mislead him as to how his short tail B-52 wing works. I don't really mean to bust anyone's bubble, but I think the real answer is important too. It is an effective way to counter adverse yaw--the tendency of the drag of a downward deflected aileron to be greater than that of the upward deflected one, which causes the aircraft to way opposite the direction of intended roll. Yet, the spoiler in such a configuration is not intended to "spoil lift", but only to cancel the drag and lift difference between the right and left aileron. The B-52 for example uses spoilers for roll control and the F-105 had eight spoilers on the top of the wing on each side for the same purpose. Here is a question for you, did my sploiler flap discussion with Buff get the USAF to teach the real aerodynamics of the short tail B-52 wing? I think it would be interesting to note if it relly matter whether a pilot knows how their wing works. Not sure what "roll steering" is. Roll is defined as rotation around the longitudinal axis of the aircraft. Yaw as rotation around the vertical, and pitch as rotating relative to the horizontal. One "steers" the aircraft by inducing bank, which then creates a lift component to divert the aircraft from straight ahead flight. The error between selected course and actual course is roll steering.(or more correctly, the output of a mode slector) On the output side of the roll computer is roll command, which you may have seen dispalyed on a flight director attitude display. Ed's description of the spoiler is refers only to a spolier flap in a speedbrake configuration and while textbook in nature, has been false for airliners since the 707; Spoilers, surfaces that extend from the top surface of the wing are used to "spoil" lift. Not in the application we are discussing here. The spoiler flap actually pushes down on the wing and induces drag. Although I can understand why it is simpler for an operator to parrot some string of words. They disrupt the smooth, accelerated flow over the top surface of the wing which causes the low pressure area which is different than the high pressure area on the bottom surface (maybe wings don't lift, they "suck" the airplane up?) Sometimes, but right now we are not discussing a speed brake. When these lift-destroying devices are deployed, they help an aircraft descend without gaining a lot of airspeed. Yes, Ed knows what a speed brake is. |
| Thread Tools | |
| Display Modes | |
| FS - Propeller leading edge protective tape | Sammy | Home Built | 0 | July 6th 04 01:06 PM |
| Leading edge protection search | Tim Hickey | Home Built | 0 | June 28th 04 03:45 AM |
| A Bush C150? With Leading Edge Slats? | [email protected] | Home Built | 33 | May 27th 04 06:39 PM |
| -7 wing leading edge 'glitch' ? | Charlie England | Home Built | 0 | March 7th 04 01:27 AM |
| tail buffeting and leading edge fillets, strakes | Wallace Berry | Home Built | 1 | September 26th 03 11:48 PM |
