ASK21 air brake bell crank repair
Old December 25th 10, 06:15 PM posted to rec.aviation.soaring
bildan
Default ASK21 air brake bell crank repair
On Dec 25, 7:07*am, JJ Sinclair wrote:
On Dec 23, 6:31*am, Geoff Brown
I've been trying to find anything on the www that shows how to access the
pivot bolt that secures the air brake bell crank that is located in the air
brake box on an ASK21.
I've had no luck. *Does anyone else have any pointers?
Thanks
Geoff,
If I understand the problem, you need to drill a hole on the forward
side of the spar in order to get at the other end of the bolt that
secures the air brake pivot bolt. I would tap-test the width of the
spar cap and then add an inch to show where to drill an exploritory
hole. Start with 1/16 drill and stop if you get anything other than
skin/foam/skin. If that goes OK, then widen it out to 1/2" in order to
get a small light and mirror in there. Now you can adjust the hole as
necessary to remove/replace the bolt/nut. I have replaced the inner
skin with pre-cured glass piece that overlaps the inner skin at 40:1
(about 3/4"), held in place with 3 strings that pull it up until epoxy
cures.Then replaced the foam core (plug with no scarf) followed with a
normal 40:1 scarf on the outer skin replacement + one layer of 92110
extending out another 1/2" to make sure none of the uni tries to get
loose.
Hope this helps,
JJ
Strike's me this thread could be merged with the one on cheap video
cameras. A search of Ebay for "USB endoscope" turns up some cheap
options. One could be used for inspecting the interior of gliders
through tiny holes. IIRC, something like this was used to inspect the
interior of DUO wings after an AD.
Old December 27th 10, 09:35 PM posted to rec.aviation.soaring
Geoff Brown
Thanks for all your help - I'll let you know how we got on.
lightning stikes a ASK21 jeplane Soaring 15 May 16th 09 05:03 PM
ASK21 --- OR -- Charles Yeates Soaring 14 November 9th 08 06:17 AM
Brake pad P/N for ASK21? [email protected] Soaring 2 September 28th 07 11:10 PM
FS: ASK21 disassembly tool Bob Kuykendall Soaring 0 April 25th 07 08:35 PM
ASK21 vs G103 solo89 Soaring 13 October 23rd 03 07:15 PM
