ASK21 air brake bell crank repair
Old December 23rd 10, 02:31 PM posted to rec.aviation.soaring
Geoff Brown
Default ASK21 air brake bell crank repair
I've been trying to find anything on the www that shows how to access the
pivot bolt that secures the air brake bell crank that is located in the air
brake box on an ASK21.
I've had no luck. Does anyone else have any pointers?
Thanks
Old December 23rd 10, 03:53 PM posted to rec.aviation.soaring
Bob Kuykendall
On Dec 23, 6:31*am, Geoff Brown
I have a sawzall...
Old December 23rd 10, 04:03 PM posted to rec.aviation.soaring
On Dec 23, 9:31*am, Geoff Brown
I've had no luck. *Does anyone else have any pointers?
Thanks
Access hole on bottom required. Most likely aft of spar.
You would best be served by contacting the factory on this one. Bad
stuff happens when you cut the spar cap.
UH
Old December 23rd 10, 04:11 PM posted to rec.aviation.soaring
Papa3
Thanks
UH
"I'm a little hazy on this whole good/bad thing..."
P3
Old December 23rd 10, 04:26 PM posted to rec.aviation.soaring
bildan
On Dec 23, 7:31*am, Geoff Brown
Thanks
I've been associated with a couple of these situations. If your shop
knows exactly where, one or two 5cm round holes can be cut in the
bottom skin through which a wrench will fit. A perfectly round hole
is a simple repair and you'll never see where it was.
Why do you need access?
Old December 24th 10, 09:15 PM posted to rec.aviation.soaring
Geoff Brown
At 16:26 23 December 2010, bildan wrote:
On Dec 23, 7:31=A0am, Geoff Brown
a=
ir
I've had no luck. =A0Does anyone else have any pointers?
Thanks
The ball race that couples to the air brake paddle side has corroded and
needs replacing. My shop also reckons a couple of holes will be needed to
allow access by wrenches (though the hope is that bolt doesn't have to be
fully retracted). We were hoping that we could find some pictures of what
we might find before cutting any holes.
Old December 25th 10, 12:17 AM posted to rec.aviation.soaring
bildan
On Dec 24, 2:15*pm, Geoff Brown
a=
ir
Thanks
I've been associated with a couple of these situations. *If your shop
bottom skin through which a wrench will fit. *A perfectly round hole
needs replacing. *My shop also reckons a couple of holes will be needed to
fully retracted). *We were hoping that we could find some pictures of what
Yep, I've seen that. The ASK-21 spoiler boxes, like most composite
gliders, don't have drain holes for water, which has leaked in around
the spoiler cap, to escape. If a glider is to be tied out, it's a
good idea to tape some colorful plastic sheet over the spoilers to
keep water out. I worry a little about using white wing gap tape to
seal the spoiler boxes - someone might not see it and take off with
the spoilers taped shut.
Old December 25th 10, 02:54 AM posted to rec.aviation.soaring
Bob Kuykendall
On Dec 24, 1:15*pm, Geoff Brown
needs replacing...
I'm interested in understanding your terminology. What is the thing
you call a "ball race?"
Thanks, Bob K.
Old December 25th 10, 08:30 AM posted to rec.aviation.soaring
Geoff Brown
At 02:54 25 December 2010, Bob Kuykendall wrote:
On Dec 24, 1:15=A0pm, Geoff Brown
and
needs replacing...
Thanks, Bob K.
See http://en.wikipedia.org/w/index.php?...ce&redirect=no
Geoff
Old December 25th 10, 02:07 PM posted to rec.aviation.soaring
JJ Sinclair
Thanks
Geoff,
If I understand the problem, you need to drill a hole on the forward
side of the spar in order to get at the other end of the bolt that
secures the air brake pivot bolt. I would tap-test the width of the
spar cap and then add an inch to show where to drill an exploritory
hole. Start with 1/16 drill and stop if you get anything other than
skin/foam/skin. If that goes OK, then widen it out to 1/2" in order to
get a small light and mirror in there. Now you can adjust the hole as
necessary to remove/replace the bolt/nut. I have replaced the inner
skin with pre-cured glass piece that overlaps the inner skin at 40:1
(about 3/4"), held in place with 3 strings that pull it up until epoxy
cures.Then replaced the foam core (plug with no scarf) followed with a
normal 40:1 scarf on the outer skin replacement + one layer of 92110
extending out another 1/2" to make sure none of the uni tries to get
loose.
Hope this helps,
JJ
lightning stikes a ASK21 jeplane Soaring 15 May 16th 09 05:03 PM
ASK21 --- OR -- Charles Yeates Soaring 14 November 9th 08 06:17 AM
Brake pad P/N for ASK21? [email protected] Soaring 2 September 28th 07 11:10 PM
FS: ASK21 disassembly tool Bob Kuykendall Soaring 0 April 25th 07 08:35 PM
ASK21 vs G103 solo89 Soaring 13 October 23rd 03 07:15 PM
