#51
effect of changed thrust line.
On Fri, 14 Nov 2008 19:48:00 -0500, "Morgans"
wrote: "Alan Baker" wrote In level flight, drag is horizontal. Engine thrust is not except at one particular angle of attack (and it is technically possible that it is never level for any angle of attack the aircraft can achieve). So drag and thrust cannot *possibly* cancel each other except at the one angle of attack. Now, you are starting to get close. You are splitting hairs, though. Airplanes are said to be a loose flying formation of compromises. In the question of thrust angle, also. Parasite drag goes up for higher speeds, induced drag goes up with higher loads. The angle of attack changes the center of lift, loading affects the center of gravity of the airplane, and the tail balances it all out, with help from the thrust angle. Everything is designed to achieve a compromise of performance and safety, speed and comfort, and many other factors. So goes it with questions of thrust, trim and what goals you are trying to maximize. Same with this whole question. A different engine will cause a different thrust line, and changes would need to be made to keep the handling qualities approximately the same. They can never be the exact same, but an attempt can be made to keep it close. A change of 1/2 degree would be close, but the best answer will be to try it and see. Drag still is the paramount factor in attempting to quantify the changes that will need to be made. Once things start rotating, then they will indeed rotate around the center of mass. If the change in the angle is made successfully, there won't be any rotating going on. ;-) U guess the way to intelligently assess this is to determine the longitudinal center of balance of the finished plane, and project the thrust line of the engine (from the plans) back to where the 2 intesect. THAT point is where I want the new thrust lines to intersect as well. If I drop the engine 2 inches I change the angle down enough for the thrust line to hit the same point and the flight characteristics SHOULD, theoretically be the same. No? Any reason this should not work? |
#52
On Fri, 14 Nov 2008 16:52:24 -0800, Alan Baker
wrote: In article , Bob Kuykendall wrote: On Nov 14, 4:10Â*pm, Alan Baker wrote: ...Where must the axis of the thrust vector be? Through the centre of mass. Period. Ah, I see. All those self-launch gliders and amphibs with pylon- mounted engines must be figments of imagination. Thanks for clarifying that. Bob K. Bob, Let's put back what you snipped: Now: when you start the engine and add its thrust into the equation, what is the one direction in which you can apply that thrust and not cause the aircraft to pitch? I'm not saying that you can't have an engine mounted with the thrust line pointed off the CoM. You can, but when you change engine power, the aircraft is going to experience a pitch change. I'm saying if you don't want pitch changes with changing engine thrust, you have to mount it with the thrust line through the CoM. And I'm right. But if you don't believe me, will a reference from Princeton suffice? http://www.princeton.edu/~stengel/MAE331Lecture9.pdf "Pitching Moment due to Thrust € Thrust line above or below center of mass induces a pitching moment" Note: no mention of drag line... Let's step back and take another look. The plane is trimmed for level flight.All forces are ballanced. The aerodynamic drags (parasitic and dynamic) and lifts (main wing and rear horizontal stab) balance out, so the center of mass is what the plane will rotate around when something other than aerodynamic trim causes the plane to pitch. Moving the center of mass forward or backwards from the center of lift will cause a pitching motion, as will adding thrust (or drag) which is not applied through the center of mass. |
#53
#54
#56
On Fri, 14 Nov 2008 16:56:51 -0800, Alan Baker
wrote: In article , "Morgans" wrote: "Alan Baker" wrote In level flight, drag is horizontal. Engine thrust is not except at one particular angle of attack (and it is technically possible that it is never level for any angle of attack the aircraft can achieve). So drag and thrust cannot *possibly* cancel each other except at the one angle of attack. Now, you are starting to get close. You are splitting hairs, though. No. I'm understanding the situation and so far, you've not shown that you do. Airplanes are said to be a loose flying formation of compromises. In the question of thrust angle, also. Parasite drag goes up for higher speeds, induced drag goes up with higher loads. The angle of attack changes the center of lift, loading affects the center of gravity of the airplane, and the tail balances it all out, with help from the thrust angle. If your claim that thrust and drag line always canceled each other out, then that last statement would not be true, would it? Everything is designed to achieve a compromise of performance and safety, speed and comfort, and many other factors. So goes it with questions of thrust, trim and what goals you are trying to maximize. Same with this whole question. A different engine will cause a different thrust line, and changes would need to be made to keep the handling qualities approximately the same. They can never be the exact same, but an attempt can be made to keep it close. They can be kept close by keeping the change in torque about the centre of mass the same as they were in the original design... A change of 1/2 degree would be close, but the best answer will be to try it and see. Where did you get that figure? Show your work if you're going to try and be quantitative... Drag still is the paramount factor in attempting to quantify the changes that will need to be made. Once things start rotating, then they will indeed rotate around the center of mass. If the change in the angle is made successfully, there won't be any rotating going on. ;-) Yup. And in order for that to happen, you need to keep the same relationship with the centre of *mass*. :-) Using an engine offset calculator, and assuming the CL is over the CM and it is 78" behind the prop center,1.5 degrees would have the prop center 2.045" below the CM. If I lower the engine 2 inches, the angle needs to change to 2.969 If theCM is farther back, the angle change will be less. If I only drop the engine 1 inch instead of 2, the difference is half. If I drop it 4 degrees, the angle WOULD be over 3.5 degrees - 4.432, to be exact. ASSUMING the CM is somewhere very close to the CL (which it MAY not be) |
#57
And angling an engine UP is a real BAD (tm) idea. Really? So when you're flying with a large AOA, it's BAD(tm)? Please. I don't know who you are, nor what your qualification really are. But most of what you have espoused here I strongly disagree with. You dance pretty well, though. Richard |
#58
Alan Baker wrote:
Not if you use wedge washers... http://www.instron.us/wa/acc_catalog...ref=http://www .google.com/search The smallest of those are 1" in dimeter. Do you think that's big enough??? -- Richard (remove the X to email) |
#59
#60
cavelamb himself wrote: And angling an engine UP is a real BAD (tm) idea. Really? So when you're flying with a large AOA, it's BAD(tm)? Please. I don't know who you are, nor what your qualification really are. But most of what you have espoused here I strongly disagree with. You dance pretty well, though. Richard Nope. I just don't like bull****. Angling an engine "up" implies only the physical orientation of the engine. Now if you want to talk about what makes for a stable configuration with respect to the *aircraft*, that's an entirely different story. -- Alan Baker Vancouver, British Columbia http://gallery.me.com/alangbaker/100008/DSCF0162/web.jpg |
Similar Threads | ||||
thrust line for engine and not mounting engine on this thrust line | tommyann | Home Built | 8 | December 15th 06 03:31 PM |
Has something changed | [email protected] | Soaring | 10 | May 3rd 05 08:34 PM |
High thrust line on canard design? | Shin Gou | Home Built | 4 | March 5th 05 03:06 AM |
Getting students to line up with the center line | BoDEAN | Piloting | 27 | April 21st 04 11:23 AM |
I want to tell you something that has changed my life! | C J Campbell | Owning | 11 | January 29th 04 11:34 PM |
