Hard wax v/s liquid wax
Hi,
Can hard wax be replaced by liquid wax application? Of course silicon free, as well as other harmfull adds. Although i've seen guys maintaining their gliders purely on applying liquid wax regularly, i guess it wont seal & protect the gelcoat as well as a good anual hard wax buffing. ¿Any advice? Thanks |
On Tuesday, August 28, 2018 at 8:30:22 AM UTC-4, FranCP wrote:
Hi, Can hard wax be replaced by liquid wax application? Of course silicon free, as well as other harmfull adds. Although i've seen guys maintaining their gliders purely on applying liquid wax regularly, i guess it wont seal & protect the gelcoat as well as a good anual hard wax buffing. ¿Any advice? Thanks Liquid wax is good for maintaining but is not a substitute for the sealing properties of hard wax on polyester finishes. Hard wax buff, then maintain with liquid wax. UH |
Please name a few brands and types of typical "hard wax" for use on gelcoat.
Thanks. |
Menzerna seems to be the pick of the bunch here in Europe
G18 first and something like M5 or P175 to give it a glossy finish |
I have had good results recently with Big White Hi-Temp Paste Wax. Put in on thin by hand or smooth pad at low rpm with a random orbit machine. Let dry to a haze, hand wipe off with a clean cloth. Buff with a finishing pad at higher rpm.
As with painting, surface prep before waxing is critical for best results. Remove hard water stains (ehite viniger usually works), polish with an ultrafine compound like 3m Finesse-it II (white color). Be careful of the new 3M ultrafine compound for cars that is blue in color, it can stain white gel coat if left on the surface more than a few seconds. |
El martes, 28 de agosto de 2018, 12:27:55 (UTC-3), Soartech escribió:
Please name a few brands and types of typical "hard wax" for use on gelcoat. Thanks. According to my research, pure brazilian "Carnauba" seems to be good for the job. |
On Tuesday, August 28, 2018 at 10:41:06 AM UTC-5, Ross wrote:
Menzerna seems to be the pick of the bunch here in Europe G18 first and something like M5 or P175 to give it a glossy finish Generally, we believe that the smoother and more glossy the surface, the better. Is it actually supported by a scientific research? How about the 'stickiness' of certain substances with regards to the airflow, e.g. caused by electrostatic charge? Any thoughts? |
On Tuesday, August 28, 2018 at 6:30:22 AM UTC-6, FranCP wrote:
Hi, Can hard wax be replaced by liquid wax application? Of course silicon free, as well as other harmfull adds. Although i've seen guys maintaining their gliders purely on applying liquid wax regularly, i guess it wont seal & protect the gelcoat as well as a good anual hard wax buffing. ¿Any advice? Thanks A golf ball has many small dimples over its surface, to make it more "slippery". So how would this principle apply to a glider? |
On Tue, 28 Aug 2018 19:50:19 -0700, John Foster wrote:
On Tuesday, August 28, 2018 at 6:30:22 AM UTC-6, FranCP wrote: Hi, Can hard wax be replaced by liquid wax application? Of course silicon free, as well as other harmfull adds. Although i've seen guys maintaining their gliders purely on applying liquid wax regularly, i guess it wont seal & protect the gelcoat as well as a good anual hard wax buffing. ¿Any advice? Thanks A golf ball has many small dimples over its surface, to make it more "slippery". So how would this principle apply to a glider? Read up on turbulators. They're not needed on modern airfoils, but were useful for preventing flow separations on older wing sections (Wortmann) and at the hinges of control surfaces: - I've seen turbulators immediately ahead of the aileron hinges on Discus 1s - fitting them ahead of the rudder hinge on a Grob G.103 is said to improve rudder response - my Std Libelle has full span turbulators under the wing, just in front of the undercambered part of the lower surface. Streifneder sells them. ... and of course they work really well to improve airflow at low Reynolds numbers (40,000 - 100,000). Just ask any serious free flight model flyer. The first F1A I built with a D-box wing structure flew like a dog until I fitted thread turbulators where the rear of the leading edge and the front of the main spar were on my previous successful open-structure models with entirely tissue covered wings. -- Martin | martin at Gregorie | gregorie dot org |
Le mercredi 29 août 2018 13:42:25 UTC+2, Martin Gregorie a écritÂ*:
Read up on turbulators. They're not needed on modern airfoils, Except that ALL modern airfoils use turbulators. |
Similar Threads | ||||
Saturn V S-IC Stage Liquid Oxygen Tank 6414299.jpg | [email protected] | Aviation Photos | 0 | April 12th 07 01:32 AM |
Saturn I Liquid-Oxygen (LOX) Tank 6000382.jpg | [email protected] | Aviation Photos | 0 | April 10th 07 09:59 PM |
Liquid oxygen equipment for glider | Bruno Maes | Soaring | 14 | February 25th 07 04:46 PM |
Liquid Shim | Boelkowj | Home Built | 1 | April 17th 04 06:30 AM |
Liquid to liquid coolers | Paul Millner | Home Built | 2 | July 5th 03 02:32 PM |
