First emergency
I thought you might all find this story interesting.
Me, I'm 53 and have been flying since 1988 with about 1000 hrs. My partner is a CFI and we've been in a Cherokee 140 partnership for about 12 years. We have a 1974 Cherokee Cruiser, which we normally keep well maintained (!). About a week ago my partner and I decided to fly after work. We are still breaking in a new cylinder so we thought we'd fly local here in Southern California. I flew left seat and we took off from Camarillo and flew around Malibu, then I flew over to Santa Paula for a landing. We had agreed we wanted to fly about 1.5 hrs, so as I was landing at Santa Paula I was at about 45 minutes. After I landed I asked my partner if he wanted to switch sides, but he said no, he'd fly from the right side. We taxied back and he took off. At about 1500'agl he tapped me on the shoulder (I was looking outside for traffic). He said "we have a problem". There had been no apparent change in the flight so I thought he might be joking. He pointed down at the throttle and he was moving it full to idle and back, but it had no effect! We were still at full throttle and obviously we had a broken cable or something similar. So your mind goes rapidly over the situation. How bad is this? What are the challenges? What are the options? We had a brief discussion and I mentioned that although this didn't seem real bad, we had some risks and I had read so many stories of pilots being reluctant to declare an emergency. We were only about 5 miles from Camarillo, our home airport which has a 5000' runway. We discussed and within about 20 seconds agreed that I would fly the plane since I was left seat, he would handle radio, and we would declare and emergency since we did not have throttle control. We had decided that I would try to modulate power with the mixture, but if necessary I could fly over the the airport and then just kill the engine and we would glide down. The weather was very clear and it was just about dusk. My partner called Camarillo tower, reported our position (about 5 miles out) and indicated we had a throttle problem and we needed to declare and emergency. The tower immediately cleared us to land on runway 8 and cleared out one other plane in the pattern. The runway in use was 26 but it was calm and rwy 8 was the closer approach. I was at about 1700' and full power; I leveled off and flew at about yellow line toward the airport. As I got closer I started a dive to lose altitude and flew fast; I had not yet adjusted the mixture. I realized that I was going to be quite high - I was on a 1 mile base so I began to pull the mixture back and the engine roughened as it slowed down some more. Still flying fast, I descended. I realized I was still pretty high so I overshot the centerline a bit before turning to about a ..5 mile final to lose some more altitude. I leaned the mixture more aggressively and the engine ran really rough with some backfiring. As we came in a bit high on final and I knew the runway was assured I asked my partner for flaps. I leaned more aggressively and the engine was really choking now. As we came over the threshold a bit high I told my partner I was going to kill the engine. I didn't want to be trying to modulate a full throttle enging with mixture once I was on the runway. About 20 feet or so I pulled to idle cutoff and it was weird to see a prop stopped as I flared for a nice landing. I rolled out and used residual speed to pull off on a turnoff and coast to a stop. Airport security showed up and the guy didn't quite know what to do. We told him we just needed a tow into our tiedown spot. He took our names and certificate numbers and a brief statement of what had happened. In discussion with my partner, we felt we did almost everything correctly. We did not panic, we did not hesitate to declare the emergency, we quickly agreed on roles and everything went smoothly. We never really felt scared about the situation (a power failure might have felt different!). When the situation first presented itself I thought about flying to over the airport and cutting power, but I felt it would be better not to have a guaranteed engine failure. We both felt this was the less-risky way to handle the situation. We sort of stood there saying to ourselves "we can't believe we just had an emergency!". It was the first one for both of us in more than 20 years of flying each. The plane is in the shop to get its cable replaced, apparently it broke somewhere between the throttle quadrant and the carburetor, not at either end. Event Horizon |
First emergency
"EventHorizon" wrote We sort of stood there saying to ourselves "we can't believe we just had an emergency!". It was the first one for both of us in more than 20 years of flying each. The plane is in the shop to get its cable replaced, apparently it broke somewhere between the throttle quadrant and the carburetor, not at either end. Sounds like you did a good job of handling the situation. I am glad everything worked out well. -- Jim in NC |
First emergency
"EventHorizon" wrote in message . 12.10... We were still at full throttle and obviously we had a broken cable or something similar. Were you truly at full throttle? While flying towards home and a longer runway would be tempting, I would not be comfortable flying at takeoff power for some 45 minutes. Your engine is likely not made to do that. Two minor things that you did not mention: You could have at least slightly reduced your power with carb heat. Switching off one mag should reduce power by a further small amount. To keep your engine from overheating, 90% power is far better that 100% power. I am glad that it worked out for you! Vaughn |
First emergency
On 09/07/09 22:33, EventHorizon wrote:
I thought you might all find this story interesting. I'm sure glad everything worked out for you. Did you consider that with no throttle control, the engine could have gone to idle as well as remained at full power? I'm not sure I would have flown to another airport - but I'm Monday Quarterbacking! :-) Best Regards, and thanks for sharing with us! -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
First emergency
"Mark Hansen" wrote Did you consider that with no throttle control, the engine could have gone to idle as well as remained at full power? I could be wrong, but I have been told that aircraft engines have a spring on the throttle that causes the engine to go to full power rather than idle if a cable or linkage breaks, just to prevent going to no power at the "wrong time." As the story is told in this incident, it is easier to deal with too much power than no power. So, is this true, wrench turn-ers out there? -- Jim in NC |
First emergency
"vaughn" wrote in
: "EventHorizon" wrote in message . 12.10... We were still at full throttle and obviously we had a broken cable or something similar. Were you truly at full throttle? While flying towards home and a longer runway would be tempting, I would not be comfortable flying at takeoff power for some 45 minutes. Your engine is likely not made to do that. This only took about 5 minutes. Yes, we were at full throttle. Two minor things that you did not mention: You could have at least slightly reduced your power with carb heat. Switching off one mag should reduce power by a further small amount. To keep your engine from overheating, 90% power is far better that 100% power. Good points. My partner and I just mentioned the one mag idea and that is a good one. I hadn't thought about carb heat, that's another good idea. I am glad that it worked out for you! Vaughn |
First emergency
Mark Hansen wrote in news:b16ac$4aa68361$414ebc3d
: On 09/07/09 22:33, EventHorizon wrote: I thought you might all find this story interesting. I'm sure glad everything worked out for you. Did you consider that with no throttle control, the engine could have gone to idle as well as remained at full power? I'm not sure I would have flown to another airport - but I'm Monday Quarterbacking! :-) Best Regards, and thanks for sharing with us! We hadn't thought of the throttle going down to idle. Since we were at full there was a lot of vibration and we assumed that it was going to stay stuck in that condition, which was what happened. |
First emergency
On 09/08/09 19:06, Morgans wrote:
"Mark Hansen" wrote Did you consider that with no throttle control, the engine could have gone to idle as well as remained at full power? I could be wrong, but I have been told that aircraft engines have a spring on the throttle that causes the engine to go to full power rather than idle if a cable or linkage breaks, just to prevent going to no power at the "wrong time." As the story is told in this incident, it is easier to deal with too much power than no power. So, is this true, wrench turn-ers out there? At the time of the emergency, was what broke precisely known? My point was that without knowing, I think I would have assumed that the engine would not continue running. Again, this is Monday-morning quarterbacking, which isn't exactly fair to the OP. He was there, I was not. -- Mark Hansen, PP-ASEL, Instrument Airplane, USUA Ultralight Pilot Cal Aggie Flying Farmers Sacramento, CA |
First emergency
I think you did fine.
2,000 hour CFI retired. "EventHorizon" wrote in message . 12.10... I thought you might all find this story interesting. Me, I'm 53 and have been flying since 1988 with about 1000 hrs. My partner is a CFI and we've been in a Cherokee 140 partnership for about 12 years. We have a 1974 Cherokee Cruiser, which we normally keep well maintained (!). About a week ago my partner and I decided to fly after work. We are still breaking in a new cylinder so we thought we'd fly local here in Southern California. I flew left seat and we took off from Camarillo and flew around Malibu, then I flew over to Santa Paula for a landing. We had agreed we wanted to fly about 1.5 hrs, so as I was landing at Santa Paula I was at about 45 minutes. After I landed I asked my partner if he wanted to switch sides, but he said no, he'd fly from the right side. We taxied back and he took off. At about 1500'agl he tapped me on the shoulder (I was looking outside for traffic). He said "we have a problem". There had been no apparent change in the flight so I thought he might be joking. He pointed down at the throttle and he was moving it full to idle and back, but it had no effect! We were still at full throttle and obviously we had a broken cable or something similar. So your mind goes rapidly over the situation. How bad is this? What are the challenges? What are the options? We had a brief discussion and I mentioned that although this didn't seem real bad, we had some risks and I had read so many stories of pilots being reluctant to declare an emergency. We were only about 5 miles from Camarillo, our home airport which has a 5000' runway. We discussed and within about 20 seconds agreed that I would fly the plane since I was left seat, he would handle radio, and we would declare and emergency since we did not have throttle control. We had decided that I would try to modulate power with the mixture, but if necessary I could fly over the the airport and then just kill the engine and we would glide down. The weather was very clear and it was just about dusk. My partner called Camarillo tower, reported our position (about 5 miles out) and indicated we had a throttle problem and we needed to declare and emergency. The tower immediately cleared us to land on runway 8 and cleared out one other plane in the pattern. The runway in use was 26 but it was calm and rwy 8 was the closer approach. I was at about 1700' and full power; I leveled off and flew at about yellow line toward the airport. As I got closer I started a dive to lose altitude and flew fast; I had not yet adjusted the mixture. I realized that I was going to be quite high - I was on a 1 mile base so I began to pull the mixture back and the engine roughened as it slowed down some more. Still flying fast, I descended. I realized I was still pretty high so I overshot the centerline a bit before turning to about a .5 mile final to lose some more altitude. I leaned the mixture more aggressively and the engine ran really rough with some backfiring. As we came in a bit high on final and I knew the runway was assured I asked my partner for flaps. I leaned more aggressively and the engine was really choking now. As we came over the threshold a bit high I told my partner I was going to kill the engine. I didn't want to be trying to modulate a full throttle enging with mixture once I was on the runway. About 20 feet or so I pulled to idle cutoff and it was weird to see a prop stopped as I flared for a nice landing. I rolled out and used residual speed to pull off on a turnoff and coast to a stop. Airport security showed up and the guy didn't quite know what to do. We told him we just needed a tow into our tiedown spot. He took our names and certificate numbers and a brief statement of what had happened. In discussion with my partner, we felt we did almost everything correctly. We did not panic, we did not hesitate to declare the emergency, we quickly agreed on roles and everything went smoothly. We never really felt scared about the situation (a power failure might have felt different!). When the situation first presented itself I thought about flying to over the airport and cutting power, but I felt it would be better not to have a guaranteed engine failure. We both felt this was the less-risky way to handle the situation. We sort of stood there saying to ourselves "we can't believe we just had an emergency!". It was the first one for both of us in more than 20 years of flying each. The plane is in the shop to get its cable replaced, apparently it broke somewhere between the throttle quadrant and the carburetor, not at either end. Event Horizon |
First emergency
The decision to go to CMA instead of circling back to SZP was a good one. All sorts of advantages - tower, emergency
equipment, Looooong runway, no hills too close, etc. Congrats a a job well done! "EventHorizon" wrote in message . 12.10... Mark Hansen wrote in news:b16ac$4aa68361$414ebc3d : On 09/07/09 22:33, EventHorizon wrote: I thought you might all find this story interesting. I'm sure glad everything worked out for you. Did you consider that with no throttle control, the engine could have gone to idle as well as remained at full power? I'm not sure I would have flown to another airport - but I'm Monday Quarterbacking! :-) Best Regards, and thanks for sharing with us! We hadn't thought of the throttle going down to idle. Since we were at full there was a lot of vibration and we assumed that it was going to stay stuck in that condition, which was what happened. |
Similar Threads | ||||
Emergency | Dan Luke | Piloting | 57 | April 12th 06 02:01 PM |
EMERGENCY AIR PUMPS | [email protected] | Soaring | 7 | January 30th 06 11:29 PM |
Emergency airports | Paul kgyy | Piloting | 7 | November 2nd 05 10:44 PM |
Emergency Procedures | RD | Piloting | 13 | April 11th 04 08:25 PM |
Not an emergency??? | William W. Plummer | Instrument Flight Rules | 14 | December 26th 03 06:28 AM |
