Not an emergency???
Old December 19th 03, 01:19 AM
William W. Plummer
Default Not an emergency???
Has any pilot ever been prosecuted (by the FAA, NTSB, ...) for declaring an
emergency when, in some experts opinion, one did not exist? [Reference:
decending through icing layer while short on fuel]
Old December 19th 03, 08:08 AM
Ben Jackson
In article ZmsEb.146587$_M.719680@attbi_s54,
I went to an aviation safety seminar about declaring emergencies recently.
A local FSDO guy said a few words at the beginning. He emphasized that
the reports for flight assists (emergencies) all go to him and it's the
FSDO's policy not to start an enforcement action based on an emergency.
He was very clear that they didn't want to do anything to discourage pilots
from getting help when they need it.
Ben Jackson
http://www.ben.com/
Old December 19th 03, 02:23 PM
tscottme
William W. Plummer wrote in
message news:ZmsEb.146587$_M.719680@attbi_s54...
declaring an
[Reference:
I participated in a research project a few years ago concerning this
issue. After the experiments, the person doing the research indicated
he had not been able to find any enforcement action against a pilot for
unnecessarily declaring an emergency. Nearly all of the pilot
participating in the project has tried to avoid declaring and talked
around the issue with ATC with bad results.
I've not seen any reason to avoid declaring when there is a possibility
of needing help. My rule would be, if you start thinking if you should
declare or not, do it. It's unlikely there will even be paperwork
unless there are serious injuries or damage.
Scott
If George W. Bush announced that a cure for cancer had been discovered,
Democrats would complain about unemployed laboratory rats.
Ann Coutler
Old December 19th 03, 04:05 PM
C J Campbell
"William W. Plummer" wrote in message
an
You are much more likely to face action for declaring an emergency when the
emergency is of your own making. Still, you should not hesitate to declare
an emergency if one arises.
Old December 19th 03, 11:55 PM
Doug
I had one magneto fail totally at NIGHT in VFR. I declared an
emergency although it turned out I really didn't have to. I declared
it on Center frequency, and received flight following as well as
assistance in deciding which airport to proceed land at (the nearest
or the nearest with a mechanic). After landing without mishap, I had
it repaired. I received a very pleasant letter from ATC telling me
they were more than willing to help me out. I wrote them back a letter
thanking them and informing them of the outcome (the magneto was
indeed faulty, etc). More knowledgable pilots than I, have told me it
wasn't really an emergency. It felt like one to me, and I think that
is important. I, as Pilot in Command, truly felt like I was going to
have to land off field at night, therefore I declared an emergency.
The fact that I did not have to land off field and the fact that the
plane was capable of continuing the flight without mishap was not a
factor. So here is one example of a pilot declaring an emergency,
because he THOUGHT he had one, and getting ATC assistance with no
negative reprecussions. My impression was the ATC division wanted a
thankyou letter to show to their supervisors to show how needed they
are, which, indeed they are! They received that from me. Least I could
do. That was the extent of the paperwork. Thank you ATC. Thank you
FAA.
So I would say, if you think you have an emergency, and you think
declaring it to ATC would be helpful, do it. No one is going to
prosecute you. Obviously a pilot declaring phony emergencies would be
liable for some ATC certificate action, but I don't think any of us
would do that. And if one of us did, I would support the action
against him.
You are PIC and you have to decide. No one expects your decisions to
be perfect. But they do expect your intentions to be honorable.
A stuttering engine can be a gut wrenching scary experience, and if
you need help, even if it just means someone to talk to, then do get
on the radio and start asking for assistance. ATC is trained in
assisting you and they display that attitude. This was also true of
the other pilots on frequency. No one is going to knock you down for
seeking help so long as you truly think you need it.
"C J Campbell" wrote in message ...
an
Old December 24th 03, 02:57 PM
Marco Leon
I for one think you did the right thing. There are two sides to an
mechanical failure emergency--the mechanical failure itself and the ability
of the pilot to handle that failure. If you had serious doubts about the
ability to handle the situation, then it truly was an emergency. I'm sure
there are test pilots out there that fail one system or another on a regular
basis and can handle most type of failures. These pilot may not consider
many mechanical failures emergencies where the majority of the pilot
population would find themselves in a world of hurt given the same
situation.
Marco
"Doug" wrote in message
om...
FAA.
against him.
message
declaring
an
[Reference:
declare
Posted Via Usenet.com Premium Usenet Newsgroup Services
** SPEED ** RETENTION ** COMPLETION ** ANONYMITY **
http://www.usenet.com
Old December 24th 03, 05:17 PM
Robert Moore
an mechanical failure emergency--the mechanical failure itself
and the ability of the pilot to handle that failure. If you had
serious doubts about the ability to handle the situation, then
it truly was an emergency. I'm sure there are test pilots out
there that fail one system or another on a regular basis and can
handle most type of failures. These pilot may not consider many
same situation.
As a Naval Aviator, I flew the Lockheed P-3 Orion on 10-12 hour
patrols. After about 2 hours, we shut-down (feathered) the number
one engine and after 2-3 more hours, off went number four for the
remainder of the flight. All of this at 100' to 500'. Certainly
wasn't an emergency to us but for the average airline pilot flying
the same basic airplane (Electra), this would have been an emergency
for sure.
Bob Moore
VP-46 (1965-1967)
Old December 24th 03, 06:37 PM
Matthew S. Whiting
same situation.
for sure.
Yes, having a plane load of passengers isn't quite the same as a plane
with a military crew. The military by necessity accepts risks every day
that would be unacceptable to civilian commercial aviation.
Matt
Old December 24th 03, 07:23 PM
Andrew Gideon
Why? I was thinking perhaps "for fuel economy", but then why wait?
- Andrew
Old December 24th 03, 08:02 PM
Roy Smith
Why the staggered shutdown? Waiting to hit certain weight limits as
fuel burned off?
Once you had shut down two engines, what would happen if one of the
remaining two failed? Was the airplane capable of flying on one?
Emergency Parachute questions Jay Moreland Aerobatics 14 December 3rd 04 05:46 PM
For Auction, Emergency Parachute JC Cunningham Aerobatics 0 June 16th 04 02:47 PM
FA: Emergency Parachute JC Cunningham Aerobatics 0 June 11th 04 09:45 PM
FS, Emergency parachute JC Aerobatics 0 March 22nd 04 09:51 PM
Jon Johanson..Long delete if not interested Jerry Springer Home Built 0 December 21st 03 05:55 PM
