#11
They _are_ being driven by air pressure. The air is sucked in from the cabin
and through an air filter by the vacuum generated by the pump (or venturi). The filter is inside the cabin. This setup comes from the fact that when faced with the choice of air from the outside (or from the engine compartment), or air sucked in from the cabin using the vacuum generated by a venturi or pump, the latter is considered more suitable to contribute to a longer instrument working life. "Jim Carriere" wrote in message ... This is one of those questions where there must be a simple answer. This is probably the forum to get the best explanation. Why aren't vacuum driven gyro instruments driven by pressure instead? The reason I'm wondering is because about 2" of suction is sufficient to power a turn needle, and while attitude gyros require more, about 5", either of those amounts is still much less than standard atmospheric pressure, meaning that the absolute pressure inside the instrument is still close to ambient pressure. Note other than seeing one on an instrument panel, I've never actually taken apart or looked at the inside of any of these instruments. In other words, what am I missing and what don't I understand? Thanks! |
Similar Threads | ||||
Wet vs Dry Vacuum Pump | Fastglasair | Home Built | 1 | December 15th 04 05:17 PM |
Wet Vacuum Pumps | DBlumel | Home Built | 4 | August 19th 04 08:27 AM |
Newbie Question - Vacuum vs Electric | Bill Denton | Aerobatics | 1 | April 15th 04 11:30 PM |
Gyro Copter for Sale on EBAY | EC155 Pilot | Home Built | 0 | November 1st 03 11:34 PM |
NACA duct ventrui | Chris W | Home Built | 7 | October 27th 03 04:11 PM |
