AH64 tail rotor
Old October 23rd 03, 08:02 AM
CivetOne
Default AH64 tail rotor
Hi Tim,
When Hughes Tool Co., Aircraft Division experimented with the OH-6A to make it
very quiet, the engineers knew that a big source of noise was the tail rotor.
To make the tail rotor quieter, they decided to increase the blade area and
decrease the rpm. The most convenient (i.e., least costly) method was to
simply add another set of teetering blades to the tail rotor.
In addition to the addition of more blades, Hughes engineers experimented with
blade phasing to decrease the noise level as much as possible. As I remember,
the phasing they decided upon was about 45 deg.
When the AH-64 Apache came along, the Hughes engineers incorporated what they
had learned from the OH-6A development work. The same basic design for the
tail rotor of the quiet OH-6A was incorporated into the Apache design; two
pairs of teetering rotor blades. The same concept was used on the 4-bladed
tail rotor option on the MD 500D, E, and FF series of helicopters.
The one additional requirement for the Apache was to fit into a C-130 transport
without disassembling the rotors. In order to meet this requirement, the tail
rotor blade spacing was changed to the 30 deg spacing you found. The noise
signature suffered a litttle bit, but the transportaion requirement was met.
Old October 23rd 03, 10:33 AM
Tim
"CivetOne" wrote in message
Hi Tim,
make it
rotor.
and
with
remember,
they
4-bladed
transport
tail
noise
met.
Thanks for that. Just got to work out how to incorporate that into an R/C
replica...
Outgoing mail is certified Virus Free.
Checked by AVG anti-virus system (http://www.grisoft.com).
Version: 6.0.529 / Virus Database: 324 - Release Date: 16/10/2003
Old October 23rd 03, 02:17 PM
sean trost
yup what he said.
Good info.
all the best Sean "Apache driver in my dreams" Trost
CivetOne wrote:
Hi Tim,
Old October 23rd 03, 07:18 PM
mm
The Apache tail rotor is, as you note, actually a pair of stacked tow-bladed
teetering rotors. There have been claims that the unusual blade spacing
you're asking about was intended to reduce noise. While the spacing may
give some noise benefit, the real reason for the orientation is simple: it
was how the blades would fit. If you look at an Apache tail closely you
will see that if you tried to orient the outboard rotor at 90 degs from the
inboard rotor, the pitch links for the outboard rotor would interfere with
the inboard blades. (The interference geometry is largely a result of the
skewed teeter hinge, which is needed to get the desired pitch-flap coupling.
This pitch-flap coupling reduces the flapping of the tail rotor in rotor
flight.)
"Tim" wrote in message
Hi,
Please can anyone explain to me what the tail rotor on the AH64 Apache is
all about? I see that the two pairs of blades are actually in different
planes and only at about 30degrees spacing.
What's the thinking behind this?
(I'm into radio controlled helicopters and considering how/whether to
replicate this on a model)
Thanks,
Tim
Tail flapper failure Veeduber Home Built 2 May 22nd 04 06:52 AM
High-altitude autorotations? Bill McClain Military Aviation 17 March 15th 04 04:23 PM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Owning 1 July 26th 03 11:34 AM
Oshkosh Get together Roster - Sign in, please! Bruce E. Butts Piloting 1 July 26th 03 11:34 AM
The prone postion for tail gunners versus turrets. The Enlightenment Military Aviation 8 July 22nd 03 11:01 PM
