#41
Gary Drescher wrote: "Newps" wrote in message ... Gary Drescher wrote: Oh, ok. Is 'priority' a technical term for ATC? In ordinary language, minimizing delays (to a greater extent than for ordinary flights) would be a form of priority (though perhaps not as high as the priority afforded to some other flights). Angel Flight means nothing to ATC, most controllers don't even know what it is. And why would you put it in the remarks and not just use the three letter ID allocated to Angel Flight(NGF)? Uh, I wouldn't. That's why I was asking specifically about the use of the Angel Flight call sign (which is obviously supposed to mean something to ATC--they don't think it's a type of airplane, do they?). ATC would most likely ignore the remark Angel Flight. If you used the three letter ID ATC would still ignore it other than having to look up just what in the hell "NGF" stands for. There's a gazillion three letter ID's that the FAA has authorized, some sound similar to angel flight. ATC will see it as just another name. |
#42
... If you used the three letter ID ATC would still ignore it other than having to look up just what in the hell "NGF" stands for. There's a gazillion three letter ID's that the FAA has authorized, some sound similar to angel flight. ATC will see it as just another name. We're told to say "Angel Flight 123", not "November Golf Foxtrot 123". Is that not what ATC expects to hear? --Gary |
#43
"Jose" wrote in message m... Then on what basis to you make the following statement? Same basis as usual, simple logic. FAA Order 7110.65 requires controllers to provide services on a "first come, first served" basis, as circumstances permit, except for a few exceptions where certain operators are given priority over others. Angel Flight is NOT one of those exceptions. So if a controller gives a flight priority handling based on an Angel Flight call sign he is acting contrary to FAA Order 7110.65. And on that same basis, how do you answer my subsequent question relating to otherwise equal consideration? If two otherwise equal aircraft are a dead ass tie, that is, same speed, same time over a fix, similar distances to go to their destinations, no other aircraft to be concerned about, etc., etc., etc., then at least one of them must be turned or it's altitude changed to ensure separation. If neither of them is afforded operational priority by FAAO 7110.65 the decision of which to move is completely arbitrary. It could be decided by a coin toss. If one of the aircraft in that situation is an Angel Flight, I'd move the other one and leave the coin in my pocket. That's not the same as affording an aircraft, such as a Lifeguard, operational priority over other aircraft. We don't use the "first come, first served" rule with a Lifeguard or other aircraft that are afforded operational priority. For example, if another aircraft is naturally ahead of a Lifeguard for an IAP but it's approach would delay the Lifeguard, the other aircraft is moved and the Lifeguard goes first. |
#44
Newps wrote:
Angel Flight means nothing to ATC, most controllers don't even know what it is. And why would you put it in the remarks and not just use the three letter ID allocated to Angel Flight(NGF)? Angel Flight Mid Atlantic instructs its pilots to use the Angel Flight call sign and file a flight plan (N1701D becomes NGF01D and the call sign is "Angel Flight Zero One Delta) and to put the actual registration number into the remarks as follows: N1701D ANGEL FLIGHT MID ATLANTIC I don't have any idea what, if anything, it means to ATC. I do it. I think I may have been given some consideration in choice of altitudes for example, because of the AF call sign. Can't prove it, though. Dave |
#45
Thanks Steven, that explains it to me.
Getting ahead in a dead ass tie is worth something, maybe worth something in the remarks section. Are there many dead ass ties in your sector? Jose -- "Never trust anything that can think for itself, if you can't see where it keeps its brain." (chapter 10 of book 3 - Harry Potter). for Email, make the obvious change in the address. |
#46
"Jose" wrote in message ... Thanks Steven, that explains it to me. Getting ahead in a dead ass tie is worth something, maybe worth something in the remarks section. Angel Flight is properly designated by filing and use of the Angel Flight call sign. Are there many dead ass ties in your sector? Hell no, there aren't that many airplanes in my sector. |
#47
Dave Butler wrote in news:1119016948.514089@sj-nntpcache-3:
Newps wrote: Angel Flight means nothing to ATC, most controllers don't even know what it is. And why would you put it in the remarks and not just use the three letter ID allocated to Angel Flight(NGF)? Angel Flight Mid Atlantic instructs its pilots to use the Angel Flight call sign and file a flight plan (N1701D becomes NGF01D and the call sign is "Angel Flight Zero One Delta) and to put the actual registration number into the remarks as follows: N1701D ANGEL FLIGHT MID ATLANTIC I don't have any idea what, if anything, it means to ATC. I do it. I think I may have been given some consideration in choice of altitudes for example, because of the AF call sign. Can't prove it, though. Dave Many times I've received flight following with the Angel Flight call sign while everyone else was being told "unable". -- Marty Shapiro Silicon Rallye Inc. (remove SPAMNOT to email me) |
#48
Gary Drescher wrote: "Newps" wrote in message ... If you used the three letter ID ATC would still ignore it other than having to look up just what in the hell "NGF" stands for. There's a gazillion three letter ID's that the FAA has authorized, some sound similar to angel flight. ATC will see it as just another name. We're told to say "Angel Flight 123", not "November Golf Foxtrot 123". Is that not what ATC expects to hear? Yes. |
Similar Threads | ||||
The things Bush didn't mention in his speech | Ewe n0 who | Naval Aviation | 1 | May 26th 04 04:04 PM |
The things Bush didn't mention in his speech | Ewe n0 who | Military Aviation | 0 | May 26th 04 02:10 PM |
Things I Have Learned As First Time Buyer/Owner (long) | MRQB | Owning | 12 | April 19th 04 02:12 PM |
making the transition from renter to owner part 2 (long) | Journeyman | Piloting | 2 | April 15th 04 10:19 PM |
31 things that are really true about Fighter pilots | Big John | Piloting | 5 | November 28th 03 05:33 PM |
