Front Electric Sustainer
Old April 19th 10, 03:28 PM posted to rec.aviation.soaring
Martin Gregorie[_5_]
Default Front Electric Sustainer
On Mon, 19 Apr 2010 06:23:36 -0700, Dave Nadler wrote:
http://antwrp.gsfc.nasa.gov/apod/ap100419.html
True enough: the ASW's smaller multi-blade pros disk makes the problem
proportionately worse while about the only extra downside on the Antares
is interference drag between the pylon legs.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Old April 19th 10, 07:48 PM posted to rec.aviation.soaring
Dave Nadler
On Apr 19, 10:28*am, Martin Gregorie
... while about the only extra downside on the Antares
Actually I forgot the usual pusher-problem:
the wake from the pylon hits the prop.
I suspect (not expert enough to know)
the wake interference makes most of the
(minimal) noise you hear from an Antares.
Tractor would be more efficient but
didn't fit in the optimal fuselage shape.
Any aero experts care to comment ?
See ya, Dave "YO electric"
Old April 19th 10, 09:46 PM posted to rec.aviation.soaring
On Mon, 19 Apr 2010 11:48:46 -0700, Dave Nadler wrote:
Actually I forgot the usual pusher-problem: the wake from the pylon hits
the prop. I suspect (not expert enough to know) the wake interference
makes most of the (minimal) noise you hear from an Antares. Tractor
I don't think it can be very significant in prop efficiency terms of
Martin Hepperle would have picked up on it and insisted on using a single
blade pylon.
I do have a comment on noise: the day I mentioned when the ASW22 and the
Antares launched at a fairly similar time was a calm, fairly quiet day
apart from the usual sounds when a grid is being launched: all the tugs
on the field had 4 blade props and silencers. I happened to be standing
about 50m to one side of the runway and about 100 m in front of the grid
when the Antares took off. The only sound I remember hearing from it was
a sort of puttering sound which was almost certainly from the prop tips.
org |
Front Electric Sustainer LimaZulu Soaring 25 November 3rd 09 02:25 PM
The HPH 304S Turbine sustainer glider kd6veb Soaring 2 September 23rd 09 05:10 AM
would an electric sustainer be practical Brad[_2_] Soaring 7 July 24th 09 06:29 PM
Sustainer engine ignition noise (Solo2350) Per Soaring 8 January 4th 07 05:56 AM
DG goes the sustainer option. Paul Soaring 25 June 4th 04 12:16 AM
