Go Back   Home » AviationBanter forum » rec.aviation newsgroups » Aerobatics
Blunt Trailing Edges
Old July 27th 05, 10:17 AM
Default Blunt Trailing Edges
Hi All,
Many modern aerobatic aircraft have blunt trailing edges on the wing and
ailerons. Can someone tell me:
1. Why it this done - what are the benefits and side effects. There is a lot
of contradictory information on the web and I simply cannot get to the
bottom of it.
2. What is theory behind it (a technical explanation please - I am an aero
engineer and understand aerodynamics and stability and control etc).
3. Who was the first to do it.
I have looked in all kinds of text books on stability and control and none
of them address the issue. This type of trailing edge appears to be unique
to aerobatic aircraft.
Thanks,
Steve
Old August 1st 05, 06:20 AM
djpacro
Go to the NACA report server and search for airfoil trailing edge.
http://naca.larc.nasa.gov/
Different airfoil sections but you should see the origins of claims for
improved lift curve slope, control effectiveness and changes to hinge
moments.
Old February 9th 06, 02:07 AM posted to rec.aviation.aerobatics
here is what I have read somewhere.
Blunted trailing edges on the wings such as are found on the Extra
series of aircraft where I believe this practice was first undertaken
cause a delay in the stall. Something to do with the turblence and the
associated vacuum causing a delay in separation. To the best of my
knowledge the idea was explored in Germany during the 40's(?). Having
looked at these aircraft up close these blunted trailing edges are 1/4
thick at most and I gather their effect is significant or I suspect Mr.
Extra would have done something else.
Cheers
.......... :-)) wrote:
Hi All,
bottom of it.
Thanks,
Steve
Old February 9th 06, 06:45 PM posted to rec.aviation.aerobatics
Thanks for the update!
Last summer I had the chance to have a look at the SP-55 up close and the
trailing edges of all flying surfaces where extremely thick. From 1/4 inch
on the wingtip (or elevator/rudder) to more than 1 inch on the wing root. I
was wondering what this is for and the russian engieneer I asked couldn´t
answer...
Cheers
schrieb im Newsbeitrag
Blunted trailing edges on the wings such as are found on the Extra series
of aircraft where I believe this practice was first undertaken cause a
delay in the stall. Something to do with the turblence and the associated
vacuum causing a delay in separation. To the best of my knowledge the idea
was explored in Germany during the 40's(?). Having looked at these
aircraft up close these blunted trailing edges are 1/4 thick at most and I
gather their effect is significant or I suspect Mr. Extra would have done
something else.
Cheers
Old February 17th 06, 04:23 PM posted to rec.aviation.aerobatics
I believe this helps with rapid centering of the control, minimizes control
surface overshoot, and allows the pilot to "feel" the center better.
Cheers
Hi All,
lot
bottom of it.
aero
none
unique
Thanks,
Steve
Squared trailing edge of control sufraces Bruce A. Frank Home Built 7 August 10th 05 09:16 PM
Consistant trailing edges on rotor blades 3D-Don Rotorcraft 1 October 24th 03 06:07 AM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 02:31 AM
Old Cessna 172 --- Cracks in Flap Trailing Edges Larry Smith Owning 2 September 19th 03 01:17 PM
FS: Aviation History Books Neil Cournoyer Military Aviation 0 August 26th 03 08:32 PM
