Old Cessna 172 --- Cracks in Flap Trailing Edges
Old September 18th 03, 10:50 PM
Larry Smith
Default Old Cessna 172 --- Cracks in Flap Trailing Edges
How are these things being repaired, with a 1"-wide aluminum sheet doubler
sandwiched between the corrugated skins? That's what one of the IA's here
suggests, other than replacing the skins, which would cost an arm and a leg.
TIA.
Old September 19th 03, 12:16 AM
Dale
In article , "Larry Smith"
Another option (more expensive) would be to install the trailing edge bead sold
by BAS I think. It stiffens the trailing edge and helps to prevent cracks,
dents, bends. About $80 to $100 bucks for the two beads then the labor to split
the skins and install them.
Dale L. Falk
There is nothing - absolutely nothing - half so much worth doing
as simply messing around with airplanes.
http://home.gci.net/~sncdfalk/flying.html
Old September 19th 03, 01:17 PM
Larry Smith
"Dale" wrote in message
doubler
here
leg.
sold
cracks,
split
Dale L. Falk
Thanks. I believe that's the way we'll go and I found the trailing edge
bead at McFarlane's and Aircraft Spruce.
Cessna buyers in So. Cal. beware ! Bill Berle Aviation Marketplace 93 December 20th 04 02:17 PM
Cessna buyers in So. Cal. beware ! Bill Berle Home Built 73 June 25th 04 04:53 AM
FORSALE: HARD TO FIND CESSNA PARTS! Enea Grande Aviation Marketplace 1 November 4th 03 12:57 AM
Crooked or Wavy Trailing Edges of Wings and Control Surfaces Larry Smith Home Built 3 October 24th 03 02:31 AM
