Check your wheel bolts
Today a Pawnee had a wheel bolt lose its nut and back out of the wheel
enough to strike the brake caliper. I know of two other ocasions where this locked the wheel leading to a groundloop and to severe damage to the tug. In this instance, the bolt bent about 45 degrees producing a loud ticking from the wheel which called attention to the problem. It's a good idea to check the nuts on wheel bolts each preflight. It's an aeronautical tradition to install bolts with the heads up, forward or outboard depending on the location such that gravity will tend to keep the bolt in place if the nut is lost. If the bolt heads had been on the outboard side of the wheel, it wouldn't have been possible for them to strike the caliper. Unless the maintenance manual says otherwise, I'd suggest installing wheel bolts with the heads outboard. |
Similar Threads | ||||
MS20074-05-24 bolts | Stuart & Kathryn Fields | Home Built | 37 | January 11th 08 01:06 AM |
Needed 4 socket cap bolts | Udo | Soaring | 2 | November 29th 07 02:21 PM |
Torque for prop bolts | Scott | Home Built | 15 | August 29th 06 02:58 PM |
Oversized bolts | Kjell Sivertsen | Owning | 7 | April 14th 05 05:02 AM |
Source for Bolts | Dave | Home Built | 2 | May 20th 04 08:09 PM |
