Attitude Indicator
Old October 5th 06, 10:44 PM posted to rec.aviation.ifr
KP
Default Attitude Indicator
Every time I get in the aircraft and before I start the engine I notice
the attitude indicator is displaying a nose down and a left turn. Why
is that? Is there something wrong with the instrument and is near
failure?
KP
Old October 5th 06, 10:50 PM posted to rec.aviation.ifr
Bob Gardner
Your only concern should be whether or not it erects properly within a
decent interval...by the time you are taxiing, for example. When the vacuum
pump stops providing the force necessary to spin the gyro it is going to
come to rest in some unpredictable way.
Next time you shut the engine off, however, don't leave the cockpit for a
few moments, and listen to the gyros as they spin down...if there is any
kind of mechanical problem, you will hear it.
Bob Gardner
"KP" wrote in message
failure?
KP
Old October 6th 06, 03:51 PM posted to rec.aviation.ifr
Andrew Sarangan[_1_]
failure?
KP
It is a gyroscopic instrument powered by vacuum or electric. When there
is no power, it is not going to work.
Old October 6th 06, 04:41 PM posted to rec.aviation.ifr
You just described the expected behavior. Why is this surprising to
you?
Are you expecting the AI to jump to level when you turn the master on?
-harry
Old October 8th 06, 09:55 PM posted to rec.aviation.ifr
Bill[_4_]
It is weighted slightly off center to make up for the coriolis
acceleration due the rotation of the earth.
The weight makes it precess as required to appear to
be level.
And the erection mechanism is as others have pointed out...
takes the average downward vector and calls that level.
Bill Hale
you?
-harry
Old October 9th 06, 08:45 PM posted to rec.aviation.ifr
KP writes the AI's orientation is predictable, ie nose down and left
turn.
Bob, should we really expect an unpredictable way, as you write?
Stan
On Thu, 5 Oct 2006 14:50:47 -0700, "Bob Gardner"
When the vacuum
Bob Gardner
roups.com...
KP
Trust those Instruments.... Trust those Instruments..... A Lieberman Instrument Flight Rules 1 May 2nd 06 03:54 PM
?? Lift Reserve Indicator ?? Montblack Piloting 16 February 15th 06 05:43 PM
?? Lift Reserve Indicator ?? Montblack Home Built 16 February 15th 06 05:43 PM
Cool attitude indicator Jay Honeck Piloting 32 April 13th 05 05:32 PM
Looking for Cessna Caravan pilots [email protected] Owning 9 April 1st 04 02:54 AM
