?? Lift Reserve Indicator ??
Old February 13th 06, 07:28 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Default ?? Lift Reserve Indicator ??
First time I've stumbled across one of these:
http://home.hiwaay.net/~sbuc/journal/liftreserve.htm
"One of the AOA systems that has been around the longest is the Lift Reserve
Indicator. This unit was developed in the 1970's and has been offered in a
couple of different variations since then. There is considerable controversy
over just what the LRI actually measures and how it operates, but when the
price of the analog unit was recently reduced substantially, it got my
attention. Since the panel of 399SB is rather unconventional, I had included
a small backup airspeed indicator. However, the AI was never used since I
rely on the RMI uEncoder for pitot info, so I decided to replace the AI with
the LRI since it could also serve as a backup airspeed indicator. The
decision was easier since the LRI would fit in the same space as the little
AI and was in the pilot's angle of vision."
http://www.liftreserve.com/
Company website - InAir Instruments
Montblack
Old February 13th 06, 11:10 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Montblack" wrote in message ...
"One of the AOA systems that has been around the longest is the Lift Reserve Indicator. This unit was developed in the
1970's and has been offered in a couple of different variations since then. There is considerable controversy over
just what the LRI actually measures and how it operates, but when the price of the analog unit was recently reduced
substantially, it got my attention. Since the panel of 399SB is rather unconventional, I had included a small backup
airspeed indicator. However, the AI was never used since I rely on the RMI uEncoder for pitot info, so I decided to
replace the AI with the LRI since it could also serve as a backup airspeed indicator. The decision was easier since
the LRI would fit in the same space as the little AI and was in the pilot's angle of vision."
Montblack
Interesting, delta P between two sources, one more or less pointing forward and one more or less pointing downward. I
suppose the indicator has a pressure diaphragm inside it linked to the needle...
I want an AOA indicator for the BD4 someday...
Hmmmmmm.......
Old February 14th 06, 12:14 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Montblack
Hmmmmmm.......
A couple of years ago Kitplanes had an article about and AOA sytem
that used 2 ports flush with the wing surface near the wing tips. It's a
simplified version of a system the military has been using for decades.
The military version uses a conical probe sticking out of the side of
the fuselage. There are two sets of slots a few degrees part facing
towards the front of the airplane. These slots are ports that send air
pressure to two sensing chambers. Here's where they decided to get
complicated: the cone is then driven until the chamber measure equal
pressure. The cone's position is then transmitted to an indicator.
Obviously the system isn't for single engine tractor airplane. The
3.125" indicator is a tad big for most homebuilts, but does contain
switches for stall warning and AOA indexer lights. It seems to me some
enterprising electronics genius should be able to design a simple system
that does all this in solid state.
Dan, U.S. Air Force, retired
Old February 14th 06, 12:37 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Dan, U.S. Air Force, retired" wrote in message
Reserve Indicator. This unit was developed in the 1970's and has been
considerable controversy over just what the LRI actually measures and how
unconventional, I had included a small backup airspeed indicator.
info, so I decided to replace the AI with the LRI since it could also
serve as a backup airspeed indicator. The decision was easier since the
angle of vision."
Montblack
forward and one more or less pointing downward. I suppose the indicator
Hmmmmmm.......
A couple of years ago Kitplanes had an article about and AOA sytem that
The military version uses a conical probe sticking out of the side of the
fuselage. There are two sets of slots a few degrees part facing towards
the front of the airplane. These slots are ports that send air pressure to
two sensing chambers. Here's where they decided to get complicated: the
cone is then driven until the chamber measure equal pressure. The cone's
position is then transmitted to an indicator. Obviously the system isn't
for single engine tractor airplane. The 3.125" indicator is a tad big for
most homebuilts, but does contain switches for stall warning and AOA
indexer lights. It seems to me some enterprising electronics genius should
be able to design a simple system that does all this in solid state.
I'd also like an electronic AOA indicator. There are several probes that
work on three pressure pickups like
(http://www.cgmasi.com/aviation/index.html). In sailplanes we can just
tape a couple of yarns of the side of the canopy and mark the inside with
grease pencil.
bildan
Old February 14th 06, 01:02 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
"Bill Daniels" bildan@comcast-dot-net wrote in message ...
"Dan, U.S. Air Force, retired" wrote in message ...
A couple of years ago Kitplanes had an article about and AOA sytem that used 2 ports flush with the wing surface
near the wing tips. It's a simplified version of a system the military has been using for decades. The military
version uses a conical probe sticking out of the side of the fuselage. There are two sets of slots a few degrees part
facing towards the front of the airplane. These slots are ports that send air pressure to two sensing chambers.
Here's where they decided to get complicated: the cone is then driven until the chamber measure equal pressure. The
cone's position is then transmitted to an indicator. Obviously the system isn't for single engine tractor airplane.
The 3.125" indicator is a tad big for most homebuilts, but does contain switches for stall warning and AOA indexer
lights. It seems to me some enterprising electronics genius should be able to design a simple system that does all
I'd also like an electronic AOA indicator. There are several probes that work on three pressure pickups like
(http://www.cgmasi.com/aviation/index.html). In sailplanes we can just tape a couple of yarns of the side of the
canopy and mark the inside with grease pencil.
bildan
Here is an electronic version: http://advanced-control-systems.com/AOA/aoa.htm
Two pickups; one on the top of the wing and one on the bottom...
Old February 14th 06, 05:14 AM posted to rec.aviation.homebuilt,rec.aviation.piloting
Montblack
Hey, most of you old guys are even older than I am. Didn't they used to
hang AOA indicators on the wing struts of biplanes? A little flat plate
that moved a big needle around a graduated arc as it was pushed by the
relative wind? Sort of like a weathervane. Or was that just an airspeed
indicator I'm thinking of?
Old February 14th 06, 02:04 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
Icebound wrote:
".Blueskies." wrote in message
t...
Basically a stall horn, with the lowered pressure activating a meter instead
of a sound-producing reed. As the pressure falls at the horn, the needle
swings deeper toward the red.
Are we sure that the sensor is a pressure type sensor?
The A-4 Skyhawk uses a paddle type vane on the side of the aircraft's nose.
I'm assuming a simple potentiometer is attached to the vane to read position.
Very straight forward mechanical approach.
Another approach would be to use a pair of thremosistors carefully positioned
inside the slots of the external sensor.
Differences in the air flow inside the two slots (as mentioned previously)
would cause temperature variations of the thremosistors according to AoA.
The electrical difference between the two thremosistors is properly scaled and
can be used to monitor AoA.
I don't have my "library" handy. All that is still packed up in storage.
So I can't pull the relevant details up this morning.
But the Sport Aviation index came up with the references listed below.
Food for thought....
Richard
References:
May '78
Preliminary Report-Development of a Poor Man's VFR Autopilot/Don Hewes
March '79
Update On The Poorman's Autopilot... by Donald E. Hewes
February '80
Autopilot System For Homebuilt Airplanes... by Don Hewes
August '80
Fine Tuning The Electro-Fluidic Autopilot.. . by Doug Garner
April '81
Muscle For Your Homebuilt Autopilot... by Don Hewes
November '81
A Magnetic Heading Reference For The Electro Fluidic Autopilot,Part I
by Doug Garner
December '81
Magnetic Heading Performance For The Electro Fluidic Autopilot
Part 11 . . , by Doug Garner
Old February 14th 06, 04:01 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
I downloaded a homebuilt version of a AOA some time ago. If you want it
contact me and I will I will attach a copy and send it to you.
unconventional, I had included a small backup airspeed indicator. However,
I decided to replace the AI with the LRI since it could also serve as a
backup airspeed indicator. The decision was easier since the LRI would fit
vision."
Montblack
Old February 14th 06, 04:29 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
The last vane-type indicator I witnessed was hanging on the strut of a
New Standard DB-25 (circa 1926). It was an airspeed indicator and
appeared to function quite well from my perspective in the forward-left
front seat.
Orville Wright used a vane-type device in the autopilot system he
invented. While this was the world's first functional autopilot, it
never became popular. Sperry's gyroscopic autopilot system hit the
market shortly after, and was superior.
I'm not familiar with any vane-type AOA indicators that could be
mounted on a strut, but that doesn't mean that they didn't exist. If
anyone knows of one, I'd like to see it.
Harry
Old February 14th 06, 06:27 PM posted to rec.aviation.homebuilt,rec.aviation.piloting
On 14 Feb 2006 08:29:37 -0800, "wright1902glider"
I saw a very simple one in Kitplanes years ago. It was a vane
attached to a backing plate that was painted white, and had degrees on
it, and a big red area that represented the critical angle of attack,
beyond which the airplane stalled.
It was mounted to the wing strut in a vertical position so that you
could see it by turning your head left. Or right, it doesn't matter
on which side you mount it.
There were other versions of this that connected the vane to a
transducer which then transmitted the angle of the vane to a display
on the instrument panel.
I've always thought this (AOA indicator) was a good idea.
Corky Scott
Lift Query Avril Poisson General Aviation 8 April 21st 05 07:50 PM
Tamed by the Tailwheel [email protected] Piloting 84 January 18th 05 04:08 PM
New theory of flight released Sept 2004 Mark Oliver Piloting 70 October 10th 04 10:50 PM
Lift and Angle of Attack Peter Duniho Simulators 9 October 2nd 03 10:55 PM
