F-16 glider
Old January 17th 09, 08:00 PM posted to rec.aviation.soaring
Default F-16 glider
http://www.patricksaviation.com/videos/SUPERGT/3384/
For those not familiar with fighter aircraft, EPU (Electrical Power
Unit) provides hydraulic and electrical power in event of failure of
the engine. The EPU is powered by Hydrazine which decomposes into hot
gasses as it passes across a catalyst bed or engine bleed air (if
available). The hot air passes through a turbine which drive the
emergency hydraulic pump and generator through a gear box.
Old January 18th 09, 11:45 AM posted to rec.aviation.soaring
Gavin Short[_2_]
Default F-16 glider
My buddy at work who is a Portuguese air force officer, also called Mario,
and I discuss glide characteristics and other aviation stuff. We have to
because we are both 'flying desks' at the moment. At least I get to fly
my Std Cirrus at weekends.
Apparently the glide ratio of an F-16 with the engine out is 1:1 so the
pilot's rate of breathing in the video clip is impressively calm!
When I had winglets fitted to the Std Cirrus last year we came to the
conclusion that winglets probably wouldn't make the slightest bit of
difference on the F-16.
He is looking forward to some flights in the club's Grob 103 Twin Acro II
when the weather improves.
Gavin
Std Cirrus, CNN now G-SCNN, #173
LSV Viersen, Keiheuvel, Belgium
Old January 18th 09, 03:07 PM posted to rec.aviation.soaring
kirk.stant
Default F-16 glider
Well, it's a little better than that. When practicing SFOs (simulated
flame out) approaches, the rule of thumb (and this is from memory so
any F-16 drivers out there please jump in!) was 250 knots clean and
6:1 to the field; i.e. you needed 1000' for every nautical mile from
your intended touchdown point. Tried it several times in F-16
simulators at Luke AFB and it worked fine (lots of fun, too -
sometimes the hardest part was getting it stopped!). So the L/D is at
least 6:1, probably as high as 10:1 clean at L/D max speed.
OTOH, the F-4E flight manual (that I just happen to have handy) is
very explicit on what to do with both engines out:
"If neither engine can be started - EJECT"
Kirk
66
Old January 18th 09, 10:32 PM posted to rec.aviation.soaring
Martin Gregorie[_4_]
Default F-16 glider
flame out) approaches, the rule of thumb (and this is from memory so any
F-16 drivers out there please jump in!) was 250 knots clean and 6:1 to
the field; i.e. you needed 1000' for every nautical mile from your
I noticed that the film showed the airspeed pretty much nailed at 220 kts
until he started to flare. Couldn't get anything from the altimeter
display - hard to read off low-rez viseo!
I thought the glide ratio had to be better than 1:1 because even the
Shuttle manages 3:1 and an F-16 looks as it it should do rather better
than that.
martin@ | Martin Gregorie
gregorie. | Essex, UK
org |
Exporting a glider to/import a glider into Germany Pete Smith[_2_] Soaring 1 August 8th 08 09:33 AM
Jet Glider 33 Soaring 5 March 19th 08 03:09 AM
Glider art Mal Soaring 2 December 13th 06 06:54 PM
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
