Jet Glider
Old March 17th 08, 04:58 AM posted to rec.aviation.soaring
33
Default Jet Glider
In reference to Bill Collum's article in Soaring Magazine (Apr. 2008)
does anyone know what FAA regulations apply to retrofitting a non-
motorized glider with a turbine engine similar to the HPH-304?
Is a special turbine Type certification needed?
If there are two engines, is it then charactorized as a twin engine?
Are there extra certifications nessary for the pilot?
Is insurance readily available for a modified non-motorized glider as
a twin engine turbine?
Old March 18th 08, 05:08 AM posted to rec.aviation.soaring
Default Jet Glider
Turbine powered experimental aircraft need an engine maintenance
program, approved by your FSDO. See the FAA Order 8130.2F or maybe G
is current now.
Old March 18th 08, 05:24 AM posted to rec.aviation.soaring
Eric Greenwell
Default Jet Glider
Bob Carlton has been through all of this already. Take a look at his
website:
www.jetsailplane.com
Insurance "Available", yes; readily, I don't know. I believe he insures
through Costello Associates.
It's registered as an experimental glider. It self-launches, so you need
that endorsement. No turbine certification needed, if I remember Bob
correctly. That kind of thing might apply only to airplanes, not gliders.
Old March 18th 08, 05:50 AM posted to rec.aviation.soaring
Greg Arnold
Default Jet Glider
Turbine powered experimental aircraft not only need an engine
maintenance program, but "Proficiency flights will be limited to a
nonstop flight that begins and ends at the home base airport, with
sufficient fuel reserve to meet the applicable operating rules of part
91."
Sec. 91.22 Fuel requirements for flight under VFR.
(a) No person may begin a flight in an airplane under VFR unless
(considering wind and forecast weather conditions) there is enough fuel
to fly to the first point of intended landing and, assuming normal
cruising fuel consumption--
(1) During the day, to fly after that for at least 30 minutes
With the FAA you never know, but isn't FAA Order 8130.2F referring to an
aircraft that needs a working turbine in order stay aloft? Arguably a
jet glider would not be considered to be turbine powered.
is current now.
Old March 18th 08, 10:20 AM posted to rec.aviation.soaring
Vaughn Simon
Default Jet Glider
"Greg Arnold" wrote in message
(a) No person may begin a flight in an airplane ...
Using the FAA's definition a glider is not an airplane, so the above would
not apply to a jet glider.
Vaughn
Old March 19th 08, 03:09 AM posted to rec.aviation.soaring
33
Default Jet Glider
Thank you's to all for the replies.
Glider Model - Blaue Maus- 1922 Wasserkuppe Glider [email protected] Soaring 5 November 19th 06 11:08 PM
shipping glider to NZ-advice on securing glider in trailer November Bravo Soaring 6 November 1st 06 02:05 PM
want to buy a glider Thomas Soaring 5 October 19th 05 03:08 PM
Looking for first glider Jeff Runciman Soaring 17 September 8th 04 08:29 PM
Sea Glider OscarCVox Soaring 8 July 12th 04 12:08 AM
