Love my DG 400. I have had to do a little work but able to get parts so far. No motor breakdown work.
On the gear, there is a service bulletin that covers a number of the DG models. It was done to my glider and makes the mechanism more robust with a positive catch and spring on the handle. Also changing the gas spring on the gear is important if not done in years. Vibration, I have had the prop balanced by Russel Brown at Seminole when flying at the Seniors. Took about an hour using a Dynavibe. Put small washers in different locations around the prop hub where it bolts together. Very significant vibration reduction, pitch of prop changed, and even got a couple hundred RPM on static run. Great bird for the money. Kevin 92 |
ASW 20C Motorglider | Nick Kennedy[_3_] | Soaring | 3 | February 7th 19 11:17 AM |
FS: DG-400 Motorglider | 2G | Soaring | 0 | September 20th 13 02:32 PM |
IFR in motorglider? | cp | Soaring | 28 | March 9th 08 12:02 AM |
Motorglider Tug | Ray Lovinggood | Soaring | 21 | November 13th 04 04:06 AM |
motorglider | KsiTau | Soaring | 0 | September 4th 04 09:10 AM |
