ASW 20C Motorglider
Old February 7th 19, 04:43 AM posted to rec.aviation.soaring
Nick Kennedy[_3_]
Default ASW 20C Motorglider
In the Wings and Wheels classified there is a French Registered ASW20C Motorglider
Some pictures show a clean fuselage top and there is a photo with a rather large Konig engine with a folding prop attached on top of the fuselage. Does this whole engine/propeller go into the fuse? The motor and prop look really big in the photo.
Does anyone know any history of this modification?
Old February 7th 19, 05:43 AM posted to rec.aviation.soaring
JS[_5_]
It's known as the "Top".
Been around for a while. You can remove it and fly as a real glider or put it on and enjoy the noisy smelly thing.
Old February 7th 19, 09:08 AM posted to rec.aviation.soaring
Pete Startup[_2_]
Motorglider
and
put
One in the Uk too - https://adverts.gliderpilot.net/?op=s3&id=15010
Old February 7th 19, 12:17 PM posted to rec.aviation.soaring
AS
TOP = Take-Off Power. There have been a number of glider types retrofitted with this removable back-pack. The whole thing is mounted on permanent hard-points and can be removed quickly. Has been around since the late '70s early '80s.
Uli
'AS'
FS: DG-400 Motorglider 2G Soaring 0 September 20th 13 03:32 PM
IFR in motorglider? cp Soaring 28 March 9th 08 01:02 AM
Motorglider Tug Ray Lovinggood Soaring 21 November 13th 04 05:06 AM
motorglider KsiTau Soaring 0 September 4th 04 10:10 AM
Lambada Motorglider Andre van Niekekerk Soaring 2 June 5th 04 10:19 AM
