Repairing philliform corrosion
Old September 30th 04, 09:57 PM
Orval Fairbairn
In article , Ed Pauls
What is the best way stop it, get it off and recoat the affected areas.
Ed
You have to remove all paint from the affected area, remove the
corrosion (Aluminum Jelly works), thoroughly clean the area, including
degrease, Alodyne (optional), prime with self-etching primer, repaint to
match.
Old October 1st 04, 03:56 AM
Get a HARD copy of 43.13 and do it correctly and understand what and why
you are doing it.
It will be the best $20.00 you will ever spend as an aircraft owner.
Dave
Ed
match.
Old October 1st 04, 07:52 PM
Ed Pauls
Default Repairing philliform corrosion
Ed
Old October 2nd 04, 09:08 PM
Thomas Lembessis
The January, 1991 issue of Light Plane Maintenance had a good article on
Filiform Corrosion.
"Ed Pauls" wrote in message
Ed
Naval Air Refueling Needs Deferred in Air Force Tanker Plan Henry J Cobb Military Aviation 47 May 22nd 04 03:36 AM
Non Chromate Anti Corrosion and Paint Prep X-it Prekote? All Thumbs Home Built 7 May 5th 04 04:21 PM
Corrosion Protection on Alluminum Sheet Aircraft? DL152279546231 Home Built 6 February 10th 04 05:10 AM
How much corrosion is too much? Carl Orton Owning 5 February 2nd 04 01:31 AM
Corrosion X Applicators Hankal Owning 5 July 7th 03 06:07 PM
