AOPA reporting free GNSx30 WAAS software upgrade available
Old December 14th 07, 05:52 PM posted to rec.aviation.ifr
Marco Leon[_4_]
Default AOPA reporting free GNSx30 WAAS software upgrade available
"Peter R." wrote in message
After the upgrade I did have one problem in that the wire that connects to
my
HSI came loose and indicated a centered indication on the glideslope.
Didn't
find this out until I was on an approach and concluded that the LPV
glideslope should have been well above the aircraft yet it indicated
perfectly centered. Not sure when the wire came loose but I now pay VERY
close attention to the GPS pre-flight check where the unit at boot-up has
you
confirm 1/2 out indications for the glideslope/localizer. If the wire is
loose the GPS will not be able to force a 1/2 out indication during this
preflight check, as I learned after getting on the ground and purposely
testing this.
Holy cow Peter, that's quite scary once you think about it. Glad it didn't
happen in the low soup when it counts.
A lesson for all of us to pay attention to that system test.
Marco
WAAS upgrade for your G1000? Dan Luke Owning 13 April 14th 17 01:16 PM
WAAS upgrade for your G1000? Dan Luke Piloting 14 September 5th 07 05:02 PM
Has anyone got the waas garmin upgrade? scott moore Instrument Flight Rules 0 January 1st 07 08:38 AM
More info on GNS 430/530 WAAS upgrade PPT33R Instrument Flight Rules 33 June 24th 05 02:21 PM
More info on GNS 430/530 WAAS upgrade PPT33R Owning 33 June 24th 05 02:21 PM
