WAAS upgrade for your G1000?
Old May 29th 07, 11:10 PM posted to rec.aviation.owning,rec.aviation.piloting
Dan Luke
Default WAAS upgrade for your G1000?
From the Cessna Pilots Ass'n avionics forum:
"Just talked to Tom Engberg at Cessna about G1000 WAAS upgrade. He said that
Cessna was waiting on Garmin to propose an upgrade to the pre 07 G1000s. He
also said that it was going to take a change in the GIAs and that would be
very expensive. This is if it is even made available. What I couldn't fine
believeable is that he said no one at Cessna knew if the upgrade was even
going to be made available. I believe that if the present owners of pre 07
G1000s don't start calling Cessna and demanding what their advertisements
stated, we will never get a WAAS upgrade."
Dan
? at BFM
Old May 30th 07, 12:04 AM posted to rec.aviation.owning,rec.aviation.piloting
Robert M. Gary
Dan
? at BFM
This will be interesting for CAP. We have lots and lots of 2006 G1000
182's and 206's.
-Robert
Old May 30th 07, 12:57 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan Luke
182's and 206's.
Could be really bad. Owners 0f 2004-2006 Cessnas could find the IFR utility
of their airplanes diminishing yearly as the FAA commissions more LNAV-VNAV
WAAS approaches. Can you say "class action suit?"
What about when ADS-B arrives? Will G1000 owners be SOL then, too?
Dan
"The future has actually been here for a while, it's just not readily
available to everyone."
- some guy at MIT
Old May 30th 07, 03:46 AM posted to rec.aviation.owning,rec.aviation.piloting
Jim Carter[_1_]
"Dan Luke" wrote in message
utility of their airplanes diminishing yearly as the FAA commissions more
LNAV-VNAV WAAS approaches. Can you say "class action suit?"
I can't see the FAA decommissioning VOR / ILS / GPS / RNAV approaches as
they bring up new WAAS approaches. I can see that the older G1000s won't be
able to take advantage of the new approaches.
I also don't see this as a big impact for CAP since very, very little of our
flying is done in IMC (except for transport or maybe electronic searches).
I think this will become a marketing / legal issue for Cessna however,
especially if promises were made.
Jim Carter
Rogers, Arkansas
Old May 30th 07, 01:36 PM posted to rec.aviation.owning,rec.aviation.piloting
Frank Eigler
"Dan Luke" writes:
182's and 206's.
WAAS approaches.
What the?! Did any fool ever any proclaim a guarantee of
"non-diminishing IFR utility"? Even if they did, how exactly do you
figure that the mere existence of LNAV-VNAV approaches somehow
dimishes the utility of those machines that cannot use them?! If
anything, they can be a plus -- there any LNAV-VNAV family approaches
that do not also have plain LNAV?
Can you say "class action suit?" [...]
Yes, and I can also say "bozo the clown".
- FChE
Old May 30th 07, 03:42 PM posted to rec.aviation.owning,rec.aviation.piloting
Dan Luke
No, but Cessna and Garmin both said that older G1000s would be upgradable.
Think about the fact that the FAA is counting on GPS to allow them to do away
with ground based NAV systems--it's already happening. Do you really believe
that won't include some ILS's?
If
Haw-haw!
Evidently the concept of lower minimums for VNAV is new to you.
Can you do tricks on your tiny bicycle, too?
Dan
"How can an idiot be a policeman? Answer me that!"
-Chief Inspector Dreyfus
Old May 30th 07, 06:28 PM posted to rec.aviation.owning,rec.aviation.piloting
Frank Eigler
to do away with ground based NAV systems--it's already happening.
Do you really believe that won't include some ILS's?
So *that's* what you're aching to sue Garmin & Cessna for?
The hypothetical decommissioning of ILS approaches by the FAA?
Good luck with that.
there any LNAV-VNAV family approaches that do not also have plain
LNAV?
Or rather, I can tell the difference between a contrapositive and a
non sequitor.
- FChE
Old May 30th 07, 03:54 PM posted to rec.aviation.owning,rec.aviation.piloting
Darrel Toepfer
Hopefully it'll come with more vendors offering products and price
competiton... Right now the offerings are few and the pricing high...
Old May 30th 07, 10:28 PM posted to rec.aviation.owning,rec.aviation.piloting
Robert M. Gary
Yea, and the FAA seems to be helping avoid competition.
Old April 14th 17, 01:16 PM posted to rec.aviation.owning
Dan
? at BFM
Sorry, kind of late on this thread, but a student just bought a 2004 C-182 and thought that it had WAAS. I got a WAG on WAAS upgrade: $28,000!!!! I don't believe that this includes the Garmin Autopilot, but am not sure, since both display units and both antenna are included, it may include removal of the KAP-140 and replacement with the GFC 700 autopilot. I do not believe that it includes the Garmin GFC 700. I owned a 2004 and then a 2007 Cessna 182. The difference in the NAV capabilities was great. However, LNAV approaches without glide path are far superior to any old VOR or ADF approaches. The single advantage of the older machines is that, with the single AHRS installed in these airplanes, loss of that AHRS is pretty bad in IMC because staring down at the standby attitude indicator is a bear in the NEW (WAAS) units. However, with the KAP-140 being independent of the G1000 (older airplanes), loss of the AHRS does not eliminate use of the KAP-140 autopilot. The KAP-140 keeps the airplane on course (using heading mode), and on altitude, where one can continue using the full GPS nav tracking. I've had an AHRS fail in IMC, and it wasn't much of a bother.
Chick Svoboda
WAAS upgrade for your G1000? Dan Luke Piloting 14 September 5th 07 05:02 PM
WAAS upgrade info for Garmin 430 Paul kgyy Owning 23 January 3rd 07 04:33 PM
Has anyone got the waas garmin upgrade? scott moore Instrument Flight Rules 0 January 1st 07 08:38 AM
More info on GNS 430/530 WAAS upgrade PPT33R Instrument Flight Rules 33 June 24th 05 02:21 PM
More info on GNS 430/530 WAAS upgrade PPT33R Owning 33 June 24th 05 02:21 PM
