When to descend II
Old October 30th 07, 04:00 PM posted to rec.aviation.ifr
Newps
Default When to descend II
He probably meant NW. You can't identify ROYCE unless you are on the
localizer.
Non GPS airplane?
Old October 30th 07, 06:04 PM posted to rec.aviation.ifr
Ron Rosenfeld
Perhaps, but I'd rather respond to the question asked than to the one I
made up. Also, if here were NW of ROYCE and on the localizer, he'd
probably omit the part of his question about "heading for the numbers"
since he'd already be heading in that direction.
You can't identify ROYCE unless you are on the localizer.
You can certainly navigate TO ROYCE without being established on the
localizer, however.
Old October 30th 07, 06:07 PM posted to rec.aviation.ifr
Bee[_2_]
localizer.
Non GPS airplane?
GPS isn't the issue. In fact there is also an RNAV (GPS) IAP to 12R
with the same FAF.
But, ATC couldn't issue the crossing restiction at ROYCE unless the
aircraft were on the approach at that time. A direct-to-the-FAF is not
allowed.
Old October 30th 07, 06:32 PM posted to rec.aviation.ifr
John Godwin
Ron Rosenfeld wrote in
the localizer, however.
Vectored, maybe but not navigating.
Old October 30th 07, 06:51 PM posted to rec.aviation.ifr
Dan Luke[_2_]
"Bee" wrote:
I don't believe he can be 4 mi SW of ROYCE and also on the localizer for
Rwy 12. Or am I missing something?
localizer.
No, I meant SW. I was on a vector to join, and then called the field in
sight.
I'm doing this from memory of 6 mos. ago. I might be missing a detail, but
the approach and tower clearances are essentially correct.
Dan
T-182T at BFM
Old October 30th 07, 07:18 PM posted to rec.aviation.ifr
Newps
with the same FAF.
allowed.
I most certainly can issue that restriction without the aircraft being
on the approach. It's merely a fix, if I want an aircrasft to cross
over a fix at or above a certain altitude I'll do it.
Old October 30th 07, 07:25 PM posted to rec.aviation.ifr
Bee[_2_]
Newps wrote:
with the same FAF.
not allowed.
But, in essence you are clearing me direct-to-the-FAF. This is not an
en route fix or even an IAF or earlier. Only in limited circumstances
are you allowed to clear me direct to an RNAV IF. I certainly don't see
how you can make me cross a FAF unless you have correctly placed me on
the IAP.
Old October 30th 07, 07:27 PM posted to rec.aviation.ifr
Bee[_2_]
localizer.
sight.
Yes, memory is a fleeting thing. ;-)
If you were on vectors to the ILS, the final heading for intercept
couldn't be greater than 330 coming from that direction.
Old October 30th 07, 07:41 PM posted to rec.aviation.ifr
Ron Rosenfeld
But he wrote that he had been cleared for the visual.
Old October 30th 07, 07:50 PM posted to rec.aviation.ifr
Newps
Irrelevant. A fix is a fix. You're doing the visual approach. We in
the TRACON have determined that sending aircraft over a certain fix
makes separation easier. One problem with using an RNAV approach fix is
a lot of people won't be familair with it before hand. We normally use
a fix here on our ILS that substitutes for the OM and everybody is
familiar with it.
This is not an
the IAP.
You're doing to the visual approach, it's irrelevant what fix I send you
too. It could be a charted one or one I simply made up out of thin air.
When to descend Dan Luke[_2_] Instrument Flight Rules 44 October 14th 07 09:12 AM
