When to descend II
Old October 29th 07, 08:29 PM posted to rec.aviation.ifr
Dan Luke[_2_]
Default When to descend II
You're 4 miles SW of ROYCE.
http://www.naco.faa.gov/d-tpp/0710/00198IL12R.PDF
Approach says "Cessna '1GS,cross ROYCE at or above 2 thousand, cleared visual
approach runwy 12R. Contact the tower on 118.7."
On initial contact, Tower says "Cessna '1GS, runwy 12R, cleared to land."
Do you still have to cross ROYCE at 2,000 or can you head for the numbers and
come on down?
Dan
T-182T at BFM
Old October 29th 07, 08:42 PM posted to rec.aviation.ifr
Doug Carter
come on down?
Seems odd that Approach would tell you "cross ROYCE" since its not between you
and the runway.
Old October 29th 07, 09:21 PM posted to rec.aviation.ifr
Peter R.
visual approach runwy 12R. Contact the tower on 118.7."
and come on down?
Not enough information. Were you tracking the ILS when the visual approach
was issued? Or were you approaching the airport from another direction?
In any case, I would have asked approach for clarification before switching
over to tower if I were NOT tracking the ILS already.
Peter
Old November 9th 07, 01:31 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Peter R." wrote in message
The position was given as 4 miles southwest of ROYCE.
Old October 29th 07, 11:36 PM posted to rec.aviation.ifr
Bee[_2_]
come on down?
I presume approach had vectored you onto the localizer previously or you
would not be able to identify ROYCE.
The instruction to cross ROYCE at or above two-thousand is an IFR
restriction with which you must comply because the visual approach isn't
authorized until passing ROYCE.
The tower's subsequent clearance to land has no affect on your IFR
altitude, and then visual clearance, issued by approach control. You
still have to cross ROYCE at, or above, 2,000 landing clearance
notwithstanding.
Old November 9th 07, 01:33 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Bee" wrote in message ...
The position was given as four miles southwest of ROYCE.
The visual approach is authorized the instant it's issued.
Old October 30th 07, 01:35 AM posted to rec.aviation.ifr
Ron Rosenfeld
On Mon, 29 Oct 2007 15:29:12 -0500, "Dan Luke"
come on down?
I've not flown in that area, but ATC may be wanting you to fly to Royce
before turning inbound because of traffic on approach to Rwy 12L. There are
some issues with intersecting flight paths that need to be avoided when
dealing with parallel runway operations.
Having said that, I would have assumed ATC wanted me to fly to ROYCE before
turning inbound, at or above two thousand; but I would request
clarification from the tower as to whether I could go straight in from my
present position, if that seemed a viable alternative.
Of course, if in VMC, you could cancel your IFR flight plan, mooting the
previous ATC clearance.
Old October 30th 07, 02:23 AM posted to rec.aviation.ifr
Newps
An at or above altitude in a clearance like that almost always means
there will be traffic under you going into a different airport.
come on down?
Old November 9th 07, 01:44 PM posted to rec.aviation.ifr
Steven P. McNicoll
"Newps" wrote in message
An at or above altitude in a clearance like that almost always means there
Hard to fit another airplane between traffic at 2000 MSL and towers over
1000 MSL.
Old October 30th 07, 09:47 AM posted to rec.aviation.ifr
Bee[_2_]
If it is a "maybe" in your mind, then it's best to comply.
No turn inbound required. He is presumably already on the localizer or
he couldn't identify ROYCE.
Might not be the best airspace to be doing that without making sure you
won't be descending onto some other aircraft like Newps says.
When to descend Dan Luke[_2_] Instrument Flight Rules 44 October 14th 07 09:12 AM
