Covering an ultralight wing with Monokote
Old January 8th 06, 08:35 PM
Chris Wells Chris Wells is offline
Senior Member
First recorded activity by AviationBanter: Oct 2005
Default Covering an ultralight wing with Monokote
I was wondering about the feasability of covering a wing on an ultralight with Monokote, which is normally used on R/C aircraft. If the tensile strength is too low, could you use 2 or more layers?
Old January 8th 06, 10:42 PM posted to rec.aviation.homebuilt
"Chris Wells" wrote in message
Damn, that would be $$$expen$ive!
Also, since wing loading for models is in the ounces to a pound or two per
square foot, and full scale is 10 to 15 pounds and up, I would wonder about
it.
Ribs work best to reduce sag on models, about 4 inches apart. I wonder
about how it would sag on full size?
Old January 9th 06, 02:27 AM posted to rec.aviation.homebuilt
"Morgans" wrote in message ...
Also, since wing loading for models is in the ounces to a pound or two per square foot, and full scale is 10 to 15
pounds and up, I would wonder about it.
Ribs work best to reduce sag on models, about 4 inches apart. I wonder about how it would sag on full size?
Way back when there was a Citabria (I think) that was covered with Monokote...I think they put it over the fabric
though...
Old January 9th 06, 01:47 PM
Senior Member
I was thinking it wouldn't be too bad, considering I could do it myself...sails cost $1000+...
Old January 9th 06, 08:04 PM posted to rec.aviation.homebuilt
I've thought about this - and intend to try something similar in the
future. Tedlar has been proven to work on ultra lights so the concept
is sound. Monokote is pretty high priced and seems to tear easily once
the rip starts.
For a more inexpensive option you might investigate the material I have
in mind - boat shrink wrap. It's very inexpensive comes in a few
colors and thickness, is as tough as Tedlar, and probably could be
installed with similar methods. The tape used I know for a fact has
the durability and grip strength for ultra light applications. Look
for "preservation" tape.
As with anything experimental do the tests your self to verify the
materials and methods. My only real world experience with this kind of
material has been with the cheap clear shrink type sold in hardware
stores for storm window fabrication. It has some draw backs but will
hold together for a surprising length of time on a structure like a
rudder or elevator - at speed to 80 MPH. Never done a wing with
it............yet
Leon McAtee
Old January 10th 06, 12:20 AM posted to rec.aviation.homebuilt
wrote in message ups.com...
the rip starts.
Just have to be sure that it does not shrink too much. I can see that boat wrap stuff crushing a light wing
structure....
Grob G102 Setup BDS Soaring 11 August 30th 05 03:42 PM
Double covering fabric covered wings [email protected] Home Built 9 May 9th 04 08:39 PM
Props and Wing Warping... was soaring vs. flaping Wright1902Glider Home Built 0 September 29th 03 03:40 PM
