flaps
Old July 15th 07, 11:59 PM posted to rec.aviation.owning,rec.aviation.piloting
Roger (K8RI)
Default flaps
On Tue, 10 Jul 2007 12:38:14 -0700, Jay Honeck
Spend an hour or two landing on the numbers with the stall horn squalling.
It's funny how much easier this was to do when I was renting
airplanes. Heck, I'd routinely drag it in at minimum forward air
speed and plunk it on the numbers, just to see how short I could land.
This should be a part of every ones practice.
When you own an aircraft -- especially one with a big, heavy 6-
cylinder engine that is slightly nose-heavy -- you think twice before
"practicing" such things. Tires, struts, brakes, firewalls, props,
Nope, not even with a Beech retract. I'd probably do two (or more) of
these about every time I'd go out and practice. After about the
second one I'd find the "airport bums" (group I hang out with) hanging
on the fence, grading the landings.
and engines all become HUGE impediments to "practicing" landings with
the stall horn squalling, since you're paying for them all.
I bought 'em to use and I used them to lean both the limits of the
airplane and myself.
This post, IMHO, above all else, is a real tribute to the utility of
manual, Johnson-bar flap actuators. Hard to miss when THOSE don't
work.
When I add flaps I look at them. It's become a habit.
OTOH the Johnson bar flaps in the Cherokee 180 could make for a very
impressive, short roll out after a STEEP descent.
  #82
Old July 16th 07, 02:49 AM posted to rec.aviation.owning,rec.aviation.piloting
Dan Luke[_2_]
Default flaps
"Roger (K8RI)" wrote:
I bought 'em to use and I used them to learn both the limits of the
Yep.
The Skylane has a reputation as a great short field airplane: I'm enjoying
making mine live up to that reputation.
Life is for living; airplanes are for flying.
Dan
T-182T at BFM
  #83
Old July 16th 07, 03:44 AM posted to rec.aviation.owning,rec.aviation.piloting
karl gruber[_1_]
Default flaps
You should have no problem using a strip half that length with two of you
on board. Is your nosewheel/strut/firewall that delicate? That's not
Pipers reputation, that's Cessna's. Piper's rep is building planes that
are overweight, not fragile.
No. The Cherokees have MUCH more fragile landing gear. Not only that but
they are pushed through the wing so that repair is impractical. You'll NEVER
see a Cherokee SIX with 30,000 hours on it, like most Cessna 207s in Alaska.
Karl
  #84
Old July 16th 07, 08:00 AM posted to rec.aviation.owning,rec.aviation.piloting
Thomas Borchert
Default flaps
Newps,
That's really disappointing to hear. I didn't realize this attitude
even existed but this does explain some things I see. I have more fun
plunking my airplane down in small spots than just about anything else.
Me too. And I own it, too. It's not a smart attitude not to practice with
your own plane. But you're right, it does explain a lot of the "driving
on" of larger singles one sees.
Thomas Borchert (EDDH)
  #85
Old July 16th 07, 03:04 PM posted to rec.aviation.owning,rec.aviation.piloting
Default flaps
On Jul 11, 3:48 pm, "Al G" wrote:
This is almost getting to the point where "everything" must work, (zero
tolerance). If I have two navigation lights on each wing, and one of them
burns out, can I fly at night? It sounds awfully unsafe to say I'm going to
go out and fly at night with a known inoperative nav light.
It's not so simple but it's not complicated either. The
regs detail what needs to be installed and working for any particular
sort of flight (day VFR, night VFR, and so on) and if something is
dead, something like a landing light, it must be snagged in the
logbook and then deferred if you want to keep flying. Determining who
can defer a defect becomes your job. There are things (like fuel
gauges) that have to be working all the time and can't be deferred.
See CAR 605.14 thru 605.41 to see what you need:
http://www.tc.gc.ca/CivilAviation/Re...605.htm#605_14
Then see CAR 605.10 to see how to deal with dead stuff:
http://www.tc.gc.ca/CivilAviation/Re...605.htm#605_10
That pooched landing light isn't necessary here in Canada at
night if you aren't carrying passengers, but I still wouldn't want to
fly without it. I want to see that deer on the runway so I can go
around. Nav lights ARE necessary, as is the anti-collision light. Dead
flaps would be a real debate between the mechanic and pilot, and the
mechanic is going to be conservative because it's his signature on the
line deferring them. As a mechanic, I would get a ferry permit to
avoid the risk of losing my ticket and to avoid putting passengers at
risk. If that engine quits and the pilot has to put the thing down is
an inconvenient spot, those flaps could make the difference between
landing at a survivable speed or getting smashed to bits.
The airplane doesn't have to be perfect. It needs to be
safe for the intended flight.
Dan
flaps Kobra[_4_] Piloting 84 July 16th 07 06:16 PM
Flaps on take-off and landing Mxsmanic Piloting 397 September 22nd 06 09:02 AM
Fowler flaps? TJ400 Home Built 20 May 19th 06 02:15 AM
FLAPS skysailor Soaring 36 September 7th 05 05:28 AM
FLAPS-Caution Steve Leonard Soaring 0 August 27th 05 04:10 AM
