How long to get down question
Old November 22nd 05, 03:30 AM posted to rec.aviation.owning
Default How long to get down question
An OT query for folks here. While discussing things that can happen
between the jetways, I posited that it's a really bad to be aloft
in Big Iron in a medical emergency, etc. -- based on how long it
takes to get on the ground.
That brings up the question of how long that time really is....
So:
If you are at cruise in Boeing's finest at FL430 & declare an
emergency; how fast CAN you be down and stopped? (Or Airbus, for
that matter....)
Assuming ATC can clear a lane, I assume it's a function of how
steep a decent you can use without exceeding the max IAS. What are
the limits on speed brakes, dropping gear, etc. to dirty things ups?
Do you slow to gear-down speed, drop them, then nose over? Or is
the higher speed possible w/ gearup better?
A host is a host from coast to
& no one will talk to a host that's close........[v].(301) 56-LINUX
Unless the host (that isn't close).........................pob 1433
is busy, hung or dead....................................20915-1433
182RG question Paul Anton Owning 11 May 16th 05 09:45 PM
Question for CFIs Casey Wilson Piloting 11 February 24th 05 10:29 PM
Showstoppers (long, but interesting questions raised) Anonymous Spamless Military Aviation 0 April 21st 04 05:09 AM
Defining Composites (long) B Lacovara Soaring 1 September 13th 03 08:04 PM
