Need an 800x600 cockpit pda/tablet!
Old April 20th 04, 09:49 PM
Ben Jackson
Default Need an 800x600 cockpit pda/tablet!
I've been playing with the PDF approach plates. Well rendered they are
easily readable at 600x800 (they're taller than they are wide, but
narrower than the 4:3 aspect ratio of most display) with 16 levels of
grayscale. 480x640 is pretty good with 16 levels of gray, down to right
on the ragged edge of usable with only 4 levels.
The device doesn't need that much storage. A largish compact flash card
should hold all of the pages on the entire DVD if they're pre-rendered
(a GIF of the plate is much smaller and displays much faster).
What it does need is a reasonably large screen, probably at least 6"
diagonal. There are some 480x640 PDAs, but they have very small screens.
There are tons of 240x320 PDAs but I don't think they'd ever be suitable
for viewing plates.
I'd rather avoid a laptop or even a full tablet PC (stuff with 10"+ screens)
in favor of an ebook/pda sort of form factor.
Ben Jackson
http://www.ben.com/
Old April 21st 04, 03:27 AM
Ross Oliver
EarthLCD (www.earthlcd.com) is offering a 6.3" 640x480 grayscale
LCD display panel for the bargain price of $29 (search for EG9013FNZ1)
From the spec sheet, it doesn't look all that difficult to drive. If your
gizmo doesn't have to *do* anything other than display GIFs from a CF card,
you could probably run it using fairly simple FPGA. How's your Verilog? ;-)
Sure would be a lot less power-hungry (and therefore cooler) than a
tablet PC. The only wrinkle would be getting the +40 volt driver voltage.
If you're not into hacking hardware, EarthLCD also sells its mARMmalade [sic]
kit: Modular ARM Application LCD Appliance Device Electronics. This
is an ARM-based single-board computer running Linux, and a 7.8" color
LCD touch-screen display, all for $299. Just add power.
Happy hacking,
Ross Oliver
cockpit noise Peter Thornton Home Built 10 June 7th 04 12:21 PM
Labels for cockpit? [email protected] Home Built 17 May 11th 04 07:12 AM
Cockpit Lighting Controller Richard Home Built 0 April 8th 04 07:12 AM
What are you guys using for cockpit lights these days? Stealth Pilot Home Built 6 December 9th 03 09:14 AM
Open Cockpit Chipmunk [email protected] Aerobatics 0 October 15th 03 10:59 PM
