Jabiru 80 HP Experience, Anyone?
Old August 29th 09, 04:05 AM posted to rec.aviation.homebuilt
Orval Fairbairn[_2_]
Default Jabiru 80 HP Experience, Anyone?
A group of us are building a Pulsar and expect to license it in exp-LSA
and are seriously considering the 80 horse Jabiru as a powerplant. The
engine, and FWF kit are less than the Rotax, without having a gearbox to
complicate things.
Who out there has experience with this engine?
Strengths?
Weaknesses?
Remove _'s from email address to talk to me.
Old August 29th 09, 05:35 AM posted to rec.aviation.homebuilt
Garry O
"Orval Fairbairn" wrote in message
news
complicate things.
Strengths?
Weaknesses?
Cheap to feed and reliable are things that first come to mind :-)
15liters per hour at 2700 RPM, quick response time if you need power in a
hurry from idle and cheap to maintain as well, if its looked after during
its life the 2000hr service can be cheaper than sending your car in for a
regular service :-)
there can sometimes be an engine "miss" when applying power for a go-round,
or during a touch & go landing, all relating to the fuel/air mixture at
idle. Apparently, during a descent at low engine power (especially a glide
descent), the mixture is excessively "lean" due to the engine speed being
increased above normal idle speed by the wind milling effect of the
propeller. so when power is applied, there's a delay before the correct
mixture for full power is achieved. The problem will be less apparent if
gradual power changes are made. The problem is fixable but it means making a
small change then a test flight, rinse and repeat :-)
Incidentally, those who've grown up on Lycoming or Continental engines will
see this as pretty normal.
engine oil temp should be kept around 70C, where I am we had to blank off
part of the oil cooler as 50C is considered a bit cool, that blank can
probably be removed once the warmer weather starts to make itself known.
All in all a Jabi 80hp is as good as anything else on the market and better
that some when service and maintenance costs are calculated into the TCO.
Jabiru recommend a 2000hr rebuild (as I said, it can be quite cheap if
properly looked after) while I think the Rotax is 1500hrs and then you have
a gearbox to throw in the mix as well.
Flying RA Aus, because its cheaper and I can do it more often :-)
Old August 29th 09, 07:08 PM posted to rec.aviation.homebuilt
news
complicate things.
Strengths?
Weaknesses?
regular service :-)
thank you -- The Jabiru looks like a quality engine!
Old August 31st 09, 02:45 PM posted to rec.aviation.homebuilt
Stealth Pilot[_3_]
On Sat, 29 Aug 2009 14:08:37 -0400, Orval Fairbairn
news
complicate things.
Strengths?
Weaknesses?
some of the earlier engines have come to grief but factory support is
good.
i'm told that the hydraulic lifter model looks like seeing the full
tbo.
Stealth Pilot
Old May 12th 10, 09:57 PM
Larry Wheat Larry Wheat is offline
Junior Member
First recorded activity by AviationBanter: May 2010
complicate things.
Strengths?
Weaknesses?
I currently have a 2200 Jabiru on my Excalibur pusher. It is a great engine and runs like a sewing machine. I have had some issues with the engine running cooler than normal. It is uncowled so all the aluminum is a big heatsink. I have had great support from Jabiru Pacific and Jabiru USA. In fact I am planning on buying a 1198 PulsarIII and put a Jabiru2200 on it. Do you guys know where I can get the firewall forward kit for this airplane. I am having a hell of atime trying to contact ANYONE associated with the factory so it is worrysum to me. Any help will be appreciated. Cheers, Larry
Trimotors, pt 4 - Farman Jabiru.jpg (1/1) Mitchell Holman Aviation Photos 3 September 26th 07 10:22 AM
Jabiru Glenn[_2_] Aviation Photos 2 August 25th 07 11:35 PM
Jabiru Glenn[_2_] Aviation Photos 0 August 7th 07 10:56 AM
Jabiru chuck Home Built 9 January 22nd 07 04:40 PM
Rotax vs. Jabiru Cal Vanize Home Built 30 January 23rd 06 08:15 PM
