Importing custom built glider trailer from UK to USA
Old September 2nd 09, 03:29 AM posted to rec.aviation.soaring
AK
Default Importing custom built glider trailer from UK to USA
On Sep 1, 7:02*pm, Chris wrote:
Can anyone provide some guidance on the necessary steps for importing
a glider trailer from the UK to the USA? There is plenty of
information on RAS on the steps to take for importing the glider
inside the trailer, but this always assume that the trailer is
something similar to a Cobra that is already approved for use within
the United States. What about a trailer that was built as a one off in
the UK?
As far as I can tell this is considered a non-conforming vehicle by
the DOT and the only solution is to use a registered importer and
provide a steep bond to cover any potential modifications. BUT perhaps
someone else who's done this can suggest an easier (and less expensive
way)?
Chris
Try Importing the trailer as storage container. Find out what the
rules are. When I was picking my glider from the port of entry I saw a
few vehicles being imported from Russia. I asked one of the customs
officers how they intended clear customs. He said they are intended
for working in the forest or a farm. He also said there would be a
flat bed coming for each of them. Try this approach it must be
possible. Then when you go to register you tell them it is a home
built. Then you should be all set.
There might be another way. There is an exemption for old vehicles,
but you must prove when it was manufactured. You can investigate this
approach as well.
AK
Importing custom built glider trailer from UK to USA Chris Soaring 5 September 3rd 09 01:02 PM
Custom Built Model Airplanes [email protected] Products 0 May 30th 08 02:45 PM
Importing AVIONIC glider trailer - what a pain [email protected] Soaring 12 September 7th 07 02:49 AM
Custom Built Model of your Aircraft customairmodels Aviation Marketplace 2 November 10th 05 10:56 AM
Custom glider trailer builders in the US Ken Harry Soaring 6 January 9th 05 05:12 AM
