Propeller Damage
Old September 2nd 09, 08:15 PM posted to rec.aviation.soaring
Mike McCarron[_2_]
Default Propeller Damage
Saw a Pawnee bend its prop on a taxiway light while taxiing. Other than
repairing the prop or replacing it with another what is required by either
Lycoming or the FAA for inspection of the engine?
Thanks
Old September 2nd 09, 08:26 PM posted to rec.aviation.soaring
vontresc
On Sep 2, 2:15*pm, Mike McCarron wrote:
Saw a Pawnee bend its prop on a taxiway light while taxiing. *Other than
Thanks
Lycoming has a Service bulletin (SB-475) outlining what needs to be
done after a prop strike.
http://tinyurl.com/np8ptd
IIRC the FAA then came out and made parts of this an AD
http://tinyurl.com/lc2gw8
This topic came up a while ago on another pilots discussion group a
while back
http://www.pilotsofamerica.com/forum...ad.php?t=11823
Peter
Old September 3rd 09, 02:56 AM posted to rec.aviation.soaring
BT
AD 2004-10-14 Prop Strike Definition.
(1) Any incident, whether or not the engine is operating, that requires
repair to the propeller other than minor dressing of the blades.
(2) Any incident during engine operation in which the propeller impacts a
solid object that causes a drop in revolutions per minute (RPM) and also
requires structural repair of the propeller (incidents requiring only paint
touch-up are not included). This is not restricted to propeller strikes
against the ground.
(3) A sudden RPM drop while impacting water, tall grass, or similar yielding
medium, where propeller damage is not normally incurred.
"vontresc" wrote in message
Thanks
while back
Peter
Propeller Damage Mike McCarron[_2_] Soaring 12 September 4th 09 01:04 AM
Propeller Damage Mike McCarron[_2_] Soaring 0 September 2nd 09 08:00 PM
Photos of damage to J3 Cub propeller after new engine mount installation [email protected] Home Built 0 August 9th 04 09:32 PM
Photos of damage to J3 Cub propeller after new engine mount installation [email protected] Home Built 0 August 9th 04 09:31 PM
